Old May 29th, 2020, 03:56 PM   #1
Raddad70
Motorcycle(s): Honda cx650, 2005 ninja 250
Project finished
Just had to complete the funky ninja winter project.
File Type: jpg B776C74F-4F8A-4D2E-959C-F57814529D9D.jpg (147.0 KB, 49 views)
File Type: jpg 4B0A904D-C6D7-4986-BFAE-5FE0D1347244.jpg (210.4 KB, 43 views)
Raddad70 is offline   Reply With Quote
Old May 29th, 2020, 04:21 PM   #2
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Looking cool, they give you any **** about the pods as headlights?
Old May 29th, 2020, 04:22 PM   #3
Cool!
What's the beam-pattern like on those lights? DOT spot-pattern like flashlight? Or real e-code with cut-off?
Old May 29th, 2020, 06:01 PM   #4
Raddad70
Haven’t had it inspected yet and if it doesn’t pass I will throw a dot approved headlight on. They are a wide beam 30% spot. Top I’d hb and bottom is day running. I have them wired into a H4 socket - plugs right in. I will have to check beam pattern on the garage door. Also using a Garmin for the speedo not sure they will like that either.
File Type: jpg 341D4867-0EBB-4A84-B0F5-FB9C0074FB12.jpg (64.7 KB, 7 views)
File Type: jpg 9201439C-FA35-4E4E-9FB3-821DF7EF5277.jpg (179.3 KB, 21 views)
Old May 30th, 2020, 04:53 AM   #5
ForceofWill
What year first gen is it? In VA at 25yrs old you can get antique tags and are exempt from inspection.
Edit: If it's the 05 in your sig then nevermind lol.
Old May 30th, 2020, 07:25 AM   #6
Raddad70
One aspect of this build I most like is there is no plastic. Fenders, side panels, and even hand controls are all aluminum.
File Type: jpg 63C9D0C5-C5C8-4B16-83E6-77540273BA92.jpg (204.0 KB, 20 views)
Old June 1st, 2020, 01:12 PM   #7
Ceeloo Yello
Motorcycle(s): 250
Sweet!
Old June 1st, 2020, 06:59 PM   #8
rstnick
rstnick's Avatar
Motorcycle(s): 2011 250R, 2000 ZRX1100C4, 1978 KZ650C2
Well done!
rstnick is offline   Reply With Quote
Old June 2nd, 2020, 05:35 AM   #9
MonsterMash
Corporate Thug
MonsterMash's Avatar
Motorcycle(s): 2010 Victory Cross Roads, 1992 Ninja 250
definitely different.
i likes!
curious as to how you mounted the handlebars though.
did you fab up some mounts to use the stock mounting holes or did you drill and tap the top triple for the handlebar mounts?
thinking that it would look better for my son's cafe build.
also, where did you get the controls?
2010 Cross Roads
1992 Ninja 250 (nicknamed 'The Zombie' because its coming back from the dead)
Navy ET1 1994-2000 - Its not just a job, its an adventure
MonsterMash is offline   Reply With Quote
Old June 4th, 2020, 04:01 PM   #10
Raddad70
Drilled straight through the triple tree- secured with a large nut underneath. Got the controls off fleabay and traced out and resoldered every wire also modified a pit bike throttle cable to work with it
Old August 23rd, 2020, 01:02 PM   #11
D_Fresh
Motorcycle(s): 88 Kawasaki Ninja 250, 05 Kawasaki Z750S
What gas tank and seat is that? I love it. Looks amazing
D_Fresh is offline   Reply With Quote
Old August 23rd, 2020, 01:49 PM   #12
Raddad70
I sold it weeks ago. The tank is off a Honda quad fourtrax. Needed some work to get it to fit right and the seat is the stock one with the rear cut off and reattached to the front. Again lots of riveting, extra bracing gluing and shaping the foam to fit.
Old February 17th, 2021, 02:54 PM   #13
justanotherone1
justanotherone1's Avatar
Motorcycle(s): Ninja 250 EX x2, 07" CBR600RR, 09"SFV 650 Gladius
Nice bike!! I'm currently dismantling a project and restoring it right now. What handlebar is that and where did you find the adapters? Thanks for the share!
justanotherone1 is offline   Reply With Quote
Fun Pre-Gen Winter Project Finished 59096 1986 - 2007 Ninja 250R Tech Talk 3 August 13th, 2019 04:49 PM
Finished my project bike ThatCoolDude 2008 - 2012 Ninja 250R Tech Talk 17 June 23rd, 2019 08:37 PM
Just another Ninja Café...finished project. LTCTPU 1986 - 2007 Ninja 250R Farkles 14 August 28th, 2016 08:53 AM
finished my project Dave Swanson Pictures 4 April 21st, 2016 01:51 PM
Finished ZX6R - NickJPassss nickjpass Pictures 35 October 1st, 2012 02:10 AM
