Old January 13th, 2010, 10:20 PM   #1
jonthechron
Motorcycle(s): magHitVE
2008+ Ninja 250r FULL Electrical Wiring Diagram here!
I have just edited a wiring diagram for the 2008+ Ninja 250r. I have made this diagram easy to follow and added some detail.
This is version: US 1.1 (my version of the diagram)
If you have ANY requests or suggestions, please leave a comment here and I will look into them and possibly update the diagram.
I might soon change wire colors from black to colored for easy reference.
Here is a link to the complete wiring diagram.
Click here for the full size wiring diagram. (1600 x 1200)
Here is a diagram I edited for easy reading and tracing on the turn signal circuit.
Click here for the full size wiring diagram with turn signal circuit highlighted.. (1600 x 1200)
EDIT: Replacement pic:
Last futzed with by Alex; February 1st, 2014 at 10:00 AM. Reason: Changed pic out
Old January 14th, 2010, 11:33 AM   #2
Trixxr
Motorcycle(s): Ninja 250r
My eyes are bleeding!
But thanks! This could really help alot of people (including me!).
Trixxr is offline   Reply With Quote
Old January 14th, 2010, 01:43 PM   #3
Anyone know if anything has changed for 2009 or 2010?
Old January 14th, 2010, 02:03 PM   #4
jonthechron
no, nothing has changed.
Old January 15th, 2010, 02:36 PM   #5
jonthechron
Originally Posted by ducducgooseit View Post
Would you please PM me a PDF version of your Turn Signal enhanced drawing?
I will try and make a PDF version, but for now a PDF version is not yet available. Is this for printing? Because I can make a printable version that should fit on a 8,5 x 11
Ill be back on later, Jon
Old February 9th, 2010, 01:19 PM   #6
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Thanks - amazing how complicated it is yet works. You would have thought that simple British electricals of the 60s/early 70s would have been more reliable.
Old February 11th, 2010, 08:47 AM   #7
Timm3h
Perfect thanks!
I was looking for this awhile back for my bike PC.
Timm3h is offline   Reply With Quote
Old July 21st, 2010, 02:45 PM   #8
kobachi
kobachi's Avatar
Motorcycle(s): Blue 2008 Ninja 250R
Actually several things did change in the 2010+ (JAF+) model -- the 3rd edition of the service manual has separate diagrams for the JAF vs. the J8F/J9F. I will have a closer look and try to detail the changes soon.
kobachi is offline   Reply With Quote
Old May 29th, 2011, 03:16 AM   #9
Lowspeed Lowside
Tightwad Tinker
Lowspeed Lowside's Avatar
Motorcycle(s): '09 Ninja 250R
Great stuff!
After 25 years of inactivity I've decided to make futzing around with electronics a hobby again. Do you have any knowledge of what kind of current/voltage the crankshaft sensor generates? A pic32mx795 development board is in the mail and I'd like to make the crankshaft sensor periodically generate an interrupt.
Lowspeed Lowside is offline   Reply With Quote
Old May 29th, 2011, 09:44 AM   #10
lowspeed, not sure about the current specs but if you're looking to get rpm you can use an induction lead with one of the coil wires. just a thought. if you have a multimeter take some specs and let us know.
Old May 29th, 2011, 04:14 PM   #11
Lowspeed Lowside
Tightwad Tinker
A lot of the information is in the Service Manual. It's probably a Hall effect sensor, but I'm not going to bet on it.
Old September 26th, 2011, 10:56 AM   #12
OddlyOrdinary
Motorcycle(s): 2009 SE Ninja 250
The diagram links no longer work. Anyone still have them?
edit: Google fu found them somewhere else but just fyi these images are down.
OddlyOrdinary is offline   Reply With Quote
Old September 26th, 2011, 12:38 PM   #13
The pics are still working for me? Anyone else?
Old September 26th, 2011, 12:48 PM   #14
works for me.
Old September 26th, 2011, 01:30 PM   #15
HKr1
IC2(SW)
HKr1's Avatar
Even see them here at work, that usually never happens.
Old September 26th, 2011, 03:13 PM   #16
jonthechron
Works for me, you can copy paste this in your browser incase you don't see them. Sometimes the server goes down for maintenance but but it should be up shortly..
http://www.mickeywebpages.com/users/...e_Dia_v1.1.gif
Old November 24th, 2011, 09:12 AM   #17
JDymonds
Motorcycle(s): Kawasaki ninja 250ex 2009
Wiring assistists pretty please w/a cherry on top :)
Hi guys,
My next project is installing halo eyes on my head lights w/led. I purchase the things I need. The issue I have is finding which line on wiring diagram should I connect the on/off switch to? And thank you so much for posting the Electrical system wiring diagram. Not to many caring people around to do such a thing. Thank you once again.
JDymond$
JDymonds is offline   Reply With Quote
Old November 24th, 2011, 10:33 PM   #18
jonthechron
It all depends on when you want them to turn on, and how you want them to turn on.
You would wire them up to different points on diagram depending on what you want..
Eg. You want them to turn on when you flip a switch, but only when the bike is on.
You'd would wire them with a switch to the lowbeam circuit.
Eg. You want to be able to turn them on whether they key is in the on position or not.
You could wire them straight to the battery with a switch and fuse.
Old November 25th, 2011, 11:14 AM   #19
JDymonds
Thumbs up Wiring assistists pretty please w/a cherry on top :)
I was thinking straight to the battery but I would like to wire them to the lowbeam circuit. I'm not sure which wire it is those. I do have the wiring diagram. It's terrible because I am an audio engineer and I do repair resistors etc if need to be in speakers or mics. I know I can do this job, I'm a perfectionist and I want to do it correct, you know? I need to know which line is it and the color. It is something that unplugs like the signal turns or do I have to cut the wires and twist them together with the angel eyes/leds to the on/off switch? Thank you for your help and very quick response.
Jessica
Old November 26th, 2011, 08:10 PM   #20
jonthechron
I would spilce them in with the BLUE/YELLOW positive wire going to the lowbeam
So Lets say the positive from the lowbeam (blue/yellow) to your switch and from your switch to the angeleye positive. The negative would go to the any ground wire (black/yellow), it should be as simple as it sounds.
This way not anyone can just flip the switch anytime and turn your angel eyes on because they would require the key to be in the on position before the switch is flipped.
Old September 20th, 2013, 06:54 AM   #21
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Getting a 404 Not Found on the IMG links.
<-- Linky
Old September 20th, 2013, 10:07 AM   #22
corksil
Motorcycle(s): A lot.
Me too
If anyone has the pic, I'll throw it/them on my photobucket and provide a permalink.. I've had my photobucket for like 10 years now, so I'm not disappearing anytime soon.
Old October 26th, 2013, 06:57 PM   #23
rasta
Your face
rasta's Avatar
Uuuuuhhhh it would be terrific if we could get this sticky updated.....
Anybody have one handy? I've only found diagrams for Pregens
Old October 27th, 2013, 03:30 PM   #24
@jonthechron - do you still have these images somewhere? I can edit the posts to point in a new direction if they exist elsewhere.
Old November 2nd, 2013, 11:55 PM   #25
so the one thing that changed between 09 and 10 is the connector for the stator is different. on the 10 they are all lined up in a row whereas the 09 has two next to eachother and the third opposed.
Old November 3rd, 2013, 12:09 AM   #26
Old November 3rd, 2013, 08:04 AM   #27
NevadaWolf
NevadaWolf's Avatar
linked pic of wiring diagram
Just in case imgur breaks years down the road, trying to attach the pic to this site.
<-- Linky
Old February 1st, 2014, 12:02 AM   #28
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
From the updated Service Manual (5th Edition, May 18th, 2011). I merged the two separate pages together so it is one fluid graphic.
Gives no year, only model number "EX250J8", but should apply to 08+ Ninja's (United States).
Attached is zip of the full resolution image (8250X6250) and also just in case it goes down from imageshack.
linkinpark9812 is offline   Reply With Quote
Old February 1st, 2014, 12:21 AM   #29
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I will need to check this out when sober and on a computer
TEAM ALFALFA
www.apexassassins.com
Old February 2nd, 2014, 08:50 PM   #30
linkinpark9812
And because the Superbowl game started sucking, I started to color the diagram, so here you go.
Full Resolution ZIP attached.
File Type: zip 250 Full Electrical Diagram (Color).zip (1.54 MB, 202 views)
Old February 13th, 2014, 07:13 PM   #31
jonthechron
Hey Alex, sorry I don't know what happened to the server they were hosted on... just dissapeared from one day to an other. I don't have the wiring diagram at the moment, I can try and make a new copy and send it to you.. it could take a little while.. Thanks
Last futzed with by jonthechron; February 13th, 2014 at 07:17 PM. Reason: Turns out I do still have a copy of them.
Old February 13th, 2014, 07:19 PM   #32
jonthechron
I have a higher quality version (1600 x 1200), let me know if I can e-mail it to you.
Old September 20th, 2016, 12:34 PM   #33
Mbene
Motorcycle(s): Triumph Daytona 675
Super helpful! Thank you
Mbene is offline   Reply With Quote
Old November 20th, 2016, 02:59 PM   #34
Not to be picky, but does anyone have a massive PDF of this instead of a jpeg or png? Already have a pdf of the pregen diagram, looking for the same thing on the newgen.
Old September 28th, 2017, 11:08 AM   #35
squidoonewblet
tiny rider
Motorcycle(s): 2009 250r
Can you repost as this was error-ed out.
squidoonewblet is offline   Reply With Quote
Old September 28th, 2017, 11:10 AM   #36
squidoonewblet
tiny rider
OOPS. Silly me, just saw the posts below. Please ignore.
Old November 4th, 2017, 08:35 PM   #37
Darksik
Darksik's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R, 99' Suzuki Katana 600 (RIP)
Can you please upload this again, the server is down
Darksik is offline   Reply With Quote
Old December 7th, 2018, 12:29 AM   #38
drbninja
Motorcycle(s): 09 Ninja 250R
i was looking all over for this, thanks!!
drbninja is offline   Reply With Quote
Old April 4th, 2021, 04:12 PM   #39
JayVapes
JayVapes's Avatar
Motorcycle(s): Ninja EX250
Where is it?
RIDE IT UNTIL THE WHEELS FALL OFF, THEN BUY NEW WHEELS
JayVapes is offline   Reply With Quote
Old August 15th, 2022, 08:49 AM   #40
Originally Posted by JayVapes View Post
Where is it?
Yeah. Anyone have a backup? I have the Clymer manual but I wanted to do a comparison.
1988+ Ninja EX250 FULL Wiring Diagram here! jonthechron 1986 - 2007 Ninja 250R Tech Talk 20 May 20th, 2023 08:53 AM
Wiring diagram and Repair Manual EMSRacer07 2013 - 2017 Ninja 300 Tech Talk 2 October 27th, 2013 04:27 PM
Wiring diagram bruce71198 1986 - 2007 Ninja 250R Tech Talk 4 September 20th, 2013 05:22 AM
300 Wiring Diagram Foxrider64 2013 - 2017 Ninja 300 Tech Talk 2 June 3rd, 2013 12:24 PM
Ok hopefully someone can answer this one...(speedometer harness wiring diagram!) skilletmo 2008 - 2012 Ninja 250R Tech Talk 7 November 7th, 2012 10:43 AM
