Old August 19th, 2015, 11:10 AM   #841
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Originally Posted by M42 View Post
Oh! I remembered now what I wanted to ask. When do you shift off the seat? I saw a lot of other riders doing it while braking and before turn-in, but when I tried it, I lost all ability to grip the tank with my knees and all my weight went into my arms. What do you guys do?
Ben said it well.
Here's what I do (and this is pretty recent... I'd been sitting too close to the tank)
1) Slide back in the seat. Looks like you're already doing this. You should have at least a fist distance between crotch and tank.
2) Move your butt off to one side and lock your outside thigh, close to the knee, against the rear corner of of the tank.
3) Keep your inside leg against the tank. Squeeze with your knees and get your upper body down. That will help with the forces. As Ben noted, you'll be a bit twisted.
4) Before you tip-in, rotate your inside leg out away from the bike. Point your toe... heel up, and against the guard. That will help you get your knee farther out.
4) Relax your arms... this is an ongoing issue for me. I have to think about it. When I remember to keep that inside arm nice and relaxed, the corner is way smoother. My mental image is my inside elbow pointing at the ground instead of off to the side. If I'm doing this, it's relaxed.
Semantics are important here... people talk about the inside of your thigh against the tank, but that could be anywhere from knee joint to crotch. It's closer to your knee... that's why you're sliding back. It lets you get farther off the bike (try moving off while forward on the seat, and then after moving back... you'll find you can move off farther, easier, if you're positioned back).
Stompgrips REALLY help. If don't have any, get 'em.
Old August 19th, 2015, 11:13 AM   #842
Originally Posted by Sirref View Post
That's still humble, I suck at passing against riders of similar pace. I was making on average 3 passing attempts per lap for 10 laps and only a small handful of them worked out only to have me blow the next corner and have him come right back. I had more outright pace than him because he slowed up in a few key corners that caused us to fall behind but I wasn't skilled enough to hop off line and take advantage of that in those corners. Rick is a good rider, but he's no Paul (Paul is one of the fastest coaches with TPM)
i would suggest sandbagging in a C group day and focus on passing. limit yourself to just slightly faster than the person you're practicing with that way you get the experience of lining up the pass correctly without blowing the next few corners. then when you're doing it at race pace it's all natural
Old August 19th, 2015, 01:27 PM   #843
M42
Wrench wench
M42's Avatar
Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS
Ooooh I gotcha now! For whatever reason I was thinking you had to shift off and rotate your knee out at the same time (I saw other people doing it, but this is white class, sooooo). Can't wait to try it at the next trackday... a month from now
M42 is offline   Reply With Quote
Old August 19th, 2015, 02:23 PM   #844
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
The wonderful thing about BP is that you don't need to be riding to practice it
you can work on it with your bike on a rearstand, though if you want to work on quick knee to knee transitions I recommend having someone hold onto the front of the bike
I don't think they'll let me sandbag down to novice but I'll give it a shot in intermediate
Old August 19th, 2015, 02:57 PM   #845
Butt-cam view is so helpful for realizing how much further you have to get off the bike
Old August 19th, 2015, 06:56 PM   #846
not sure your passing rules for local clubs but hopefully either C or B group allows both side passing. explaining that you'll be safe and go slow and are going to be practicing safe passes and they'll let you sandbag in C all day. just dont start riding like you're in a race.
Old August 19th, 2015, 07:02 PM   #847
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
passing rules with the clubs that I ride with regularly
advanced - pass whenever and however you want, don't be a jerk
intermediate/novice - no passing on the inside before the apex, pass on either side down the straights
it's a shame because inside passing on the brakes is what I need to work on the most, at least I get to pass on the inside post apex so working on late apex cornering to pass on the inside at the exit may work well
Old August 19th, 2015, 08:33 PM   #848
Yes! Carry the speed, out steer them and beat them back to the throttle for a faster drive out underneath.
Old August 20th, 2015, 02:32 PM   #849
M42
Wrench wench
M42's Avatar
SO IT BEGINS
Old August 20th, 2015, 04:45 PM   #850
burningscooter
clutch
burningscooter's Avatar
Motorcycle(s): L1 GSXR600
Exiting T10 on Saturday. This is my favorite turn on the track. Absolutely love it.
burningscooter is offline   Reply With Quote
Old August 20th, 2015, 08:10 PM   #851
gogoKawi
gogoKawi's Avatar
Motorcycle(s): 2014 Ninja 300, 2008 ZX6, 2011 Ninja 1000
Hey now! I know that bike! Looking good!
gogoKawi is offline   Reply With Quote
Old August 21st, 2015, 06:30 AM   #852
burningscooter
clutch
:P
Most people know the truck! Well, mostly because there's a certain someone always standing on it taking photos.
Old August 21st, 2015, 06:46 AM   #853
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I know the bike better than the truck, I'm not one to look off track while riding and you pass me every once in a while
Old August 21st, 2015, 07:02 AM   #854
burningscooter
clutch
Thats nice, Ben. LMAO
Old August 21st, 2015, 12:53 PM   #855
My left hand showing what my right hand is doing.
Old August 21st, 2015, 01:07 PM   #856
adouglas
adouglas's Avatar
Damn head lice... God this itches!!!!!!
Last futzed with by adouglas; August 21st, 2015 at 02:50 PM.
Old August 21st, 2015, 01:10 PM   #857
allanoue
allanoue's Avatar
MOTM - Sep '14
knock wood
Old August 21st, 2015, 01:17 PM   #858
lol ya'lls
Great captions!
Old August 21st, 2015, 02:50 PM   #859
adouglas
adouglas's Avatar
7 or 11... c'mon, baby needs a new pair of shoes..... (rattle rattle)
Old August 21st, 2015, 03:10 PM   #860
lol I got snake eyes some odd sessions later.
Old August 21st, 2015, 04:16 PM   #861
Looks like I could be holding a cell phone.
EDIT:
Old August 21st, 2015, 05:49 PM   #862
allanoue
allanoue's Avatar
MOTM - Sep '14
Did i put the the oil cap back on ... let me think a second
Old August 22nd, 2015, 11:15 AM   #863
algs26
Motorcycle(s): ex300, gave up looking for a 250
Someone photoshop a shake weight and animate a few frames for a GIF, please.
algs26 is offline   Reply With Quote
Old August 23rd, 2015, 08:00 AM   #864
Funny you post that one. I did leave the oil cap off in Feb. while riding at JenningsGP. It filled my boot with oil instead of dropping it all over the track.
Shake weight.... ummmm NOOOOOOOO! bwahahahhahahaahhahaa
Old August 23rd, 2015, 11:24 AM   #865
allanoue
allanoue's Avatar
MOTM - Sep '14
Yes, you left it in KY as I recall
Old August 23rd, 2015, 07:40 PM   #866
howlinhoss
Motorcycle(s): Ninja 300
Some pics from last track day. Any pointers would be greatly appreciated!
I find my self dragging toe and from the pics it looks like I need to bring my toes up more on the pegs. Anyone else have this issue?
howlinhoss is offline   Reply With Quote
Old August 23rd, 2015, 07:48 PM   #867
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Looking good!
I drag the hell out of my toes too...then again I drag the pegs too (not as much) so I've adjusted to it.
you could definitely benefit from raising your foot and moving your knee a bit farther out at the same time (happens naturally when you raise your foot) once your knee hits the floor you start getting a lot more feel for your lean and it gives you a lot more confidence to go marginally lower each time. Then you see the price tag on new pucks hahahahaha
Old August 23rd, 2015, 08:24 PM   #868
adouglas
adouglas's Avatar
Redneck catch tank.
Old August 23rd, 2015, 10:08 PM   #869
algs26
Just the typical Thunderhill T2 pic.
Old August 24th, 2015, 09:39 AM   #870
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
I have knee issues from sports when I was younger (running and soccer took its toll lol) and I have trouble getting my knees to tolerate a position that keeps my toes off the deck, especially my right knee which is much worse than my left. I need to find/invest in some boots that will take the beating (my SMX+ and Cortech pair do not do as well as I would like) while I work my flexibility and mobility again lol.
Old August 24th, 2015, 09:42 AM   #871
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Only thing I've seen that works for that is diligently replacing titanium toe sliders
makes knee pucks look cheap but you prevent grinding down the boot to nothing like one of the guys I race against did, he could stick his little toe out of the boot and never realized until after
Old August 24th, 2015, 01:24 PM   #872
CycleCam303
King Hamfist
CycleCam303's Avatar
Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796
Hey @algs26 looking good out there! I only ran one session in B helping out one of my students. I was on the r3.
Turn 2 thunderhill. I'm #34
CycleCam303 is offline   Reply With Quote
Old August 24th, 2015, 01:55 PM   #873
algs26
Did I miss you (@CycleCam303) in the morning meeting lineup?
Last futzed with by algs26; August 24th, 2015 at 01:59 PM. Reason: fix mention code
Old August 24th, 2015, 02:00 PM   #874
CycleCam303
King Hamfist
Uh yea you did. I got a nice slap on the wrist for sneaking in after the first session. Long story short I was going to buy a ninjette race bike that morning, decided that the bike wasn't going to work out and I was up at 4:50am yesterday morning putting my Daytona together after racing dirt track Saturday and getting back at 11pm. I'm flipping tired.
Old August 25th, 2015, 05:50 PM   #875
algs26
I was playing Rock Band (and a little Project Cars) at a lanfest till about the same time Sat. Freebird is too long. I hadn't shifted my sleep time earlier so I was screwed anyway.
Old August 26th, 2015, 12:52 AM   #876
Elloelvi
Elloelvi's Avatar
Motorcycle(s): Ninja 300, Ninja ZX6r, NSR50, XR50r
Originally Posted by Peanut_EOD View Post
I feel so popular! Thanks Nems.
GEEEEEEZUS. That's crazy low
"Ride hard. Don't look back." --Strider, LOTR
Elloelvi is offline   Reply With Quote
Old August 26th, 2015, 05:43 AM   #877
^^ I still love Peanut's pictures.
Old August 26th, 2015, 06:04 AM   #878
rc racer
rc racer's Avatar
Motorcycle(s): 2015 R3, 1969 CB160, 2002 TTR125, 2007 KX250F
Got the R3 out for it's second race this year at Motorsport ranch in Cresson TX. improved my personal best lap time at this track by 1.5 seconds over the ninja 250.
rc racer is offline   Reply With Quote
Old August 26th, 2015, 06:18 AM   #879
sharky nrk
sharky nrk's Avatar
Got some more pics of it in race trim? Looks like there was three or so R3s out racing this weekend.
Old August 26th, 2015, 07:03 AM   #880
rc racer
rc racer's Avatar
Don't have many more pictures of it, just stuff like in the paddock on stands and warmers.
I know there where at least two other R3's racing last weekend besides me. Lynn Stackable with blue hotbodies bodywork and Jim Whitten #3 with primered bodywork way at the front of the pack.
Incorrect Body Positioning? rasta Riding Skills 27 July 15th, 2015 07:28 AM
Need help with body positioning.. Volnaya Riding Skills 30 November 4th, 2011 11:56 PM
Body positioning and my knees HorizonXP Riding Skills 20 August 29th, 2010 09:03 AM
[sportrider - riding] - Body Positioning And Steering Techniques Ninjette Newsbot Motorcycling News 0 April 13th, 2010 04:00 AM
[sportrider - riding] - Body Positioning And Steering Techniques Ninjette Newsbot Motorcycling News 0 March 29th, 2010 11:40 PM
