March 9th, 2012, 09:34 PM | #1 |
Join Date: Jan 2012 Motorcycle(s): Blue 08 250 - Blue Magic Posts: 162
What Coolant Do You Use?
I took my lower faring off this evening and found the reservoir nearly empty... I am pretty concerned so I am hoping that adding a 50/50 mix will get me taken care of. The manual says "green" coolant. Is there something you guys recommend?? Thanks!
March 9th, 2012, 09:50 PM | #2 |
Join Date: Oct 2011 Motorcycle(s): 2004 Ninja 250F Posts: 308
I don't have any recommendations, but you just reminded me to check mine...
March 9th, 2012, 10:05 PM | #3 |
I used Honda Type II Coolant the last couple times.
March 9th, 2012, 10:10 PM | #4 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
You can use any antifreeze that is compatable with with aluminum engines, usually ethylene glycol. Mix it 50/50 with distilled water unless it is already premixed. If you drain the old collant , be sure to remove trapped air in the cooling system.
March 10th, 2012, 09:10 AM | #5 |
/moved to new-gen tech
March 10th, 2012, 08:17 PM | #6 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
I use Water Wetter...great stuff and has a very high reputation in the racing circuit.
March 11th, 2012, 01:55 AM | #7 |
CMRA Mini Endurance #6
Join Date: Mar 2011 Motorcycle(s): CBR954, CBR600RR, EX250 Posts: 108
Me too...in the race bike, as water with water wetter is the only thing allowed with the group I race with. But be aware, it has minimal antifreeze properties, so if it gets chilly, the bike needs to stay warm - heater, garage, living room, etc.
CMRA #328 Ridesmart.info Instructor |
March 11th, 2012, 09:43 AM | #8 |
Super Noob
hmmm...mind defining "chilly". Here in the South, it barely gets real cold and even so, it's probably for a month or two and I don't recall seeing temperatures below ~20 F...
March 11th, 2012, 10:51 AM | #9 | |
If you have straight water (which is what most race bikes have, though some allow some glycol based solutions), WW also cools much better, but offers almost no freezing protection - i.e., anything below freezing for any length of time can freeze, expand, and damage the block.
March 11th, 2012, 01:04 PM | #10 |
Super Noob
I've it mixed with distilled water...that's all. I can't risk the potential damage though, bruh. I'll start looking for a new brand...perhaps that Honda above with a tad bit of WW as you recommend.
March 11th, 2012, 09:50 PM | #11 |
Is this going to be an issue for a bike that sits in a garage all winter with the garage door occasionally being opened for a few minutes at a time while cars are parked? Or is this only an issue for a bike that is run in winter? I'm looking at switching to coolant that is non ethylene glycol for my track day this summer. Should I use Engine Ice instead of Water Wetter because Engine Ice is "Poly Glycol and is allowed at Mid-Ohio?
March 11th, 2012, 09:58 PM | #12 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
I used engine ice...
Its for dirt bikes generally but i imagine it works the same? lol... hopefully..
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
March 11th, 2012, 10:00 PM | #13 |
Well, lemme know how it goes. your bike is the guinea pig, not mine
March 11th, 2012, 10:07 PM | #14 |
Avid Kitteh Poster
http://www.sportbikes.net/forums/tra...er-wetter.html
these guys use that and water wetter so im not trippin. Sounds like its fine.
March 12th, 2012, 06:02 AM | #15 | |
Mid-O tech is looking for a "color" when checking your coolant. If it's clear your good to go, if it's not clear they "may" want to check more. Green is a guaranteed inquiry about your coolant.
March 12th, 2012, 06:10 AM | #16 |
Why exactly is green coolant not allowed on the track? Does it have lubricative properties when spilled more-so than water (similar to oil catching regulations)? It it an environmental concern?
Also, don't forget that even if your garage is heated, any place you might ride to may not be, so keep that in mind before warming up in a garage and heading out without antifreeze! |
March 12th, 2012, 06:18 AM | #17 |
Lubricative properties, ease of cleanup and environmental issues. The color green is just the most common color of standard antifreeze. Hence they ask if you changed coolant as it is "sight" checked during tech.
March 12th, 2012, 08:22 AM | #18 |
I use Engine Ice or Liquid Performance in the street bike, which stays outside during the winter. Water Wetter with water in the track bikes, they stay in heated areas during the winter.
March 12th, 2012, 03:42 PM | #19 |
L8APEX
Join Date: Nov 2011 Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org! Posts: 233
ENGINE ICE! it's in everything I own....Biodegradable to boot
www.joemillersmoderngarage.com www.starr-cycle.com ***The most important concept of science isn't memorizing facts, it's observation of phenomena.*** |
March 12th, 2012, 03:50 PM | #20 |
Well, now my mind is made up on using Engine Ice when I flush my system and replace coolant
Coolant Cap | Jaife86 | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 22nd, 2014 06:04 AM |
Coolant | SafetyPaws | 2008 - 2012 Ninja 250R Tech Talk | 33 | May 17th, 2013 05:46 AM |
Waterless Coolant? | conrya5 | 1986 - 2007 Ninja 250R Tech Talk | 11 | April 28th, 2013 05:15 PM |
Coolant top up | RAMN | 2008 - 2012 Ninja 250R Tech Talk | 19 | August 17th, 2011 04:26 AM |
Coolant recomendation? | kaiserz | 2008 - 2012 Ninja 250R Tech Talk | 22 | June 29th, 2011 03:25 PM |
