Old March 26th, 2020, 05:28 AM   #1
ssrsupermoto
Motorcycle(s): 2004 Ninja 250
Exhaust modification question
So after reading it seems pointless and a pain in the ass to use pod filters since the stock air box flows good. So I am leaving the stock air box and I have a drop in UNI filter. So to try and squeeze a bit more power it seems like a 2 to 1 exhaust is the best option. Now my question is it just the 2 to 1 part of the exhaust that is making the difference or is it the straight through muffler. Reason I ask is I can have a 2 to 1 exhaust fabricated and tig welded very easily but I don't want that obnoxious loud muffler, So I was thinking making a 2 to 1 exhaust using the stock muffler. Would there be any benefit using the stock muffler with a 2 to 1 system. My other option would be use a Hyabusa muffler or 1000cc GSXR muffler with a 2 to 1 system, there single chamber and flow very well and light weight being aluminum. I think those options would give it a little noise but not be crazy loud with how high this bike revs.
ssrsupermoto is offline   Reply With Quote
Old March 26th, 2020, 06:38 AM   #2
Both exhaust and muffler work together to improve flow and increase power... varies by RPM-region..
Trick for header section is to have proper length. You'll want somewhere between 20-24". Then use smooth 2-1 merge-collector. A LOT of aftermarket exhausts don't even use merge collector and just bend each header towards each other in U-shape. This actually causes exhaust-flow from each header to run into each other head-on; not good for flow.
Another critical measurement is diameter of pipe after the merge. It should be larger, close to 2x cross-sectional area of each header pipe.
Now, not sure which stock muffler you're talking about. Each one is sized for single cylinder. If you combine both cylinders into one and send it through one factory muffer instead of two, that'll be way too restrictive and you'll lose power. Want muffler optimised for 250cc flow each. Something like one muffler from EX500. Again, sizing is critical; using too large of muffler will hurt more than help.
So do maths, get optimum size header pipes of proper length. Make sure pipe after merge collector is proper size. And use muffler of matching size for engine. Multi-chamber muffler would be quieter than straight-through muffler.
You can see photos of various OEM and aftermarket exhausts I compared here: https://www.ninjette.org/forums/showthread.php?t=338180
Last futzed with by DannoXYZ; March 27th, 2020 at 11:39 AM.
Exhaust Question skilletmo 2008 - 2012 Ninja 250R Tech Talk 15 November 22nd, 2012 05:13 PM
Exhaust question Suave 2008 - 2012 Ninja 250R Tech Talk 15 July 1st, 2011 01:07 AM
Exhaust Question. pucktoplay1 2008 - 2012 Ninja 250R Tech Talk 2 June 6th, 2011 06:05 PM
Exhaust Question 02ninjaeastbay 1986 - 2007 Ninja 250R Tech Talk 7 March 25th, 2011 02:01 PM
exhaust question reaperw General Motorcycling Discussion 5 February 5th, 2011 09:41 PM
