Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 General Discussion
Old June 2nd, 2019, 05:12 PM   #1
jbluetooth
Motorcycle(s): Kawasaki Ninja 400, Yamaha R3
New Article: Power Commander PCV vs. Bazzaz Z-Fi vs. ECU Flash vs. aRacer Race ECU
Rewriting some articles, and here's the updated article on tuning systems. This was originally based on the Yamaha R3 but the same systems and principles apply to the 400. I'll be starting my Ninja 400 tuning project probably next week and will be thoroughly testing the Bazzaz/PCV, my own ECU flash, the full Woolich system, as well as aRacer Super RC2 race ECU. Hope this answers some questions:
https://www.norton-motorsports.com/2019/05/power-commander-pcv-vs-bazzaz-z-fi-vs-ecu-flash-vs-aracer-race-ecu/
Cheers, Jesse
Follow my build and racing at Norton-Motorsports.com
jbluetooth is offline   Reply With Quote
Old June 9th, 2019, 07:46 PM   #2
What software are you using to flash ECU?
Old June 10th, 2019, 10:17 AM   #3
Topaz
Topaz's Avatar
Interesting, the article says that the ECU keeps changing the mapping according to some parameters, so any custom tune on a piggy bag system will not be the same as soon as you ride out of the shop.
Old June 10th, 2019, 06:39 PM   #4
That's fuel-trims causing shift. ECU has pre-programmed maps and target AFR. Using a piggyback to "fool" the ECU by modifying MAP/TPS values tricks it into injecting more or less fuel only temporarily. That's because ECU will analyse O2-sensor feedback to see how mixture is burning. If measured AFR doesn't match what's programmed, ECU will adjust injector duty cycle up or down until it does match.
So it's best to re-program the actual ECU maps themselves.
Old June 10th, 2019, 08:09 PM   #5
jbluetooth
It's not just fuel trim. There are timing maps that also change ignition timing based on temperature or other parameters. Super annoying, and terrible for getting a consistent "good tune"
Cheers, Jesse
aRacer - RC2 Complete ECU - Update Cabecinhas 2008 - 2012 Ninja 250R Tech Talk 15 June 12th, 2015 10:33 PM
40hp from a ECU flash - Yes please garth285 General Motorcycling Discussion 10 May 10th, 2015 07:58 PM
Power Commander PCV $220 Rekognize Motorcycle-related 4 September 21st, 2013 11:42 AM
