Old September 14th, 2011, 06:23 PM   #1
jdoucet93
jdoucet93's Avatar
Motorcycle(s): 2009 R6
Unhappy Fuel gauge not working
Ok so i finally got my bike back together after doing a little carb work and what nots. She runs better than ever! Everything works great and sounds great. Only problem is that my fuel gauge doesn't work now... I reconnected the all the hoses and the plug beneath the tank. The only thing i'm unsure of is the tube that seems to be coming up from right between the carbs, then back, under the tank, and out the side of the bike. I don't remember pulling that hose off of anything when tearing the bike down. But who knows... And also, There seems to be a place for a hose to connect to where the wires for the fuel gauge come out of the bottom of the tank. Not sure if i missed something somewhere or what. Any help would be great! Thanks!
jdoucet93 is offline   Reply With Quote
Old September 14th, 2011, 06:35 PM   #2
1LoneWolf
1LoneWolf's Avatar
Did you reconnect the fuel gauge sender? It's a green connector.
1LoneWolf is offline   Reply With Quote
Old September 14th, 2011, 06:37 PM   #3
jdoucet93
jdoucet93's Avatar
Yes, everything is connected. That plug is only one-way right? Theres no way to plug it in backwards is there?
Old September 14th, 2011, 08:50 PM   #4
1LoneWolf
1LoneWolf's Avatar
Hmm... not sure. When you plug it in, you have make sure the little tab goes through the hole. That's how you know you have connected it correctly. If you have the tab side of the connector on the other side then it wouldn't work.
Old September 15th, 2011, 09:49 AM   #5
dubojr1
dubojr1's Avatar
I'm almost positive the plug will only plug in one way. You should hear it "click" in once it's together properly. A picture or 2 may be helpful in determining the other possible missing connection.
Old September 15th, 2011, 09:53 AM   #6
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
The tube that's not connected coming from the carbs, does it tee off to both of the carbs? It's probably just the carb vent tube which should be left open and pointed so that it won't let air blow into it while riding.
k-os is offline   Reply With Quote
Old September 15th, 2011, 10:07 PM   #7
jdoucet93
jdoucet93's Avatar
Thats exactly what it is. Thank you.
OK guys, crisis averted! I had pulled a wire loose on the back of the dash. Appreciate all the help!
Replace Fuel Gauge with Fuel Light? Proteus 2008 - 2012 Ninja 250R Tech Talk 8 December 2nd, 2014 08:33 AM
My video on how to fix the fuel sender for your fuel gauge Klint 2008 - 2012 Ninja 250R Tech Talk 1 November 2nd, 2013 09:04 PM
Fuel tank/Fuel gauge issues coolcatjames 2008 - 2012 Ninja 250R Tech Talk 10 August 23rd, 2012 06:25 PM
Fuel Gauge not working THE BIG SITT 2008 - 2012 Ninja 250R Tech Talk 9 October 10th, 2011 04:24 PM
fuel gauge shellneil General Motorcycling Discussion 8 November 1st, 2009 02:26 PM
