March 8th, 2011, 09:03 AM | #41 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150 Posts: 223
If you can't find Dupont Teflon locally, you can get it(multi purpose or chain lube) from Amazon.com for about $12 shipped in the U.S.
I get mine from Lowe's.. Last futzed with by Ichiro; March 20th, 2011 at 10:21 AM. |
March 9th, 2011, 08:13 AM | #42 |
Join Date: Dec 2010 Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125 Posts: 812
March 19th, 2011, 09:43 PM | #43 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
I've used both the Maxima Chain Wax and Castrol Chain Wax. It's whatever is on sale at the local Cycle Gear whenever I go in and pick stuff up.
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
June 7th, 2011, 08:49 PM | #44 |
Join Date: May 2011 Motorcycle(s): 2010 Red Ninja 250r Posts: 69
Best Chain Lube?
Hey guys. Just bought my bike stands to be able to work on my own bike and looking for the best chain lube to buy/use. What do you guys recommend?
June 8th, 2011, 02:15 PM | #45 |
Opinionated individual :)
Join Date: May 2011 Motorcycle(s): 2010 Ninjette Special Edition (red/black) Posts: 342
So if I'm correct every 300-500 miles you should use a cleaner such as WD-40 with a rag to wipe down and clean your chain and then use Teflon spray to lube it?
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete 2010 SE 250R! Miles in the saddle: 1000 |
June 8th, 2011, 02:19 PM | #46 |
yes, clean and lube chain every 400 miles... check adjustment every 600.
http://www.ninjette.org/forums/showthread.php?t=10577 |
June 8th, 2011, 02:22 PM | #47 |
That's not the only option, but that would certainly work fine.
(edit: my response was to secret ninja man, not kkim. but i fully agree with kkim's advice as well)
June 8th, 2011, 02:26 PM | #48 |
Thanks, Kkim and Alex you guys are on top of it.
June 8th, 2011, 02:42 PM | #49 |
Maxima Chain Wax vs. DuPont Teflon Multi-use Dry Wax Lubricant
So I decided a while back that the next time I cleaned the chain I would use a different lube. DuPont is known for making good products so when they get good reviews it must be good. The first thing about the DuPont lube is that it's a multi use spray, not a motorcycle specific lube, however this same stuff also comes in a can with the label for motorcycles. Later for that one. The label says that it is a patented blend of "wax based lubricant",goes on wet to penetrate and then to dries leaving a lubricating film. DuPont also claims that it will not attract dirt and grime or fling. Maxima Chain Wax also makes the same claim as not to attract dirt and grime or fling.
Both claim to be resistant to water. Before I applied it, I shook the can well (there's a rattle ball inside). It did not have a strong smell like the Maxima Chain Wax, came out the can quick and it was runny, however it dried quickly. It did leave a waxy feel on the chain, unlike the slightly tacky feel from the Maxima Chain Wax. While the Maxima Chain Wax leaves a slight yellowish brown coat on the chain, the DuPont is almost invisible. Now is where the difference between the two comes in to play for me. If you look at my bike you might say I'm borderline OCD. However I just like my Ninja to be clean. People used to ask me, "why do you keep your cars so clean?, you're always wiping on them." My response would be, "God has blessed me with this car and the means to have one, the least I can do is keep it clean so when he looks down he can see himself in it." Anyway.....back to the lube... After a few minutes, I notice white dots, residue and overspray everywhere, despite the fact that I used a barrier for that very purpose. Not something I was looking for. So I did a little comparison test to see the difference in adhesion between the two. One short spray of the DuPont saturated the piece of paper I sprayed it on and immediately began to run. The Maxima even after a few sprays barely moved. I should also mention that as long as I been using Maxima Chain Wax, I've had little overspray flaking or fling. So here is how they stack up so far. DuPont Teflon Multi-use Dry Wax Lubricant- $5.97 for a 11 oz. can Maxima Chain Wax- $4.95 for a 5.5 oz. can DuPont Teflon Multi-use Dry Wax Lubricant- Semi clear, runny and wet to dry application Maxima Chain Wax- slight yellow, wet to slightly tacky application. Both are easy to clean After some miles on this application of DuPont Teflon Multi-use Dry Wax Lubricant, I'll see how it holds up to Maxima. Until then I got a few squeaky door hinges. I think I know which one I will use. |
June 8th, 2011, 02:59 PM | #50 |
I believe the "runny-ness" of the du pont is so that is can penetrate the chain and get into all the small nooks and crannies.
Also, did you let it dry before riding and also did you notice any fling off? great write up, I think ill be looking for the Teflon Chain Saver.
June 8th, 2011, 03:00 PM | #51 |
Blue,
Like you, I was very skeptical when this came on the market and was a Maxima Chain Wax convert for many years prior. Now I stock up on the Dupont stuff whenever I run across it at a store. Seems a hit or miss thing if they have it on the shelves, over here. Hope your testing results favorably for the Dupont stuff on your chain, but if not, I've used it in the house on sliding door rails and wheels and the doors opened great after spraying them w/ the Dupont. It's been over a year now and the door is still very easy to open. Good stuff to keep around the house, even if you decide not to use it on your chain. |
June 8th, 2011, 03:47 PM | #52 |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
No one uses the bel-ray wax? I saw it had good reviews so i picked that up, it leaves the white residue. Ive only cleaned and lubed the chain once so far, so i cant really say much.
June 8th, 2011, 04:28 PM | #53 | |
June 8th, 2011, 06:01 PM | #54 |
Awesome, due to lack of availability I had to pick up the Maxima Chain Wax.
Really wanted the Du-Pont Chain Saver Ill let you guys know how it works out.
June 11th, 2011, 07:06 AM | #55 |
Join Date: Aug 2010 Motorcycle(s): 1981 Honda Cx500 Custom, 2002 Ninja 250 Posts: 289
I just spray it every now and then. Probably average about every 4 to 500 miles. No rust at all. I am OCD about my rides and my maintenance. Chains and sprockets are not that expensive anyway. But, fact of the matter is I expect to get just as many miles as a waxed chain.
"Rudeness is a weak persons attempt at strength." |
June 11th, 2011, 08:10 AM | #56 | |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
1. The lube in WD-40 doesn't work for this application. WD-40 is only 15% lube, and the type of lube in WD-40, light mineral oil, is meant for light duty only. It works fine on hinges, etc., but it is highly viscous and lacks the compression strength to work to provide protection in heavy duty work between a sprocket and a chain. Because it is highly viscous it won't stay on at high speed either. You won't have any lube left on after even a few miles, let alone 400. Purpose built chain lubes are specifically engineered for the job they do, they are thicker and have more compression strength so they stay on better and provide a better barrier between chain and sprocket. 2. The solvent in WD-40 is going to hurt your sprocket long term. WD-40 is 50% solvent. Solvent takes stuff off chains, including lube. WD-40 makes a good cleaner, but what you are doing by using WD-40 as a lube is actually taking stuff off the chain. This makes your chain look nice - its probably super clean. But you are essetially ensuring that you will have a metal on metal contact - this is going to wear your sprocket faster in the long term. And while this is better than running a dirty chain, it is worse than running a clean, lubed chain. Go ahead and keep using WD-40 to clean, just add one more step -- add some real lube afterward, too. 3. The solvent will also hurt your chain long term. WD-40 will, on long term exposure, eat the o-rings in your chain. This makes sense as it is 1/2 solvent, and mineral oil itself tends to disolve things, too. In one study, WD-40 decreased o-ring strength by 20% on just 15 days of exposure. Use it to clean if you have to (but kerosene is better), but don't repeatedly apply and leave it on your chain. I've attached the study results below, along with a picture of the o-rings in your chain. 4. Real chain lube is cheaper than WD-40. A can of actual, engineered for the actual purpose you want to use it for, chain lube or wax is about the same price as WD-40, give or take a buck or two. Why would you use something that isn't made for chains, and for which there is some good evidence may be harmful to your bike, when it isn't saving you money? Cost of 13.5 oz. can of Maxima Chain Wax at Rocky Mountain ATV = $6.99. Cost of 12 oz. can of WD-40 at Amazon.com = $7.75. Add in the cost of reduced life on your sprocket and chain, and the cost savings of using wax/lube are even better.
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
July 6th, 2011, 03:38 PM | #57 |
PJ1 Chain Lube. For decades. Black for non-o/x ring. Blue for o/x-ring.
July 7th, 2011, 10:54 PM | #58 |
ratlab
Join Date: May 2011 Motorcycle(s): gsxr1000,R3x2,RC390,FZ07,XR100 Posts: 132
PJ1 blue label as well-it doesn,t fling off if you let it dry-what is that white crap the dealers put on-i have to clean my chain every i get my bike back from a service
July 8th, 2011, 04:50 AM | #59 | |
July 8th, 2011, 05:36 AM | #60 |
Norwegian dude
Join Date: Aug 2010 Motorcycle(s): Ducati 748 Posts: 120
Used Mobil chain spray, which utterly sucked.. everything was just flinged off onto the rear wheel. Then i got several recommendations for Royal Purple Max-Chain, which seems really awesome! Lubricates well, dries fast to a sort of protective film, and keeps dirt away. Will definitely buy again
July 8th, 2011, 08:46 AM | #61 |
Anyone try the new Spectro Z chain lube? I used their foaming green one in the 80's on dirtbikes, but like the maxima wax these days.
August 11th, 2011, 04:38 PM | #62 |
MOTM - Feb '12
Just been reading up a bit more on the Dupont Multi Use and learned that Dupont has now made its Teflon "Chain-Saver" (previously only available to industry and not public) widely available. A few bucks a can more expensive than the multi-use, but they say it will last longer, that they developed it specifically for motorcycles in response to less than ideal use of Multi Use. Dupont recommends the Chain-Saver now for motorcycles.
Here is a nice write-up on it from webbikeworld. Essentially, if Dupont felt like they needed a speciality product that lasted longer and admit potential need to reapply the multiuse after 70 miles, I think I'm going to move to the new, motorcycle specific, product. And here is a video comparing the old and new formulations:
August 12th, 2011, 04:52 AM | #63 |
Let me first say that I don't have any experience using either of these Dupont lubes but the "new" formula looks like it defeats one of the quality's most people like about the Multi-use. The thicker Chain Saver formulation looks to me like it would be a good candidate for excessive sling and dirt attraction. Even though if may be an excellent chain lube... To me it would not be a good choice for an overall quality product.
August 12th, 2011, 06:10 AM | #64 |
time for a new can of maxima wax as mine just went empty
May 29th, 2012, 08:28 PM | #65 |
Join Date: Apr 2012 Motorcycle(s): 2011 Black Ninja 250 Posts: 7
Recommend chain lube brand?
Hey what brand of chain lube do you guys recommend? Also how often should I ve lubing thechain?
Thanks to all who reply |
May 29th, 2012, 08:45 PM | #66 |
Join Date: Apr 2012 Motorcycle(s): Ninja 250, 87 & 99 Concours, Buell 1125CR Posts: 34
I use PJ1, and lube up every 500 miles.
Bumpty,bumpty, bump |
May 29th, 2012, 08:52 PM | #67 |
40 on the road
Join Date: Oct 2010 Motorcycle(s): 2008 Ninja 250, 2012 Ninja 650, 2006 Bonneville, 1990 Sportster Posts: 67
DuPont Teflon Multi-Purpose Lubricant is a favorite.
Every 600 miles or more often if... Learn to use the wiki. Download an owner's manual if you don't have one. Read it. Consider purchasing a maintenance manual. Read it even if you never perform your own maintenance. You'll enjoy it and be better iinformed. Read Zen and the Art of Motorcycle Maintenance by Robert Pursig. You'll be better for it. Ride and enjoy. |
May 29th, 2012, 08:59 PM | #68 |
Join Date: May 2011 Motorcycle(s): 2005 Yamaha FZ6 Posts: 169
Having used PJ1 and other chain lubes in the past, I can honestly say they are all crap compared to Bel Ray Super Clean chain lube. It is just so much better than any other chain lube I've ever used. It doesn't fling off at all, makes the chain much quieter and the ride smoother, and lasts a good 500 miles before the chain even starts to look dirty. I highly recommend it.
May 29th, 2012, 09:10 PM | #69 |
Join Date: Apr 2011 Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold) Posts: 479
I use Maxima chain wax every 400 miles.
May 29th, 2012, 09:59 PM | #70 |
ninjette.org newbie 2,000
Join Date: Jan 2011 Motorcycle(s): Ninja 250r Posts: 160
Maxima.
It's the only one I've tried. |
May 29th, 2012, 10:51 PM | #71 |
Jigglin' your Jiglets
MOTM - Apr '13
May 30th, 2012, 10:47 PM | #72 |
+1 more for PJ1 Blue label every 5-600mi. Tried the Black label @ the track, did not like. It is kinda tacky though and definitely picks up dirt, but I give the chain a deep-clean every few months with kerosene, so it doesn't get bad.
Smells like dumpster offal though, so don't inhale Edit: after reading the rest of the merged thread, I'm considering switching, perhaps back to Royal Purple Max-Chain (if I can find it) or to BelRay
Proud member of the Blue Army Last futzed with by Momaru; May 31st, 2012 at 07:42 AM. |
May 31st, 2012, 04:26 AM | #73 |
/merged
Some updated information on Dupont's Teflon chain lube in this thread: http://www.ninjette.org/forums/showthread.php?t=104972
June 2nd, 2012, 07:23 PM | #74 | |
June 2nd, 2012, 09:21 PM | #75 |
Join Date: May 2012 Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission) Posts: 482
i use Motul chain cleaner to clean my chain and then i use the motul factory line chain lube. I love it because it gives it the nice factory look and its white, so you can see if you miss any spot. I usually just let it sit over night.. works great.
did i get the right chain lube? | RogerPapaMike | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 5th, 2014 08:44 AM |
Chain lube! | corksil | General Motorcycling Discussion | 27 | June 20th, 2014 06:27 PM |
Chain Lube | OzzyDevil | General Motorcycling Discussion | 3 | April 21st, 2012 07:41 AM |
Chain Lube | BobsPT | 1986 - 2007 Ninja 250R Tech Talk | 28 | October 17th, 2010 08:49 AM |
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review | Ninjette Newsbot | Motorcycling News | 0 | May 18th, 2009 09:50 PM |
