Old May 29th, 2020, 07:37 PM   #1
astrochimp
Motorcycle(s): 2004 250ex
Neutral light not staying on in neutral?
If you mess with the shifter, you can get the light on but half the time you put it into neutral and the light is off.
Is there an adjustment somewhere for this to have the light on all the time in neutral?
THANK YOU!!!
astrochimp is offline   Reply With Quote
Old May 30th, 2020, 10:29 AM   #2
Kowalski
Kowalski's Avatar
Motorcycle(s): 2014 Ninja 300
There’s a bullet connector above the shifter. That’s your neutral light switch. The connector might loss or the switch might on its way out. There’s no adjustment for the switch but you can tighten the plug if needed.
Kowalski is offline   Reply With Quote
Old May 30th, 2020, 12:16 PM   #3
astrochimp
awesome info...checking it out now
THANKS
Old May 31st, 2020, 03:40 PM   #4
One person had wire cut by chain. Never know what's up until you look closely at that wire.
issues with shifting/neutral light. PLEASE HELP!! halfassmech 2008 - 2012 Ninja 250R Tech Talk 8 June 7th, 2018 10:15 PM
Neutral Light/Safety switch not working help. RuthlessZ 1986 - 2007 Ninja 250R Tech Talk 14 February 13th, 2015 11:31 AM
1st Gear or Neutral when at a red light? ajcadoo General Motorcycling Discussion 27 April 21st, 2012 09:32 PM
Neutral Light islander 2008 - 2012 Ninja 250R Tech Talk 8 March 22nd, 2012 08:16 PM
Brake light on while in neutral? andrewsfm 2008 - 2012 Ninja 250R Tech Talk 13 July 31st, 2011 07:45 PM
