September 15th, 2011, 02:32 AM | #1 |
Join Date: Mar 2011 Motorcycle(s): 2000 Ninja 250 Posts: 227
What RPM with full choke?
Mine gets up to 7k, seemed a little bit much to me when I had it on full choke today. It took some work to get started actually..wasn't even sure if I had fuel in the bike it was so rough! But I haven't started her in a week and the temps have been below 40 at night here, so that could have something to do with it.
But yeah, full choke=7k RPM? |
September 15th, 2011, 05:10 AM | #2 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
Doesn't matter how high it *can* get. Just use as much choke as you need. You don't have to run choke all or nothing. When the bike warms up to 4K rpm, turn the choke to half.
Posted via Mobile Device |
September 15th, 2011, 05:39 AM | #3 | |
Join Date: Aug 2011 Motorcycle(s): 2002 Ninja EX250 Posts: 39
sounds like you're flooding it, instead of opening the choke all the way and trying to start it, have the choke fully closed with your hand on it and turn the bike over while gradually increasing the choke, if it fires up at 1/4,1/2... choke leave it, now go ride it. if you have the habbit of full choke, start it, and let it warm up while you check the mail,smoke a cig, put your gear on, etc, idling at 5000k, or in your case 7000k!! you are dumping a bunch of fuel into a cold engine with no oil pressure, which will cause carbon bulid up on the plugs, so i would change the plugs and top her off with fresh gas |
September 15th, 2011, 10:14 AM | #4 |
Fighterer in Training
Join Date: Jul 2011 Motorcycle(s): 2001 Ninja 250R Posts: 316
Yeah, I used to (before I started tweaking the carbs) put it on about half way, which would put the idle between 2k-3k rpms on my baby. I try not to idle it too high when the engine is cold. By the second stop sign, I can usually turn it off, and see if she'll not stall with no choke.
September 28th, 2011, 06:29 AM | #5 |
CBR? This is ninjaaaaaa!!
Idle on mine is 1500k. Full choke is about 3k. I only choke it for about 15 seconds or so. To warm it up, start it with choke. Choke off after about 15 seconds, or you will just be wasting petrol
Then just hold it at about 4k rpm for about 30 seconds. Then it will be fine and idle happily. |
September 28th, 2011, 12:28 PM | #6 |
Join Date: Sep 2011 Motorcycle(s): 06 Ninja ex250 Posts: 16
hrmm. makes me think something is up with mine then.
Full choke gets it to idling around 4k-4.5k. But if i try to decrease it, down to say 2-3k, it dies out. Once its warm, it runs fine with no choke. Also riding with choke on it bogs alot. I have to give significant throttle even with the choke on to get it rolling... disclaimer: i know nothing about engines. (i love to learn though) |
September 28th, 2011, 12:33 PM | #7 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
I dont use the choke unless I have to?
I had to a little today.... I dont think it idled at 7k though...
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
September 29th, 2011, 06:41 AM | #8 |
What is your idle once the bike is warm, with the choke off? You can adjust the idle via a screw on the left of the bike just below the fuel tap if i remember correctly.
Twist left - idle speed down Tiwst right - idle speed up. Tweak it when the engines warmed up. Aim for about 1.5 - 2k rpm. If it cant idle steadily at these rpm, something is wrong. |
September 30th, 2011, 02:34 PM | #9 |
I was told not to let the choke run any faster than 3K. Its always worked good at that speed. I only use the choke to get rid of a little flat spot during acceleration when its cold. As soon as I start moving, I cut the choke completely off.
October 1st, 2011, 08:33 AM | #10 | |
Just cleaned carbs - now stuttering at low RPM, fine at high RPM | Ohio | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 5th, 2014 10:30 PM |
Significantly more power with full choke? | Boogab | 1986 - 2007 Ninja 250R Tech Talk | 5 | March 4th, 2013 02:13 PM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
Bike only runs on full choke!! | UjaasG35 | 2008 - 2012 Ninja 250R Tech Talk | 13 | May 15th, 2012 06:49 PM |
Is full choke on a cold engine bad??? | KawiKid860 | General Motorcycling Discussion | 6 | February 4th, 2012 12:42 PM |
