January 17th, 2012, 09:49 AM | #1 |
Join Date: Jan 2012 Motorcycle(s): 09 ninja 250r Posts: 13
engine surge
I have a 09 with a dynojet, with slip on, snorkel delete, k&n, and run full syn.
and 18000 I have started to notice as I ride I get engine surge on excel and de-excel, I pulled the clutch once to make sure it was not a bent rim or a flat spot in the tire, and I have also started to notice a little more back fire. so I was thinking it could need a valve adjustment or a carb sync could be a vacuum leak to. I would very much like some other opinions. |
January 17th, 2012, 09:54 AM | #2 |
Full synthetic oil and 18,000 miles? You're vague...
How long has it been since you last rode the bike? Do the carbs need to be cleaned? A valve adjustment would be a good idea. They're likely tight, which would cause the bike to be a little less smooth. A carb synch is standard follow up to adjusting the valves. As for testing for leaks, that's not hard; just spray something flammable (WD40 works great) at parts of the intake and listen for if the idle jumps up a lot. If it does, you found a leak. But I would do the valve adjustment and carb synch first. I feel like that's the more likely cause of your surging. Welcome to the forum. Post up in the new members section so we can all say hi |
January 17th, 2012, 10:21 AM | #3 | |
temp, altitude, humidity, main jet size, a lean condition, incorrect fuel air mixture. When was that last time you had the valves adjusted or complete tune up on the bike? Also have you done the kleen air delete mod? |
January 17th, 2012, 10:28 AM | #4 |
like I said I never had the problem before just started slowly happening never had the valves done and I do a full tune up ever 4000 which was last week. and I don't know what a Kleen air delete is.
January 17th, 2012, 10:42 AM | #5 |
You probably should have had the valves inspected/adjusted @ 15K miles.
The Kleen air delete may help with your backfire problem. http://www.ninjette.org/forums/showthread.php?t=9948 |
January 17th, 2012, 04:07 PM | #6 |
Adjust the valves first seeing as they haven't been adjusted and you're at 18,000 miles. If the bike is still giving you issues, then try other things.
Taking off the Kleen system should fix your popping and backfiring. |
January 17th, 2012, 05:17 PM | #7 |
It was infact my chain it has a kink in it. Thx for all the help.
January 17th, 2012, 06:44 PM | #8 |
CBR250R Traitor
Join Date: Jun 2011 Motorcycle(s): 2011 Red CBR250R 2009 Ninja 250r SE(With 2008 Fairings)(sold) Posts: 924
If you're at 18k and haven't checked the valves, you should probably do it anyways.
January 17th, 2012, 07:35 PM | #9 |
January 17th, 2012, 08:10 PM | #10 |
no joy
Join Date: Nov 2009 Motorcycle(s): Ninja 2006 636 Posts: 408
I was thinking chain.. My chain stretched weird and it has a tight spot and can't be properly adjusted... Make sure its not stretched as such.. It will seem to surge..
Posted via Mobile Device |
HJC FS-15 Surge Helmet - size small | phr3ek | Gear-related | 3 | July 13th, 2011 04:12 PM |
rear wheel surge | crazymater91 | 1986 - 2007 Ninja 250R Tech Talk | 8 | April 21st, 2011 08:13 PM |
[topix.net] - Swinton See Surge in Two Bike Biker | Ninjette Newsbot | Motorcycling News | 0 | October 3rd, 2010 10:30 PM |
Small surge a cruising speeds. | kcguy | 1986 - 2007 Ninja 250R Tech Talk | 16 | September 13th, 2009 01:32 PM |
[visordown.com] - Council issue plea over surge in bike deaths | Ninjette Newsbot | Motorcycling News | 0 | November 21st, 2008 02:02 PM |
