Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 General Discussion
Old November 19th, 2019, 11:04 AM   #1
Ninja 400 intake and exhaust mods with dyno results
This was posted elsewhere, but thought it should be in here as well (I didn't see it anywhere in the 400 section) -
https://www.norton-motorsports.com/2...dyno-shootout/
Some pretty extensive testing, thanks to Norton Motorsports.
Old November 19th, 2019, 11:28 AM   #2
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
there's really nothing posted in the 400 forum. funny how it started as a 250 forum, had a decent amount of members with 300's when they came out, and maybe three 400 owners here. i have always liked this forum, too bad its slowed down so much. when i joined it was moving along at a pretty good clip.
gantt is offline   Reply With Quote
Old November 19th, 2019, 11:58 AM   #3
I probably should have put this is the 400 Tech Talk section.
Maybe mods can move it.
Old November 19th, 2019, 05:26 PM   #4
Snake
Snake's Avatar
Thanks for the link.
Old November 19th, 2019, 07:13 PM   #5
Zaph42
Zaph42's Avatar
Funny how all the 400 dyno charts I've seen have a flat top end. My old race 300 gained right up to the redline. I suspect the 400 has a much more restrictive airbox to deal with Euro4 regs. And those racing supersport rules are stuck with it. The bike is choking. Damn the bike could really see gains with pod filters.
My buddy who bought my old 300 is now building a 400. I hope he's not disappointed with the dyno results.
Old November 19th, 2019, 09:59 PM   #6
Most likely milder cam-specs. Easier to pass emissions that way. Also hefty low-end torque compared to 300 and 20-lbs lighter too!
Old November 20th, 2019, 07:12 AM   #7
JFMNINJA400
JFMNINJA400's Avatar
Motorcycle(s): GSXR 750, GSXR 600, Ninja 400, Ninja 300
Yes Norton suggests cutting the air box and removing the snorkels with their velocity stacks.
File Type: jpg D5234D04-515B-4634-8916-735E62B7AAD0.jpg (135.3 KB, 6 views)
JFMNINJA400 is offline   Reply With Quote
Old November 23rd, 2019, 06:40 AM   #8
Zaph42
Zaph42's Avatar
Yeah, supersport racing classes aren't allowed to modify the airbox. Maybe that's a good thing for the 400... to choke it off and let other older bikes still be a little competitive with it.
I hated the 400 when it came out, just messing up all the race classes. I was getting pissed off that the makers can't standardize on a class like 600 and 1000. But outside of that there's no denying that it's a nice bike.
Old November 26th, 2019, 05:07 PM   #9
BretSV
Motorcycle(s): Shopping
Wonder what just the snorkels hp gain is
BretSV is offline   Reply With Quote
Old December 28th, 2019, 11:06 AM   #10
jbluetooth
Motorcycle(s): Kawasaki Ninja 400, Yamaha R3
Changing the velocity stacks for ours completely wakes up the top end, even if you don't cut up the airbox. But cutting up the airbox and removing the snorkels just gives it the last little bit to maximize the gains from our velocit stacks.
Cheers, Jesse
Follow my build and racing at Norton-Motorsports.com
jbluetooth is offline   Reply With Quote
Old December 29th, 2019, 10:48 AM   #11
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
For the Norton motor sports guy. Try my Dual stack idea. Basically make the primary stack as short as possible whilst maintaining a smooth intake radius with the correct taper. Then add a secondary velocity stack mounted in line with the primary one, where the base of the secondary is inline with the top of the primary. Make the secondary as long as reasonably possible, with a proper full curved top.
The short primary gives the best high RPM flow & the secondary catches most of the pulse wave from the short stack at lower rpms & reflects it back as if from a longer stack as well as straightening the air flow.
I can send a diagram/picture of the setup I have on my 800. Be worth it to see if it improves airflow throughout the rpm range !
Ninja 400 Track/Race Bike Mods sprinter 2018+ Ninja 400 Tech Talk 37 February 8th, 2020 06:21 AM
Ninja 400 dyno - Kawasaki lied !!! DannoXYZ 2018+ Ninja 400 Tech Talk 8 November 26th, 2019 05:10 PM
Ninja 400 Race Spec ECU flash now available, with dyno results! jbluetooth 2018+ Ninja 400 General Discussion 1 August 12th, 2019 10:16 PM
Ninja 300 Dyno Exhaust Test Results skagit Ninjettes At Speed 5 July 12th, 2013 01:01 PM
Jetting/intake mods - consolidated advice? adouglas 2008 - 2012 Ninja 250R Tech Talk 6 April 20th, 2010 08:36 AM
