May 15th, 2011, 03:31 PM | #1 |
ladyrocket
Join Date: Dec 2010 Motorcycle(s): 09 Ninja 250R Posts: 84
Relocation of The Rear Brake Reservoir (Pics)
Hey guys!
So I previously took out the stock airbox and decided to put the brake reservoir in the newly created space. Took out the battery and battery box, then drilled a 1" hole through the...plastic....mud guard....thingy, placed a 5/8 I.D rubber grommet, bought a L bracket, screws and nylock nuts. Then attached the L bracket to the battery box, mounted the reservoir, and cut about an inch and a half off the brake line, attached it, bled the brakes, then removed the stock reservoir bracket with a dremel tool, sanded, painted and ALL WAS GOOD Here are some pics of my bike after moving the rear brake reservoir, enjoy DSCN5364.jpg DSCN5369.jpg DSCN5365.jpg DSCN5370.jpg DSCN5371.jpg
Never ride faster than your angel can fly |
May 15th, 2011, 03:41 PM | #2 |
/moved to new-gen tech
May 15th, 2011, 04:27 PM | #4 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
very nice!
by the way, if that's your garage..........i'm jelous. |
May 15th, 2011, 06:30 PM | #6 |
Great mod.
May 16th, 2011, 08:54 AM | #7 |
DUCEATR
Nicely done It really cleans up the back of the bike. It's always cool to see someone who takes the time to make a mod that looks like it came from the factory with great fit and finish.
May 16th, 2011, 09:53 AM | #8 |
What kind of abuse does the reservoir hose go thru during suspension compression???
I may have to copy this mod. Limits my room for the cruise control I wanted to add though.
May 16th, 2011, 04:36 PM | #10 |
ladyrocket
The reservoir & hose are both attached to the frame, so neither moves as the suspension/swing arm moves up/down..
May 16th, 2011, 07:16 PM | #11 |
self wrencher
Nice mod. You remOved the airbox yourself? Impressive.
May 16th, 2011, 08:48 PM | #12 |
sleeper
Join Date: Nov 2010 Motorcycle(s): '10 250r, '10 690 duke Posts: 558
this is awesome..i will do this eventually!! nice DIY
May 16th, 2011, 09:41 PM | #13 |
Good job.
another thread on the same subject... http://www.ninjette.org/forums/showthread.php?t=10096 |
Rear brake reservoir bent? | joecool | 2013 - 2017 Ninja 300 Tech Talk | 16 | October 20th, 2014 08:55 PM |
DIY - Relocating the rear brake reservoir | VeX | 2008 - 2012 Ninja 250R Tech Talk | 12 | December 3rd, 2008 11:13 PM |
