February 10th, 2014, 06:19 PM | #321 | |
Just get an aftermarket shock! Dew eet right. Dew eet tight. I'm running the JRI shock. I love it. (missing shock obviously) |
February 10th, 2014, 06:29 PM | #322 |
Board Member
I run a Penske triple. Smooth as butter.
February 10th, 2014, 06:32 PM | #323 |
I ran a Penske on my Formula Twins bike. Loved that shock too. I did the JRI this time around because it's new and Cyclemall wanted to throw one on my bike. I'm going to be a guinea pig for a cartridge kit they're planning to build for Spears racing too. Can't wait to play around with that upgrade.
February 10th, 2014, 06:46 PM | #324 |
Board Member
Nice. I wonder how it will compare to the andreani (sp?) Kit.
February 10th, 2014, 06:59 PM | #325 |
I heard the andreani cartridges were a copy of the Ohlins kit but that could just be the rumor mill from Ohlins owners hating on another brand.
I'll let you know when it gets installed. I talked to Zoran at TWF and he said he could do a cartridge kit with GSXR internals for the Ninja for $700. He just needs a stock fork to take initial measurements so he can machine new fork caps. He hasn't done a kit for the Ninja yet but he's happy to do it |
February 10th, 2014, 07:34 PM | #326 |
Fighting Texas Aggie '05
^^ $700 would be downright reasonable if they were decent.
February 10th, 2014, 07:54 PM | #327 |
Board Member
Yes it would be.
February 11th, 2014, 09:45 AM | #328 |
Well I ran Zoran's GSXR cartridge swap in my Formula Twins stock forks and won a championship with that setup so I can vouch for his ability to do some good tuning. He's an SV650 guru so I bet he could tweak a set of 250 forks no problem
February 11th, 2014, 01:51 PM | #329 |
By the way, that deal with Zoran is open to anyone looking to take advantage. I'll post up about it.
March 17th, 2014, 07:14 PM | #330 |
Schönen Tag noch
Join Date: Sep 2013 Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica Posts: 184
March 17th, 2014, 07:36 PM | #331 |
Join Date: Oct 2012 Motorcycle(s): '04 R1 and '08 Ninja 250 Posts: 222
In the off season, Draik got emulators and a gsxr rear shock set up by Jamie at
http://daughertymotorsports.com/ Draik was able to drop his lap times at Roebling Road from his best time last year by 8.4 seconds! We are very happy with what Jamie was able to do.
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son |
March 18th, 2014, 05:39 PM | #332 |
Join Date: Aug 2013 Motorcycle(s): 1 2005 Ninja EX250, 1 2008 Ninja 250, 1 2009 Ninja 250 Posts: 37
I think my son's crash at Roebling a week or so ago in turn 7 may have been avoidable with better rear suspension. I need to look into the gsxr shock as we are still running a completely stock setup.
I am guessing our sons were racing together so hope to meet you next time out! Steve |
March 18th, 2014, 11:27 PM | #333 |
For racers on a budget Ohlins has come out with a new shock
2 way but only roughly $300-$330 Part Number KA-110013 Some distributors may not have it yet as it came out of Ohlins Asia division I emailed Ohlins Euro/USA & Asia to verify it is really a Ohlin & they confirmed yes it is & it is new Ohlin quality so should be a decent shock |
March 19th, 2014, 05:25 AM | #334 | |
March 19th, 2014, 06:49 PM | #335 | |
we are sticking with florida CCS this year but will be moving to Nashville next spring for my work and will probably start running the WERA races then. |
March 19th, 2014, 07:00 PM | #336 | |
Draik got one of the ~$125 dampers off ebay and have been really happy with it. You on facebook?
March 20th, 2014, 05:11 PM | #337 | |
I am on facebook as stephen andersen and kyle is kyle andersen. He also has a simple fan page too. I will check out the steering damper and will look more into the gsxr shock. I think we at least need to do something on the rear of the bike. I am sure we will cross paths once we get to TN. That is employer dependent right now though so will be a bit. |
March 20th, 2014, 05:26 PM | #338 | |
August 6th, 2014, 04:18 AM | #339 |
Join Date: May 2013 Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s Posts: 628
ok so as I was drilling out the steel sleeve in the rubber isolator the sleeve broke free. doesn't look like I can order just the rubber isolator to replace the broken one. how important is the isolator? can I put a steel spacer in its place? I have one that will fit perfectly. I don't want to stress any parts and possibly have a failure. any idea??
August 6th, 2014, 09:58 AM | #340 |
Board Member
what part are you talking about?
August 6th, 2014, 12:35 PM | #341 |
this one. I have a spacer in it now. I think it will be fine. nice and snug. the hole for the spacer is slightly off center. maybe 1/2 a mm or so. will make a new one soon.
August 6th, 2014, 04:33 PM | #342 |
Join Date: Jan 2014 Motorcycle(s): 1996 Ducati 900SS/SP 45k miles Posts: 132
race prep . . .
When I put on a GSXR 750 shock, I pressed the upper bushing out, And did not drill it to a larger ID. I put in a 16mm x 22mm piece of tygon tubing and a metal bushing that fit the diameter of the original upper mounting bolt. Nice press fit. All easily serviced if necessary. Drilling out the bushing leaves very little metal, and not much room, if any, for error.
Fred
'09 Ninja 250R track only SOLD "If everything seems under control, you're not going fast enough." -Mario Andretti |
February 12th, 2015, 12:50 PM | #343 | |
Join Date: Sep 2014 Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4 Posts: 250
Great info
for me weight 150 lbs no gear GXSR springs are too stiff , I believe I need 7.5 kg/mm or tops 8 kg/mm... now looking for spring rate on the ninja 300 rate for the spring.. once again great info |
November 17th, 2015, 05:20 PM | #344 |
Join Date: Nov 2015 Motorcycle(s): 2009 Ninja 250 Posts: 386
bumping this from the dead, new Ninja 250 owner here, prepping the bike for track days next season. Looks like the GSXR600 shock is a great mod. Just trying to figure out all the spacer/bolts I need to do it. I am much heavier than most guys here, 220lb so the stock spring that comes on the 600 shock might be pretty close to perfect for me.
November 17th, 2015, 07:01 PM | #345 | |
Join Date: Nov 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2006 Suzuki Hayabusa GSX1300R, 2004 Kawasaki ZRX1200R, 1985 Kawasaki 750 Turbo Posts: 118
November 17th, 2015, 07:03 PM | #346 | |
November 17th, 2015, 07:13 PM | #347 |
Stock bolt and drilled out the upper. Used spacers from the HW store. Then made my own dog bones from steel straight brackets for something I don't recall for but came with holes that were close in size on one side so only had to drill the other sides.
I believe I made them 156mm in length. |
November 17th, 2015, 07:14 PM | #348 | |
I was looking at the dogbones online for like $20 or something. |
November 17th, 2015, 07:21 PM | #349 |
November 17th, 2015, 07:46 PM | #350 |
just ordered the 600 shock, the 1000 shock and the dog bones. Thanks for the advice!
November 18th, 2015, 12:34 AM | #351 | |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
WARNING. My preload adjuster on the spring is supppper chewed up. Long story short I took my gsxr shock to a shop for service and he lost it...so he bought me one from eBay and the adjuster was ****ed up. Would have to get a screwdriver on it and beat the hell out of it to adjust. Can send pics if you like. edit: then I read further and saw you bought your stuff already. Whoops!
CVMA #531 |
November 18th, 2015, 01:18 PM | #352 | |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
Wish I could run that in CCS...great deal for the set up. I need to keep stock dogbones though so- stock shock works for me |
November 18th, 2015, 08:00 PM | #353 | |
November 27th, 2015, 01:05 PM | #354 | |
November 27th, 2015, 06:26 PM | #355 |
R&T Suspension
Join Date: Jun 2009 Motorcycle(s): Too many to list Posts: 175
This is what we use for the top gsxr shock mount.
Just drill out the frame mount a little bigger and these fit right in so you can use a smaller Dia. bolt. |
November 27th, 2015, 06:43 PM | #356 | |
maybe this is a dumb question, whats the reason for doing those over drilling out the shock? would this affect down the road installing a different shock? Thanks! |
November 28th, 2015, 09:23 AM | #357 |
R&T Suspension
You can use another size spacer for another shock.
Nothing wrong with drilling the shock except that I've seen the bushing get damaged several times and even if you get it drilled in the center the metal is very thin at that point. This is just the way we do it. |
November 28th, 2015, 12:04 PM | #358 | |
November 28th, 2015, 12:52 PM | #359 |
Track Clown
MOTM - Sep '15
Just ride the bike stock and when you start to out ride it, then get upgrades.
November 28th, 2015, 04:48 PM | #360 |
only mods I am doing are a body, and suspension and tires. Everything else is going to wait until my skill level improves to where it matters for things like jets/exhaust etc. Just lots of really bumpy tracks here in TX so I want something suspension wise that will help me stay on the bike.
Track Prep | nickjpass | Ninjettes At Speed | 38 | August 11th, 2014 08:13 PM |
Paint prep.... | ManOfGod | General Motorcycling Discussion | 21 | May 11th, 2013 07:50 AM |
2010 - Ninja 250r race prep | 675Raisinator | Motorcycle-related | 1 | December 26th, 2012 11:27 AM |
Project: N250r Race prep | racegunnr | Pictures | 19 | January 3rd, 2012 10:00 PM |
bike prep | Miss Informed | 1986 - 2007 Ninja 250R Tech Talk | 3 | March 14th, 2011 12:45 PM |
