Old February 22nd, 2019, 08:46 AM   #201
I thought the only advantage of E85 was the ability to crank the boost, and not much to be gained for a normally aspirated engine.
Is that right?
Old February 22nd, 2019, 09:21 AM   #202
Hibs
Motorcycle(s): 2010 Ninja 250R, 2000 Ninja ZX-12R
Is that right?
Ability to "crank the boost" on E85 comes from two things. First, it's a higher octane rating them regular pump (around 105 octane). Second, ethanol burns cooler, so lower cylinder temps.
There is gains to be had an a NA engine. On a NA 250, no, probably not much. But I ran E85 (with increased timing) on my NA ZX12R and it did provide gains.
Of course all depends on your combo, compression ratio, ability to adjust timing, etc
Hibs is offline   Reply With Quote
Old February 22nd, 2019, 04:18 PM   #203
Yep, E85 is about 108 octane and actually out-performs 110-octane race-gas I get at Sears Point raceway down the street. Most likely due to the cooler running to avoid detonation. Yeah, on NA engine, you have to tune to get extra power such increasing compression and advancing timing. Using in stock Ninja 250, won't get much gains.
I can actually run 13.0:1 compression on 100-bore NA engine with E85. Or 25psi with boost.
Pocketbike Nitrous ninja250 2008 - 2012 Ninja 250R Tech Talk 8 August 15th, 2011 06:56 AM
250 with Turbo/Nitrous Alex General Motorcycling Discussion 18 April 20th, 2010 06:40 PM
[sportrider - latest stories] - Nitrous Oxide--"Wet" and "Dry" Kits Ninjette Newsbot Motorcycling News 0 April 12th, 2010 11:20 PM
[sportrider - latest stories] - Nitrous Oxide--"Wet" and "Dry" Kits Ninjette Newsbot Motorcycling News 0 April 9th, 2010 11:30 AM
[faster and faster] - The 200bhp nitrous-oxide-powered Suzuki B-King Ninjette Newsbot Motorcycling News 0 November 11th, 2008 11:39 PM
