Old March 23rd, 2012, 05:01 AM   #1
haze5736
Motorcycle(s): 98 Ninja 250
Won't idle or stay running
I've been struggling with a non-idling/stalling bike since last fall. I just cleaned the carbs for the 3rd time and adjusted/checked the valves for the second. Every time I end up with the same result.
The bike will start just fine with the choke. And will idle at high rpms for a short time. Once the bike starts to warm up, within a minute, it seems that no combination of choke and idle speed will keep the bike running. If I keep throttling it, I can keep it running. But once I start backing the idle speed off it dies. I'd say about 3k rpm. And trying to add choke at that point does not help. At this point it seems to be running rich. I get some pops from the exhaust and can smell the fuel.
It sure sounds like a carb issue to me but I have no idea what to try next.
I've read as many similar posts as possible and it always seems like a good cleaning resolves the problem.
Please help.
haze5736 is offline   Reply With Quote
Old March 23rd, 2012, 05:19 AM   #2
Sounds like the idle jets are still dirty. What did you do to clean the carbs?
Old March 23rd, 2012, 05:27 AM   #3
dbking321
dbking321's Avatar
Motorcycle(s): 09 ninja 250,93 vulcan 750
take out your pilot jet and hold it up and see if you can see light through it if you cant its plugged and its your problem.
dbking321 is offline   Reply With Quote
Old March 23rd, 2012, 07:55 AM   #4
haze5736
I cleaned the pilot jets with carb cleaner and a piece of copper wire. I can see light through them. I did that for all of the 3 times I had them apart and cleaned. I followed a set of cleaning instructions to the letter and had carb spray coming out of all the right places and flowing well. That's why I'm at a loss. I did not touch the main jets. The instructions I used did not mention taking them out.
Old March 23rd, 2012, 09:20 AM   #5
dbking321
dbking321's Avatar
they just unscrew but that wouldnt be your idle problem. Is your airbox on righti know if theres a gap around the seal of the carb and boot it can cause idle issues
Old March 23rd, 2012, 09:33 AM   #6
jmgrande
YEAH! Custom name tag.
jmgrande's Avatar
Motorcycle(s): 2010 Ninja 250R SE- SOLD to maverick9611
Spark plugs!
Don't touch it. Don't even look at it. Go on, get out, you heard me. Don't look at me either. Yeah, you better walk on. I'll hit an old man in public.
jmgrande is offline   Reply With Quote
Old March 23rd, 2012, 09:40 AM   #7
jmgrande
jmgrande's Avatar
Originally Posted by jmgrande View Post
Spark plugs!
This sounds very similar to the issue I was having with my bike a couple weeks ago. I was planning on cleaning the carbs, but I installed new plugs first and it resolved the issue. It's worth a shot, won't cost you more than $10 and won't take long.
Old March 23rd, 2012, 09:41 AM   #8
jmgrande
jmgrande's Avatar
You may want to drain your gas and put in fresh gas. Shouldn't be an real issue, but just an idea.
Old March 25th, 2012, 08:56 AM   #9
haze5736
5 times a charm
I cleaned the carbs for the 4th time Friday. Still no good. Determined not to be defeated by this bike I cleaned them a 5th time. This time using 2 cans of carb cleaner and blowing out the passages with compressed air after the cleaning. I also changed the spark plugs and drained the fuel tank. Viola, it finally idles. I did notice that there were some remnants of a blue sealer in the idle screw holes that seemed to be coming loose. I got all of that out.
Quite a bit of gunk came out of the fuel tank. I guess by the time I got the fuel filter on last year it was already too late. The funny thing is the inside of the carbs never looked dirty.
Got the carbs synched and she idles like a champ. What a PITA, but seeing as this is my wife's bike, and she's happy now, life is good.
Old March 25th, 2012, 09:19 AM   #10
jmgrande
jmgrande's Avatar
Awesome, I wish you did the plugs first before cleaning it again. You said it yourself, the carbs didn't look that dirty in the first place, so it was unlikely that was the problems.
Glad you got it running, seems my suggestions work Safe riding!
Old March 25th, 2012, 12:49 PM   #11
Nice work.
Won't stay running after warming up skrymir69 1986 - 2007 Ninja 250R Tech Talk 31 May 1st, 2014 07:24 PM
Valve adjustment and now bike won't stay idle har0ld 2008 - 2012 Ninja 250R Tech Talk 13 December 16th, 2012 06:16 PM
Bike won't stay running...HELP!! Pretzel 1986 - 2007 Ninja 250R Tech Talk 7 July 6th, 2012 07:22 PM
bike won't stay running cabeenaz 1986 - 2007 Ninja 250R Tech Talk 42 December 20th, 2011 02:05 PM
Bike won't idle/stay running after carb removal CmichRider 1986 - 2007 Ninja 250R Tech Talk 6 August 11th, 2011 01:26 PM
