Old November 7th, 2021, 09:39 PM   #1
Leonardo Lupo
Free spring!
Did a carb clean and rebuild, then found a spring on the floor next to my bike. Runs fine, potential weight savings????
Anyone know where this is from?? I opened the fuel tank valve and the carb and the airbox; and removed the carb from the body so messed with everything I had to to get it out.
Cheers
Bringing Ninjas to The Outback!
Leonardo Lupo is offline   Reply With Quote
Old November 8th, 2021, 08:12 AM   #2
Originally Posted by Leonardo Lupo View Post
Hey,
I have a very similar problem. Just did a carb rebuild and didn't fix it. Mine isn't to bad and bike runs fine in higher rpm.
Mine also got worse! I think it turned out that my fuel tank diaphragm dried out and stuck together, as pulled it apart, unstuck it and it works. Problem is that that tank valve never really worked. Could I grab an expert opinion on this:
on my bike:
When the screw is horizontal (pointing to "ON") and there are no hoses, fuel exits the large port on the valve.
When the screw is pointed down (pointing to "PRI") and there are no hoses, fuel exits the valve. Can't remember which port(s).
I leave my bike on "ON" as this seems logical due to its name. I read above that this valve could cause problems, is that the case?
Cheers
The spring is for your petcock diaphragm. It keeps petcock closed until vacuum is applied to small port to open it.
In ON position, fuel should not flow until you apply vacuum to small port. Put spring back in petcock. Otherwise you risk dripping petrol into engine and hydrolocking it.
Old November 8th, 2021, 08:19 AM   #3
Leonardo Lupo
Thank you so much. Should I ride and idle in ON position?
Old November 8th, 2021, 08:24 AM   #4
Originally Posted by shspvr View Post
Just case any of you didn't know this but the pointing to "PRI" is actually also the fuel reserve it the short tube so you see it serves two purposes
On 2008-12 new-gen models, petcock is much simplified over earlier versions with no reserve setting.
1. no-reserve, there's only one drain port and it's at very bottom of tank. Entire tank can be used from very beginning. Notice 2nd port for previous design is blocked off with brass plug
2. ON works as normal vacuum-activated setting. No fuel flows until vacuum is applied on small diaphragm port
3. PRI flows without needing vacuum. This is convenient for draining tank.
4. No selector lever since you don't need to switch between ON and non-existent reserve. Just slot for screwdriver in those rare cases when you need to switch to PRI to drain tank
Old November 8th, 2021, 08:27 AM   #5
Leonardo Lupo
Perfect thank you so much!
Old November 8th, 2021, 08:47 AM   #6
When I go to bike meets, I grab handful of random nuts & bolts from jar. Then randomly sprinkle them under people's bikes! Keeps them entertained for hours!!!
Old November 8th, 2021, 10:24 AM   #7
PRI is also very convenient if the bike has been sitting for a couple weeks and the fuel level in the bowls has dropped. Going to PRI for a few seconds fills the carbs and greatly reduces the cranking time to start the engine.
Old November 8th, 2021, 11:18 AM   #8
Yeah! Or when 1st installing carbs after getting it back from ducatiman for restoration!
2007 ZX6R Clutch Spring Plate/Clutch Spring Direction? KnuckleBuster General Motorcycling Discussion 2 August 24th, 2015 03:21 AM
[motorcyclemonster] - Waterbury, CT - Spring Open House and Free Pig Roast May 4, 201 Ninjette Newsbot Motorcycling News 0 April 24th, 2014 08:10 PM
[superbikeplanet.com] - Soups's Free Classifieds, Born Free. Live Free. Sell or Trade Ninjette Newsbot Motorcycling News 0 July 14th, 2010 03:00 PM
[superbikeplanet.com] - Soup's Free Classifieds: Born Free, Live Free. (Sort By State Ninjette Newsbot Motorcycling News 0 November 21st, 2009 07:51 AM
[superbikeplanet.com] - Soup's Free Classifieds: Born Free, Live Free. (Sort By State Ninjette Newsbot Motorcycling News 0 October 24th, 2009 09:20 AM
