April 2nd, 2010, 12:13 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): Candy Plasma Blue 250r Posts: 79
My bike is stuck at 65 mph and won't go any faster?
Yesterday I was traveling on the HWY and couldn't get past 65mph and 9000rpm. I had the throttle fully rolled back in 6th gear. It just wouldn't go any faster and the rpms wouldn't move past 9000rpm. I was going against the wind, but don't understand why the bike wasn't climbing in RPMs at all. The winds were strong, but I was in a full tuck and it wasn't the worst gusts of wind I've experienced. An hour later, the winds died down and the bike was back to normal and I could travel faster than 65mph.
What happend? Thanks, David |
April 2nd, 2010, 12:31 PM | #2 |
Zombies.
April 2nd, 2010, 12:40 PM | #3 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Was it cold?
Mine does the same thing when it gets down below 20 F. If I'm on the freeway for more than 20 minutes at such low temperatures, the bike mysteriosly loses power and it does not run more than 60mph. I pull off to the side and let it idle a few minutes to warm up and then the zombies are gone. The only explanation I have found is the cold. Even with the engine running at high RMP it is like the bike was never warmed up when you get moving at freeway speeds. THe wind chill wicks the heat away from the bike faster than it can produce it. I never have had the problem on a warm day or on side streets.
Addicted to anything that has an engine and rolls. |
April 2nd, 2010, 12:43 PM | #4 |
I wonder if the carbs are icing? I know some relatively modern but carbed bikes (Bonnevilles for example up until a year or two ago), had carb heaters to prevent the problem. I remember reading that ZRX1200's are subject to carb icing problems when ridden in very cold weather. Not sure I've heard about it on ninjettes yet, but I guess it's plausible.
April 2nd, 2010, 12:47 PM | #5 |
That is what I think it is! THe cold air at high speed freezes up the carbs. I let it idle and the heat from the block radiates back up to the carbs and then it runs fine.
I didn't mention but it is usually hummid and foggy when it is at those temps, so moisture is probably getting into the carbs and freezing.
April 2nd, 2010, 12:50 PM | #6 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
Are you hitting 65 mph right at 9000, or earlier?
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
April 2nd, 2010, 12:50 PM | #7 |
April 2nd, 2010, 01:28 PM | #8 |
Join Date: Apr 2009 Motorcycle(s): 09 Ninja 250 Posts: 184
Looks like UNTDAVID is in the Dallas area. It definitely wasn't cold here yesterday. I believe it was in the 80's. It had to have been the zombies.
April 2nd, 2010, 02:08 PM | #9 |
MOTM - Mar '13, Jun '14
Governor
April 2nd, 2010, 03:55 PM | #10 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
April 2nd, 2010, 05:01 PM | #11 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
David must be having trouble with the OD lock out.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
won't go above 58 to 60 mph | 904jeff | 2008 - 2012 Ninja 250R Tech Talk | 10 | March 22nd, 2014 09:20 AM |
Dropped bike at low MPH, drained float bowls, still won't start. | BoKing | 1986 - 2007 Ninja 250R Tech Talk | 17 | July 20th, 2013 07:07 PM |
[faster and faster] - Volkswagen motorcycles: Will they or won’t they? | Ninjette Newsbot | Motorcycling News | 0 | February 16th, 2010 03:30 AM |
[faster and faster] - Cedric Lynch: “They won't equal petrol-engined bikes unless som | Ninjette Newsbot | Motorcycling News | 0 | December 12th, 2009 03:10 AM |
[faster and faster] - BMW F800R: Will they or won’t they? | Ninjette Newsbot | Motorcycling News | 0 | August 21st, 2008 08:00 AM |
