April 11th, 2013, 10:04 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): '08 Ninja 250R Posts: 15
Lower a 250?
I'm 5'2 and I need to lower my 250r just a few inches. Are lowering links enough or do I have to purchase an entire lowering kit? Any advice would be appreciated
April 11th, 2013, 10:31 PM | #2 |
Join Date: Apr 2013 Motorcycle(s): 2013 Kawi Ninja 300 Posts: 109
Hello and Welcome!
We seem to be the same height. My approach was to purchase the Roaring Toyz lowering kit minus the kick stand. I was able to drop it two inches in back and about 1.5 in front. To bring me a tad bit lower to the ground, I shaved down the stock seat which approximately gave me an additional 0.5 inches. As everyone else would tell you, two inches is about the most you want to drop it. And if you drop the rear, you want to drop the front too. You might also want to adjust your spring load on the rear to keep the rear tire from rubbing. |
April 12th, 2013, 05:08 AM | #3 |
Boots with thick soles can give you a bit of height as well. Just might save you from shaving the seat.
April 12th, 2013, 05:41 AM | #4 |
April 12th, 2013, 06:05 AM | #5 |
Height makes no difference once you're moving, learn how to bring it to a stop & take off again properly & it should save you having to lower the bike.
Pick a clean bit of road to put your foot down on, brake with the front & rear until you're going a couple of mph then use the rear brake to come to a stop As you stop flick the bars right & put your left foot down, flicking the bars right will cause the bike to fall left. *point the bars straight again prior to takeoff* On takeoff the bike will right itself. I'm 5'7 and have no problems with my mate's F650GS, it's seat is 4" higher than my inseam. Last futzed with by Whiskey; April 15th, 2013 at 05:15 PM. Reason: *idiot proofing* |
April 12th, 2013, 06:18 AM | #6 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Shorts?!
And welcome! |
April 12th, 2013, 06:22 AM | #7 |
i think the bike shouldn't be lowered more than an inch.
then get better boots and shave the seat if need be. as you get used to the balance of the bike, whiskey's technique will help you handle taller bikes.
April 13th, 2013, 11:17 AM | #8 |
Join Date: Jan 2011 Motorcycle(s): (08 Ninja 250) (07 Suzuki Hayabusa) (08 Suzuki GSXR 1000) (Yamaha dirtbikes) Posts: 33
I put on the roaring toyz lowering kit for my wifes bike. It made a world of difference for her and boosted her confidence. I rode that bike hard and did not notice any ill effects of it being lowered. I was lowered fully in the front and the rear was in the middle setting I think. Its a nice kit and easy to install. I did not shorten the kick stand, and it was not a problem as long as the rider was carefull about parking it on uneaven ground. Getting a shorter stand cant hurt, but you can easily get away with the stock stand after lowering fully.
Actually I am about to post the kit for sale in the classifieds. Hope its ok to post that. |
April 13th, 2013, 11:46 AM | #9 |
I've been told that you don't need a lowering kit if you're comfortable riding, but the only thing is I'm still in the learning process, so I don't want to lay the bike down and cause damage because I can't flat foot. It has been suggested that I put the lowering kit on while I learn and then remove it after so I don't miss out on handling or being able to ride a bigger bike later. Is it worth spending the $200+ on a kit just to learn?
April 13th, 2013, 12:15 PM | #10 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
you have a higher chance of laying it down during a corner from your pegs scraping and getting scared so easily as the bike has been lowered. Ive seen it happen. Ive also seen the same person drop it coming to a stop on a hill / slanted street which cause absolutely no damage once so ever.
do not lower it in my opinion |
April 13th, 2013, 12:39 PM | #11 | |
Lowering doesnt have the negative effects some people will warn you about in real world street riding. Truth is there are alot of lowered ninja's riding around out there and they are just fine. I am a very expeirenced rider with many tens of thousands of miles under my ass, and many, many bikes bought, ridden, and sold. The Ninja 250R was my wifes and was lowered for her. I still rode the bike, and rode it hard at times. I felt NO ill effects that effected my ability to ride that bike. Neither did my wife. She immedietley had more controll over the bike and gained confidence with it lowered. Everyone has their opinions, but unless you have ridden a 250R with a lowering kit installed your opinions dont mean alot. If you are considering getting lowering kit becuase you want more confidence and controll or you are short and have no other option then go for it. |
April 13th, 2013, 01:22 PM | #12 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Whiskey had it right. I grew up on dirtbikes and was never able to flat foot anything. It was tippy toe on one side. Seat height isn't that big of an issue IMO. All it matters is in stopping and starting.
April 13th, 2013, 01:26 PM | #13 |
Lays er down
April 13th, 2013, 02:18 PM | #14 | |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
If I could flat foot my dirtbike, it was time to upgrade :P |
April 13th, 2013, 03:20 PM | #15 | |
Not to mention the threads that pop up from time to time "what do I do about this hole in my rear fender since the tire hit it when the bike was lowered?" Everything in moderation, right? An inch or two at most, on a bike that is ridden gently by a new rider, and there might be limited ill effects.
April 13th, 2013, 03:44 PM | #16 |
Join Date: Dec 2012 Motorcycle(s): 2008 Ninja 250R Posts: 263
April 13th, 2013, 08:04 PM | #17 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
I'm 5'1" (on a good hair day, haha). I have the roaring toyz lowering links on the back and the blocks on the front.
I started with the links at the lowest setting until i was confident and comfortable enough to try it higher. I did have rear tire rubbing on the lowest and 2nd to lowest setting. I now have it on the mid hole on the links and don't have any rubbing issue. Make sure you put the front blocks on to keep the bike level thought! I didn't at 1st and had handling issues. Hope this helps!! Good luck and be safe! |
April 14th, 2013, 04:55 AM | #18 |
Get someone to hold the bike while you try to flat foot it using your left foot.
Step on the rear brake to hold the bike still. Shave the seat and get thicker boots. That'll get you close to 2 inches. Only lower it as a last resort, if you cant apply the rear brake.
April 15th, 2013, 08:27 AM | #19 |
Join Date: Apr 2013 Motorcycle(s): 2011 Ninja 250r SE Posts: 61
My wife is only 5'0 95lbs and we lowered hers today 1.5" and it wasn't too difficult. Never worked on a bike so it took longer than expected but I am 6'0 and I weight bout 175 and I sat on it bounced up and down on it and the tire had plenty of back clearance. Didnt come close to touching the tire. Can't imagine if I weigh that much more than her she shouldnt be able to make it touch either. :P She can nearly flat foot and is very happy with it. I say go for it if your up to the task. Take any precautions to insure it won't touch :P
April 18th, 2013, 12:47 AM | #20 |
Join Date: Jul 2012 Motorcycle(s): 2012 Ninja 250r Posts: 33
I'm 5'4" and even I was contemplating lowering the bike, I can only imagine losing two more inches! I decided not to, but I have to be honest, there are times where my footing as slipped because I'm on my tippy toes. It makes sticky situations that much more difficult. The first time I was on a steep slope o got really scared but I was fine.
Half of it is mental I think, it can certainly be done without lowering but you have to conquer that in your mind. And run through what you would do if the bike started to tip. I've pulled out my back catching it once in my driveway, but it didn't drop. I think another problem for me is that I'm not very strong, so while guys think holding the bike up on one foot is fine, it's a lot harder for me to recover because I don't have too much strength to stop the bike from falling. Anyway, I think if the height difference is holding you back from being comfortable and really learning how to ride, and making it scary, then yes you should lower it. |
April 18th, 2013, 04:51 AM | #21 |
if both strength and height is an issue, might be a good idea to start off on another bike.
April 18th, 2013, 08:19 AM | #22 |
So....
I tried my bike for the first time (waiting for the snow to melt) and it turns out that I feel perfectly comfortable while riding and when stopped I'm steady enough holding it and can easily flat foot while holding the back brake. If it doesn't make me nervous, do I really need to lower it? |
April 18th, 2013, 09:52 AM | #23 |
No.
April 18th, 2013, 06:50 PM | #24 |
I have a buddy who's about 5'5". He rides an F4i. He can barely touch both of his feet at once, much less flat-foot it. He's also of the opinion of, "hell no I'm not lowering it, I like turning!"
To each their own. I think if you lower the bike, consider raising it back up to stock after some time. That way, you'll get good opportunity to get riding experience without fearing stops, but in the end, you'll still appreciate why a sport bike is as high as it is. |
April 18th, 2013, 08:04 PM | #25 | |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
Once you get used to standing it up on your left leg, your good. 6months later i wouldn't even think of lowering my bike, so i'd say your fine. Put some sliders on maybe? they'd definitely protect your bike in a tip over situation.
It doesn't LOOK that steep. But you can go first... |
April 18th, 2013, 08:39 PM | #26 | |
it'll become natural as you ride more often. also i find stopping like that gives you an advantage in hilly areas.
April 20th, 2013, 01:13 PM | #27 |
If your comfortable then I'd say no as well. I wish my wife didnt want to lower hers but she wouldn't even try to walk the bike because she couldn't flat foot it.
April 26th, 2013, 08:46 PM | #28 |
Join Date: Oct 2012 Motorcycle(s): 2008 Kawasaki Ninja 250r, 2009 Suzuki GSX-R750 Posts: 85
My wifes ninja is currently lowered about 2iches front and back. Shes 5'0" 110lbs with a 26inseam. At first I disagreed with lowering it but then I started to realize that from a performance stand point it doesn't matter because all she is doing is just learning. Do what you have to do to establish that foundation then slowly go from there.
When I ride her bike it scrapes the cat on bumps if you go just a little bit too fast. If you go too fast on corners and have to lean then it'll scrape the pegs. But as a beginner these won't be of any concerns to you. Right now, I got her the heartbreaker boots to help increase her height 2 more inches so I can hopefully raise it back up. She wants to ride my GSX-R750 one day.. hahaha. She still tippy toes after we lowered it so she still struggles but with positive support and encourage she'll get comfortable with using one foot. |
