October 28th, 2021, 02:48 PM | #1 |
Join Date: Jul 2019 Motorcycle(s): '85 750 Turbo E2 - '86 600 Ninja - '82 FT 500 Ascot Posts: 45
2009 Ninja 250 giving me fits lol
October 28th, 2021, 03:49 PM | #2 |
This is carburetor related, not spark. The left carb's idle circuit is not supplying fuel, as demonstrated by the engine stalling when you unplugged the right coil. This could be dirt in the carb or just the idle speed set too low.
After you correct that, let us know if the stalling on quick throttle opening still happens. |
October 28th, 2021, 03:59 PM | #3 | |
Ive cleaned the carbs 2x, this a.m. I. The ultra sonic and carbs spray in every orifice....and that doesn't make sense because once it's above 3k or so rpm it still has the issue. If it was idle circuit I would t think it would not affect mid throttle, maybe off idle it would....and I just don't think it would bog down so bad if it was just idle circuit.
October 28th, 2021, 04:39 PM | #4 | |
October 28th, 2021, 04:49 PM | #5 |
Join Date: Jul 2013 Motorcycle(s): 2007 SV650S 2005 EX250F Posts: 486
Yup, and everyone wants to believe they're clean after the first, second, tenth time going through them... tiny carbs can be frustrating. Other carbs are much easier to clean than these.
Don't think, look! |
October 28th, 2021, 05:43 PM | #6 | |
I hear ya, I've read all those posts. They spent 2 hours in the ultrasonic and then carb cleaner and compressed air thru all the orofices. Maybe still carb related but doubtful from dirt. And the prob is kind of a mid and full throttle prob and pilots, needles and mains are spotless
October 28th, 2021, 05:51 PM | #7 |
I'm really starting to wonder if maybe this has something to do with the slip-on and the drop-in filter
October 28th, 2021, 05:59 PM | #8 | |
I know this is kind of out there, but is it possible this issue is being caused because I'm using the IV bottle and have the vacuum for the petcock plugged. I'm just wondering if the pressure from the IV bottle is doing weird things to the carb like maybe pushing too much fuel in it and maybe having the vacuum plugged is doing something... just a thought I guess I'll hook up the tank and try it tomorrow
October 28th, 2021, 06:53 PM | #9 |
I can assure you carb needs further cleaning. Carb-sprays no longer work due to removal of chlorinated compounds. Pee actually works better since it has ammonia.
Have to completely disassemble carb down to every last nut, bolt and individual component. If it can be futher disassembled, it needs to be done. Then physically scrub all parts and all petrol passages form end to end with scrub-brushes using PEA-based fuel-system cleaner. http://n4mwd.blogspot.com/2013/10/se...-passages.html Poke out all bleed holes in jets, emulsion-tubes and carb-venturi with matching size soft copper wire. You'll find it pokes out little plastic dried petrol plugs like little grains of sand. No way that's being dissolved by any kind of solvent. Make sure you re-assemble needle-jet/collar with tapered end facing needle. Micro soda-blast everything. Many expert mechanics with decades of experience have had to pull carbs 4-5x for ever deeper cleaning before they got it factory-fresh clean and bike ran like new. Best to do full restoration first time around so you don't have to keep on pulling them. As for petrol-flow into carbs, best to measure and get some numbers. Then you'd know for sure rather than trying out different things without knowing before & after measurements. Bottle is fine since any flow issues would affect both carbs evenly. Unless you need to replace fuel-rail O-rings, which might affect one side more than other, so should be done anyway. Also replace all rubbers such as float-valves, flow-bowl seals, maybe even slide diaphragms as needed. |
October 28th, 2021, 07:48 PM | #10 |
October 28th, 2021, 07:58 PM | #11 | |
This is great, great info thx. I'm not discounting what you are saying, but I did completely disassemble them today. I'm just wondering what passage I could have possibly missed.
I will pull them again tommorow and thank you HUGE, for taking the time to write that post. Hopefully my next post will be one of success instead of defeat lol Quote:
October 28th, 2021, 08:33 PM | #12 |
did you clear out choke circuit? The jets in those aren't removable. Had recent case where they had to be drilled out with micro drill-bit! Dried petrol couldn't even be pushed out with wire!
October 29th, 2021, 06:14 AM | #13 |
Did not. I figured the ultra sonic would do that. Where are those located? Pulling carbs - uh gain - today and hitting those and the super teeny tiny ones right under the butterfly in the venturi
October 29th, 2021, 07:43 AM | #14 |
Join Date: Oct 2021 Motorcycle(s): 08' ninja 250 and Honda XL600 Posts: 31
The aftermarket exhaust is probably not throwing off the mixture much, as I run mine straight pipe and never had to re-jet from stock and it runs great, but the air filter setup will. If you do not have the stock airbox then your constant velocity carburetor will not have the same vacuum and will not have the same fuel/air mixture.
One last educated guess would be a vacuum leak. I had a dirt bike that did the exact same thing for years and I lived with it, only to discover the problem was a cracked intake boot. I sprayed water all over my engine and noticed the idle sort of stumbling. Then I narrowed it down with a squirt bottle. Other that bad fuel air mixture or vacuum leak I'm not sure what else it could be. |
October 29th, 2021, 08:04 AM | #15 |
October 29th, 2021, 08:27 AM | #16 |
October 29th, 2021, 10:03 AM | #17 |
October 29th, 2021, 10:45 AM | #18 | |
Rubber diaphragms in good condition? Slides manually rise and fall smoothly? |
October 29th, 2021, 08:14 PM | #19 | |
Wow, the internet has gotten weird.
October 30th, 2021, 05:33 AM | #20 |
October 30th, 2021, 05:40 AM | #21 |
Ok guys. Carbs pulled again. I'll be shocked if I can find something that the ultra sonic and carb spray missed. Will be fully separating carbs this time too. Seems like the plugs are wet so I'm thinking maybe it's an air passage in the carb that is blocked. We will see....
Thanks to everyone who has chimed in. Just so you know I'm not a random dumbass working on a bike for the first time lol https://youtube.com/channel/UCSIF32oHckawhBvL6SK8JwA |
October 30th, 2021, 10:04 AM | #22 |
Also work from carb-venturi back to float-bowls.
Bend copper wire 90-degrees 10mm from tip. Use that to poke out bleed holes from carb venturi backwards. Spray compressed air and carb-cleaner spray from there backward as well. Clear out choke circuits with some wire also Poke out lateral bleed holes in emulsion-tubes, pilot jets. Dried petrol becomes plastic and no kind of solvents will ever dissolve it again. Requires mechanical removal. Be sure to drill out mixture-screw plugs and remove screws. Replace O-rings |
October 30th, 2021, 10:43 AM | #23 | |
Thanks I'm doing them right now What do you think I should set the mixture screws at 2 and 1/2 turns out?
October 30th, 2021, 11:24 AM | #24 |
Well, as I suspected, it was not the carbs. Thouroughly cleaned them as per Dannos instructions and have same problem. I knew they should be clean enough after the ultra sonic and carb cleaner. So at least I can rule them out
October 30th, 2021, 12:02 PM | #25 |
I guess I need to look at other things. Could it be a crank sensor or maybe something in the ignition is bad. Maybe a ground??
Ready to push this thing off a cliff. https://youtu.be/mqNxZ0I3m6k https://youtu.be/YXqHmQC4edM |
October 30th, 2021, 12:23 PM | #26 |
have you adjusted valve clearances?
October 30th, 2021, 12:28 PM | #27 |
October 30th, 2021, 12:49 PM | #28 |
October 30th, 2021, 12:53 PM | #29 |
A compression test would tell you if the valves are closing.
October 30th, 2021, 01:27 PM | #30 |
October 30th, 2021, 01:32 PM | #31 |
Is it possible the drop in K&N and slip on yosh have screwed up the jetting
October 30th, 2021, 01:41 PM | #32 |
October 30th, 2021, 01:42 PM | #33 |
modded, kit jetting? post sizes, and needles too.
October 30th, 2021, 01:59 PM | #34 |
October 30th, 2021, 02:16 PM | #35 |
pilots not hogged out, 4 sure?
U needle in LH carb, W in RH?
October 30th, 2021, 02:22 PM | #36 |
you've synched carbs using proper manometer?
in post #27 you've dismissed valve clearances? a guy with a "new to him" EX500 (suffering fluctuating idle) was urged to check his....found *all* tight. Suggest you check them, assure they are in spec....that and a return to 98 mains.
October 30th, 2021, 03:03 PM | #37 |
My pre-gen with only 2000-miles needed valve-adjustment.
October 30th, 2021, 03:56 PM | #38 |
low mileage 500's as well...tight exhaust valves. Always. Exhausts.
October 30th, 2021, 04:10 PM | #39 |
October 30th, 2021, 04:12 PM | #40 | |
Great advice, but getting 170-180 on compression and highly doubtful it's causing my issue in the 2nd vid above ....
Ninja 250 stalls when giving throttle | ji0315tafeng | 2008 - 2012 Ninja 250R Tech Talk | 4 | August 24th, 2015 10:43 AM |
