Old August 19th, 2021, 11:10 AM   #161
ducatiman
ducatiman's Avatar
on 50cc '86 Honda Spree today....pulled/drained tank and cleaned petcock. I believe first time ever tank drained, mesh filter cleared. While there fresh fuel/Stabil 360 added. I've cleaned carb prior. Starting 1st kick without battery, i blindly left the key on....duh.
Sorry, no pics.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old August 19th, 2021, 01:22 PM   #162
JayVapes
JayVapes's Avatar
Motorcycle(s): Ninja EX250
way to go!!!
RIDE IT UNTIL THE WHEELS FALL OFF, THEN BUY NEW WHEELS
JayVapes is offline   Reply With Quote
Old August 20th, 2021, 06:10 PM   #163
ducatiman
ducatiman's Avatar
Knocked these beauties off today, total split, full refurb, careful setup, the works. My property to be sold, look for a thread in marketplace.
The black powder coated brackets done by none other than our own member @jkv45. Great work, I'd encourage anyone needing powder coating to look him up at Apex Custom Coating 608-444-2202.
Custom Carb Service
Old September 5th, 2021, 05:40 PM   #164
ducatiman
ducatiman's Avatar
a before/after of EX500 carbs done today.
Custom Carb Service
Old September 8th, 2021, 10:52 AM   #165
ducatiman
ducatiman's Avatar
the usual refurb done to these 250's today. Discovered hogged out plot jets (replaced with brand new) and clogged transition ports. All corrected, needless to say.
Custom Carb Service
Old September 23rd, 2021, 01:23 PM   #166
ducatiman
ducatiman's Avatar
more tew fitties completed today
Custom Carb Service
Old September 24th, 2021, 02:52 PM   #167
ducatiman
ducatiman's Avatar
yet another set of too fitties today
Custom Carb Service
Old October 2nd, 2021, 03:36 PM   #168
ducatiman
ducatiman's Avatar
and another completed today
Custom Carb Service
Old October 9th, 2021, 01:46 PM   #169
ducatiman
ducatiman's Avatar
knocked these off for a member today. Received 10:30am.....completed by 4:30, including the petcock.
Custom Carb Service
Old October 30th, 2021, 01:11 PM   #170
ducatiman
ducatiman's Avatar
ditto again today. Encountered huge, though unmarked (for size) main jets. Comparing to a stock 105, metering was visually way too large. As the owner complained of fouling plugs and bikes resisting high RPM running, I do believe this was the problem. Reverted back to all OEM stock jetting, removing needle shims as well.
Custom Carb Service
Old October 31st, 2021, 12:28 PM   #171
ducatiman
ducatiman's Avatar
yet another done today, found 1 clogged pilot jet, drilled/removed EPA caps along with my normal service. I predict these'll run fine.
Custom Carb Service
Old November 15th, 2021, 10:54 AM   #172
ducatiman
ducatiman's Avatar
while awaiting delivery of 2nd needle jet on @Detrailers carbset, I knocked off a full service on these pregens today. Came out nice, should be fine runners.
Custom Carb Service
Old November 15th, 2021, 11:01 AM   #173
Detrailers
Motorcycle(s): '85 750 Turbo E2 - '86 600 Ninja - '82 FT 500 Ascot
Beautiful. 2nd jet will be going out today.
Detrailers is offline   Reply With Quote
Old November 15th, 2021, 11:07 AM   #174
ducatiman
ducatiman's Avatar
^ superb, anxiously awaiting to finalize your carbset
Custom Carb Service
Old November 16th, 2021, 10:40 AM   #175
ducatiman
ducatiman's Avatar
Todays victims...currently wrestling with an exceptionally bitchy 250 carbset. Why oh why must both bowl and top cover screws be overtightened to the point where a dremel is necessary to remove them? Surprise... the bowl gaskets (orings at one time) flatter than pancakes, no wonder screws were so overtightened...leak prevention.
Nice internals, eh? But "carbs are easy".....so says the internet..... meh, I'm well on my way to returning them to as new condition. Stay tuned.
Custom Carb Service
Old November 16th, 2021, 05:41 PM   #176
ducatiman
ducatiman's Avatar
after service
additional problems found (beyond the obvious extensive varnish):
- 1 clogged pilot jet
- needles were incorrectly installed (left and right were juxtaposed, now corrected)
- needle shims removed
Custom Carb Service
Last futzed with by ducatiman; November 16th, 2021 at 08:13 PM.
Old November 24th, 2021, 12:21 PM   #177
ducatiman
ducatiman's Avatar
a set of fi' hunnerts finalized today.
Custom Carb Service
Old November 26th, 2021, 08:33 AM   #178
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
There is absolutely no doubt now...Gorden is the GOD of carburetors !
i am in AWE !!!!
Bob.......
Old November 28th, 2021, 09:36 AM   #179
ducatiman
ducatiman's Avatar
Admittedly, Bob, I've (long ago) reached "benchmarks" within my carb processes through the use of unwavering, standardized, effective methods.
Certain "as received" variations of condition can produce differing visual outcomes, however functionally....each set I do are quite capable of "as new" performance levels.
Even though it remains incumbent on owners to assure valve clearances are sufficient, correct petcock function, (new, fresh) fuel condition, ignition component's performance....sending carbs my way virtually eliminates them from the equation.
Custom Carb Service
Old November 28th, 2021, 09:50 AM   #180
Bob KellyIII
Didn't you make up a bench test setup for the carbs as well ? that must have been quite a feat to do in and of itself ! what does that setup test anyway ?
I bet you can actually see the pilot jet working and then more as the throttle is opened.... that has got to be a cool setup .... what do you have to power it with a shop VAC ???
Bob....
Old November 29th, 2021, 07:52 AM   #181
ducatiman
ducatiman's Avatar
Within my service I utilize a gravity fed wet test for checking/setting fuel levels on various design carb sets. Note board is upside down? Flip it, its setup for EX500 and Ducati/Mikuni. Done during the reassembly process....prior to slide assembly phase.
Custom Carb Service
Old December 17th, 2021, 10:51 AM   #182
ducatiman
ducatiman's Avatar
Holiday time o' the season I'm understandably slow, as in DEAD slow. Enjoying while I can, Jan 1 I anticipate it'll open up again.
Custom Carb Service
Old December 22nd, 2021, 06:17 PM   #183
ducatiman
ducatiman's Avatar
done for a member here today, will be fine runners
Custom Carb Service
Old December 22nd, 2021, 06:49 PM   #184
Snake
Snake's Avatar
Looks like you do Quality work.
Old December 22nd, 2021, 07:12 PM   #185
ducatiman
ducatiman's Avatar
Yes, I'd consider that a fair assessment. Thank you for compliment.
Custom Carb Service
Old January 16th, 2022, 11:45 AM   #186
ducatiman
ducatiman's Avatar
currently on a 250 set today....upon disassembly found both choke plungers frozen in place. Soaking in WD40, to follow with heated ultrasonic treatment.
Pics to follow as I progress.
Edit: choke plungers both removed, though I bent the end of 1. I'll handle a (no charge) replacement as I've got spares. Both currently in ultrasonic.
I'm done for today.
Custom Carb Service
Last futzed with by ducatiman; January 17th, 2022 at 03:42 PM.
Old January 18th, 2022, 11:46 AM   #187
thedrewski86
thedrewski86's Avatar
I think I recognize those...
Don't think, look!
Old January 18th, 2022, 12:56 PM   #188
ducatiman
ducatiman's Avatar
ya absolutely should! how'd we make out with 'em?
Custom Carb Service
Old January 18th, 2022, 02:12 PM   #189
thedrewski86
Starts and runs great. I've made sure the intake boots are seated properly multiple times though, and I still get an inconsistent idle. I don't really care that much as it just fluctuates between 700 and 2000 rpm. It seems to average out to about 1500 though and doesn't die. I'm waiting to get a few more good rides in before I really start to care, honestly running is better than not.
I'll probably have another set for you to go through. My Dad told me he found a spare set I apparently gave him with the bike years ago. I didn't even remember doing that.
Don't think, look!
Old January 18th, 2022, 03:47 PM   #190
ducatiman
ducatiman's Avatar
you may want to (individually) set each pilot screw for highest idle, best response. Do it after a ride, bike fully warmed up.
Custom Carb Service
Old January 18th, 2022, 03:51 PM   #191
ducatiman
ducatiman's Avatar
finished the current set this evening, chokes functioning perfectly, as is everything else on them, confirmed via testing. A couple o' pics.
Custom Carb Service
Last futzed with by ducatiman; January 19th, 2022 at 07:52 AM. Reason: adding photo
Old January 25th, 2022, 02:22 PM   #192
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
Hey ducatiman have seen this before?, this thing got eat up
shspvr is offline   Reply With Quote
Old January 25th, 2022, 02:58 PM   #193
ducatiman
ducatiman's Avatar
yep, vent tube, I believe I should have 1 here.
Custom Carb Service
Old January 25th, 2022, 03:00 PM   #194
shspvr
Got new one coming and fuel one to Thanks for confirming
Old January 31st, 2022, 05:09 PM   #195
ducatiman
ducatiman's Avatar
WAY too cold for carbs here right now, LOL. Done in my warm basement on a pro-quality machine...I'm currently researching and learning proper cleaning methods of fuel injectors using some spares from my Ducati SS800. Ultrasonic, reverse flush and other methods, followed by graduated flow testing, thus confirming results. Rebuild kits, (featuring inlet filter baskets and orings) ordered for 3 family owned Toyotas and the Ducati for further research and "live" testing come warm spring.
Interesting stuff, to say the least.
#comeonspringdammit
Custom Carb Service
Old January 31st, 2022, 09:02 PM   #196
Bob KellyIII
#comeonspringdammit
I could not agree more !!!!
Bob......
Old February 10th, 2022, 02:54 PM   #197
ducatiman
ducatiman's Avatar
knocked off the 1st set of EX500 carbs for '22. New season just beginning to pick up here.
Custom Carb Service
Old February 15th, 2022, 09:53 AM   #198
ducatiman
ducatiman's Avatar
taking full advantage of the carburetor "off season" educating myself in the finer points of cleaning/servicing fuel injectors. A new machine in my possession, I'm experimenting with its cleaning capabilities and features (reverse flow and ultrasonic capabilities).
My first working testbed using 4 Denso injectors removed from my Toyota Matrix 2.4 engine, which I thought was running great.....wow what a difference after an ultrasonic and reverse flow clean and new "kit" install (filter baskets, orings & seals). Smooth verywhere, steady idle, great throttle response. I'll be monitoring fuel consumption going forward.
Next up to be my Ducati SS800 (Weber-Marelli injectors) when warmer weather finally returns.
#comeonspringdammit
Custom Carb Service
Last futzed with by ducatiman; February 15th, 2022 at 12:53 PM.
Old February 16th, 2022, 07:32 PM   #199
ducatiman
ducatiman's Avatar
back on a set of especially nasty 250's today. Overtightened bowl screws needed dremel action to remove, as did all 8 brace screws. Badly discolored brass, clogged jets....yada yada. Completed pics to follow when completed.
Custom Carb Service
Old February 17th, 2022, 12:55 AM   #200
Bob KellyIII
before and after of those would really be nice to see ! LOL
Bob....
[roadracingworld.com] - Yamaha VR46 Master Camp Video: Day Four Was A Special Day For Ninjette Newsbot Motorcycling News 0 May 26th, 2019 10:52 AM
[roadracingworld.com] - â??Racers Edge Performance Hosting Track Day/ Practice Day Ap Ninjette Newsbot Motorcycling News 0 March 25th, 2015 02:20 PM
[kropotkin thinks...] - IMS Press Release: A Day-By-Day Guide To What's On At The Red Ninjette Newsbot Motorcycling News 0 August 5th, 2014 09:30 AM
[motorcycledaily.com] - Max Biaggi Finishes First Day of Two-Day Ducati MotoGP Test ( Ninjette Newsbot Motorcycling News 0 June 6th, 2013 05:10 PM
[kropotkin thinks...] - Shots In The Dark, Day 4: Scott Jones, Race Day Ninjette Newsbot Motorcycling News 0 April 9th, 2013 03:50 AM
