Old July 7th, 2020, 03:06 PM   #1
drychain
Motorcycle(s): 2008 ninja 250r
Need new radiator filler neck??
Hey guys i need to replace the radiator filler neck on my 08 250. The plastic surface where the gasket seals is damaged and that causes it to leak. I can get one at my dealer but it is backofdered for a couple months and it’s $120. Does anyone have one they’d be willing to sell or any leads where I can find one??
drychain is offline   Reply With Quote
Old July 7th, 2020, 03:15 PM   #2
Bummer,
Pics, year and such is needed to help others offer what they have will go a long way here. Is it safe to assume that you are looking for 08-12 years?
Depending on the damage, a new cap will seal just fine. This is where pics will help.
Thanks and good luck!
Old July 7th, 2020, 03:35 PM   #3
drychain
Thanks for your reply. As mentioned above it’s an 08. The problem is that the filler neck is damaged and coolant can exit between the sealing surface on the filler neck and the gasket on the rad cap. I could try some epoxy but would rather fix it right. I’m not able to post a picture because I’ve temporarily “fixed” the issue by adding some gaskets on the rad cap but it took a few tries to get right but it works now and I don’t want to take it apart before I have a new part
Old July 7th, 2020, 04:21 PM   #4
Emu
Emu's Avatar
Motorcycle(s): 2011 Ninja 250r
This is the part from bike bandit and oem part number
https://www.bikebandit.com/oem-parts...685&sch=706586
Kawasaki CAP-ASSY Part # 14075-1061
A Google search of that part number brings up new and used listings.
Used listing for $9
https://www.ebay.com/itm/312557438316
Emu is offline   Reply With Quote
Old July 7th, 2020, 05:55 PM   #5
drychain
Used listing for $9
Emu, Thanks for that! I had checked Ebay but I didnt find anything strangely. $40 shipped to Canada and itll be here in a week. Awesome!
Old July 7th, 2020, 06:34 PM   #6
Emu
Emu's Avatar
Any time man. Keep that bad boy on the road!
Old July 8th, 2020, 02:54 AM   #7
I think radiator cap only fits on one way, at least mine does. In the other orientation, it can actually scratch off material from filler neck. Which will then cause leak. Install cap gently and don't force it if it doesn't want to spin on. Instead, remove and re-stall 180-degrees from before and see if that fits better and spins on without too much force.
Old July 8th, 2020, 07:24 AM   #8
drychain
Interesting, thanks! I'll be sure to check that!
Old July 13th, 2020, 07:24 AM   #9
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
Thumbs up
Helpful soul! We are eternally grateful.
arthury is offline   Reply With Quote
Old July 13th, 2020, 10:12 AM   #10
Emu
Emu's Avatar
I spent 4 years in the army working on and with the Patriot Missile system. My whole life revolved around reading and understanding parts diagrams, wiring schematics, and trouble shooting. That's all my brain wants to do now lol.
If anyone in the forum wants/needs help with finding parts anyone is welcome to DM me. This community is honestly awesome and I want to give back as much as I can.
Is this normal, the level of coolant in filler neck after changing it?(with picts) coelgrim 2008 - 2012 Ninja 250R Tech Talk 10 November 5th, 2012 05:37 PM
Red Hot Glowing Radiator Supports/Radiator Top bluebr65 2008 - 2012 Ninja 250R Tech Talk 10 March 10th, 2012 10:05 AM
