Go Back   ninjette.org > Marketplace > Motorcycle-related
Old February 29th, 2020, 09:15 AM   #161
JFMNINJA400
JFMNINJA400's Avatar
Motorcycle(s): GSXR 750, GSXR 600, Ninja 400, Ninja 300
Here is a pic of my 2fiddy that I will be pulling the carbs out of for Mr. Gordon to work his magic!
File Type: jpg 9B35F1E1-C365-4F1D-8EF6-0EAF76FD7D30.jpg (183.1 KB, 7 views)
JFMNINJA400 is offline   Reply With Quote
Old February 29th, 2020, 03:04 PM   #162
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
You won't regret it, man the bike feels like they came out of the factory after the carb clean.
Old March 14th, 2020, 09:54 AM   #163
ducatiman
ducatiman's Avatar
EX500 refurb completed today, came out nice, predict will be fine runners after precise setup and testing.
24 hours in & out, btw.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Last futzed with by ducatiman; March 14th, 2020 at 11:12 AM.
Old April 4th, 2020, 02:56 PM   #164
ducatiman
ducatiman's Avatar
uh oh, Ducati carbs, wha we gonna do?
Custom Carb Service
Old April 4th, 2020, 06:06 PM   #165
Yuck!!! is that algae? mould or fungus?
Old April 4th, 2020, 06:38 PM   #166
ducatiman
ducatiman's Avatar
Hard to believe at one time that black stuff was fuel. The brass jets underneath, once revealed, will no doubt show some nasty damage. It'll be interesting to see, I'll leave them intact for a pic I'll eventually post. Thankfully, I've got spare jets involved.
Challenging, a lotta work ahead on these nasties, actually Mikuni BDST34 from a 750 Ducati Monster twin. Similar Mikunis were used on old 90's Yamaha FZ, some Suzuki fours too.
For informational purposes...I'll try and get history from owner to see how long they sat.
Custom Carb Service
Old April 5th, 2020, 06:18 AM   #167
ducatiman
ducatiman's Avatar
turns out was a "barn find", sat untouched by current owner for 2 years, unfortunately no previous owner timeline available.
As the pictured carb is far worse than the other, i'll venture to say it was left on its side stand many years filled with unstabilized fuel.
Custom Carb Service
Old April 6th, 2020, 05:10 PM   #168
ducatiman
ducatiman's Avatar
Duc carbs finished today, before & after
Custom Carb Service
Old April 7th, 2020, 03:38 PM   #169
ducatiman
ducatiman's Avatar
Work commencing on Honda V4 ST1100 Keihin carburetors today. Various issues will be corrected.
Custom Carb Service
Old April 9th, 2020, 02:43 PM   #170
ducatiman
ducatiman's Avatar
brass (jets, pilot screws) prepped and ready for reinstall
Custom Carb Service
Old April 16th, 2020, 01:36 PM   #171
ducatiman
ducatiman's Avatar
separate vacuum leak diagnosed/fixed, carbs' internal circuits cleared, float levels, mixture adjustments corrected, starts on the click of the button, stable idle, responding to throttle.
New battery, intake manifolds, oil & fuel filters, oil & coolant, final drive oil, spark plugs...(basically a full service minus valves)
This big-ass 650 pound touring ST1100 Honda (V4 carbed powerplant) is ready to rock after tire and valve replacement....next on the list. I await shipment.
Custom Carb Service
Old April 18th, 2020, 03:48 PM   #172
ducatiman
ducatiman's Avatar
My Saturday here....missing various parts, clogged in numerous areas, vent hose misrouted and kinked shut between the poorly setup carbs, bowl hardware obscenely tightened to compensate for crushed oring seals, pilot screws (missing washers) closed shut, every single oring crystallized solid, decel valve sticking, air correction jets clogged........on and on.
I'll submit the owner will not recognize them as his own AND the 250 involved will now run like a champ (provided no other issues on bike).
Not quite done yet....these required some chutzpah, determination, and experience in knowing where to seek and how to eliminate problem areas. Splitting mandatory in this repair.
Yeah, "carbs are easy"....right.
Custom Carb Service
Old April 18th, 2020, 04:46 PM   #173
ST is so awesome! I may go for one of those eventually...
Old April 18th, 2020, 05:51 PM   #174
ducatiman
ducatiman's Avatar
This 650 lb Honda behemoth is certainly the opposite side of motorcycling from the perspective of ninjette and such lightweight sporties. Their (mature) owners rave on its comfort, reliability and pile many miles on....200K+ not unusual at all.
Gulp...I will test ride after new tire install before handing it back to the 70 year old local owner (friend of a friend). Want to assure no running issues whatsoever. I gotta admit, its size and weight are rather intimidating. Being a lightweight I had to employ additional help to get it up on the centerstand!
Custom Carb Service
Old April 19th, 2020, 06:35 PM   #175
ducatiman
ducatiman's Avatar
2 fiddy set completed this evening, evidence of neglect and abuse, missing parts, prior setup errors all corrected. These now ready to rock, going home to Colorado.
Custom Carb Service
Old April 27th, 2020, 03:16 PM   #176
ducatiman
ducatiman's Avatar
Current "corona" project...in process of restoring an original Holley 1 barrel carb off a 1958 Ford F100 pickup. Goal to make both functional and return it to its former glory by owner request. I'll post before/after when done.
Interesting old brass float setup and ball bearing type check valves and drillings (rather than jets) controlling flow and spray...this one an oldie alright.
Custom Carb Service
Old April 28th, 2020, 09:38 AM   #177
ducatiman
ducatiman's Avatar
Netflix my ass. '58 Holley carb done this morning.....moving on to the next 250 set.
Custom Carb Service
Old April 28th, 2020, 09:40 AM   #178
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
nice. we are workin too(cardinalhealth)
"trying not to get old"
Old April 29th, 2020, 05:39 PM   #179
ducatiman
ducatiman's Avatar
these 250's finished today, now onward to a Honda 750 Shadow carb/service work, bike here, live, in all its Honda glory.
Custom Carb Service
Old May 2nd, 2020, 05:46 AM   #180
ducatiman
ducatiman's Avatar
Honda Shadow carbs essentially done, I await new float bowl gaskets. In the meantime, doing valve clearances.
Interesting older Honda/Keihin carbs...some parts/orings common to 250!
Custom Carb Service
Old May 9th, 2020, 09:26 AM   #181
ducatiman
ducatiman's Avatar
24 hour refurb turnaround, received USPS Friday....shipped back Saturday
Custom Carb Service
Old May 10th, 2020, 06:50 AM   #182
ducatiman
ducatiman's Avatar
yet another 250 set on deck
Custom Carb Service
Old May 15th, 2020, 12:08 PM   #183
ducatiman
ducatiman's Avatar
The formerly spitting, sputtering, loudly popping Honda 750 Shadow is now done and complete, a successful victim of carb voodoo. Fully serviced and fully rideable, though the open, loud fishtail exhaust is utterly obnoxious, IMHO.....back to owner it goes. And today has officially left the building. Direct quote via text from owner "unbelievable, great throttle response, no hesitations, just perfect".
Custom Carb Service
Last futzed with by ducatiman; May 16th, 2020 at 09:29 AM.
Old May 15th, 2020, 12:59 PM   #184
Awesome work!!!
Old May 16th, 2020, 09:31 AM   #185
ducatiman
ducatiman's Avatar
Ty. Got lucky I guess.
Custom Carb Service
Old June 6th, 2021, 05:27 AM   #186
ducatiman
ducatiman's Avatar
ZR7 carbs refurbed/completed this week. Now a break...nothing planned or going on at this point forward. Great opportunity to actually ride my own!
Custom Carb Service
Old August 1st, 2021, 10:56 AM   #187
ducatiman
ducatiman's Avatar
latest iteration of my splitting and non-splitting carb kits
$35 non split, $50 for split shipped USPS 1st class in CONUS
Custom Carb Service
Old April 5th, 2022, 05:58 PM   #188
ducatiman
ducatiman's Avatar
Just a reminder, I welcome petcock repair inquiries, with or without being accompanied by carbs.
As new 88-07 petcocks retail at $115, I'd guess it would be worth it to inquire.
All spares are in stock, no delays.
Custom Carb Service
Old June 1st, 2022, 02:45 PM   #189
ducatiman
ducatiman's Avatar
until further notice.......
a CCS ink pen to be provided with every service/purchase!
Custom Carb Service
Old June 24th, 2022, 12:14 PM   #190
ACL 9000
ACL 9000's Avatar
Motorcycle(s): 2005 EX250, 1975 Suzuki T500, 2018 Kawasaki Z900RS
I sent the carbs from my '05 over to ducatiman back in 2020, I think, and I'm such a lazy forum member I'm only just getting around to saying it was the best decision I could have made.
Everything worked flawlessly out of the box and all my terrible, chewed-up fasteners had been replaced with nice stuff I can actually put tools on. The bike has been perfectly happy ever since.
ACL 9000 is offline   Reply With Quote
Old June 24th, 2022, 12:32 PM   #191
ducatiman
ducatiman's Avatar
superb, great to hear Ash.
Custom Carb Service
Old December 3rd, 2022, 06:07 AM   #192
MikeCL
Motorcycle(s): ‘04 EX250
Subscribing to this
MikeCL is offline   Reply With Quote
Old December 3rd, 2022, 07:02 AM   #193
ducatiman
ducatiman's Avatar
I'd opt to suggest you follow the thread named "my day"
https://www.ninjette.org/forums/showthread.php?t=348623
more current, timely posts
Custom Carb Service
Old December 3rd, 2022, 02:29 PM   #194
MikeCL
Done!
Old December 3rd, 2022, 03:10 PM   #195
ducatiman
ducatiman's Avatar
Custom Carb Service
Old June 22nd, 2023, 01:29 AM   #196
MattyDaddy
Motorcycle(s): 2012 Kawasaki Ninja 250R EX250J
Question Still offering these formentioned services?
^ g and g -
cleaning and refurb service, I'll send a PM with further info.
I have a 2012 Kawasaki Ninja 250R EX250J that I could use some carb work done on. I bout the hike off a guy who stooped rebuilding it due to family issues, and I finally got all the mechanical pieces hooked up to there respective spots but my carb is leaking fuel from somewhere on the bottom near the bowls.
MattyDaddy is offline   Reply With Quote
Old June 22nd, 2023, 05:25 AM   #197
ducatiman
ducatiman's Avatar
yes, of course
i'll PM in a bit
Custom Carb Service
Old February 3rd, 2024, 12:46 PM   #198
Ghostt
Ghostt's Avatar
Hey there Gordon, I picked this up
violente et ignorantia
ZX-2R BLOG
Old February 3rd, 2024, 01:27 PM   #199
ducatiman
ducatiman's Avatar
a rather rare Honda Hurricane 1000!
Further detail? total mileage? a runner? year?
Custom Carb Service
Old February 4th, 2024, 11:48 AM   #200
Ghostt
Ghostt's Avatar
Won it on eBay, and had to pick it up, 2000 miles, 4 states, in 25 hours, total cannonball style.
1987 Honda Hurricane 1000, 19k miles, it runs, but only with the choke on, and that's about it.
It's had a hard time, cracked fairings, etc... but it's got good bones.
AKA "Hurricane Harvey"
PS you'll be getting the carbs soon.
ZX-2R BLOG
Last futzed with by Ghostt; February 4th, 2024 at 01:03 PM.
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
Full service manual says to turnout one carb pilot more than the other....why? RcTechnologies 2008 - 2012 Ninja 250R Tech Talk 17 March 25th, 2015 09:45 AM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
[roadracingworld.com] - Race Tire Service To Provide Trackside Dunlop Sales, Service Ninjette Newsbot Motorcycling News 0 February 20th, 2012 11:10 PM
[motorcyclistonline] - Sargent Cycles Custom Seat Service Ninjette Newsbot Motorcycling News 0 February 12th, 2011 07:30 AM
