Go Back   ninjette.org > General > Pictures
Old March 12th, 2014, 09:07 AM   #201
When I did that, I had terrible light aiming. There was tons of light in all the wrong places and still too bright to oncoming traffic.
So I went with a bixenon retrofit. Much better solution. Don't be that guy who blinds traffic.
Old March 12th, 2014, 08:12 PM   #202
EMSRacer07
EMSRacer07's Avatar
Ok this is one with the lower belly fairing on and my zx12 front fender, moved the saddle bags a bit so I can better fit a passenger.
But so far I am satisfied with my 1990 pregen.
Old March 13th, 2014, 11:47 AM   #203
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
^^ dude that is pretty sweet
Good work
Old March 13th, 2014, 12:05 PM   #204
EMSRacer07
EMSRacer07's Avatar
Good work
Thanks took a lot of work. Thank you for the good deal on the headlight and the brackets for it. That helped a lot with the project
Old March 13th, 2014, 12:09 PM   #205
akima
Nooblet
akima's Avatar
MOTM - Oct '13
It keeps inline with the Kawasaki idea of a ninja: black with hints of obnoxiously bright colouring! Stealth.
P.S. I do like the orange.
You've created a very cool and unique ninjette.
Old March 13th, 2014, 12:19 PM   #206
EMSRacer07
EMSRacer07's Avatar
Thank you. Orange really pops out. I like it.
Old May 10th, 2016, 07:28 PM   #207
wendyjboss
wendyjboss
wendyjboss's Avatar
Motorcycle(s): 2015 Honda CBR 500RF (On its way), 2004 Kawasaki Ninja 250 (sold)
Here's mine
Here's mine. I have put new precision springs in it, replaced the top fairing and added a hard case rack and top case.
wendyjboss is offline   Reply With Quote
Old May 10th, 2016, 09:42 PM   #208
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Only mod so far is my rim-tape.
Old May 11th, 2016, 05:34 AM   #209
I've posted these here somewhere before, but here's my son's pristine 2004 -
And our other, not so pristine, 1990 $150 beater -
Old May 11th, 2016, 12:57 PM   #210
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Originally Posted by jkv45 View Post
^ evidence of time travelling
pls don't bring stuff back from the past... you'll break things. k thanks bye
Old May 11th, 2016, 01:24 PM   #211
wendyjboss
wendyjboss
wendyjboss's Avatar
That top Ninja looks sweet.
Here's mine for its first day out with a carrier and top case. Yeay Spring! It's finally here.
And yes, my dog Lotus is photobombing in the background.
Last futzed with by wendyjboss; May 11th, 2016 at 01:29 PM. Reason: I have a photo to add plus I have a dog.
Old May 11th, 2016, 02:08 PM   #212
Ghostt
Ghostt's Avatar
Back in May 2014, I picked up a 98 with 27k miles on it for a great price. The P.O. did nothing except put gas in it, and changed the oil, I think, he did this for about 20k of the total miles.
Needless to say it needed a lot of TLC. I am no stranger to rebuilding bikes, I did my 91 EX500 which was a basket case for sure to say the least, here is the link to see that build:
https://picasaweb.google.com/1006527...JCB6ffS-973wgE
With that said I went through the bike, repairing, replacing, & modifying as I went, with the exception of the engine/transmission that seems solid no noises or smoke.
Here is a link to the evolution as told by pictures.
https://picasaweb.google.com/1006527...IDXyZXyoe2m0QE
Work performed as of 08/2015
Cut and set sag front fork springs(springs from a Ninja 500 1st generation, rate is .85kg/mm )
Replace fork oil 15wt synthetic
Install new fork seals and dust caps
Replace rear shock(zx600c)
Replace shock oil 15wt synthetic
Change gears +1/-2(15/43)
Rebuild/tune carbs, adjust idle mixture
K&N air filter
New brake pads F&R EBC extreme HH
New Wave front rotor
Used OEM rear rotor
Rebuilt calipers
Modified OEM seat(gel/foam insert, Custom Seat Creation cover solo line cf silver/cf metal, heated kit)
Extra heavy bar ends(3"/23oz)
Heated grips w/ foam covers
Touring windscreen / 7 JuRock 18" 73%tint w/ flip
Shorter bar risers(OEM ZX600c, lower bars about 1 1/2")
Removed paint from rims, bare aluminum
Bridgestone BT-45s w/ Dynabeads
Stainless steel allen head fasteners
Stainless steel braided brake lines
Shorty adjustable levers
HD clutch springs
Charge/voltage LED indicator
LED clock
HID headlight(55w 5k)
Replaced all other bulbs with CREE LEDs
DIY integrated tail light kit w/clear lens
DIY rear fender elimination
DIY licence plate mount(LEDs to illuminate the plate/red LEDs tied into brake light)
Brake light modulator
Maintenance free gel battery
Compact air horn
2007 Complete OEM fairing set silver
Genuine imitation carbon fiber wrap misc parts
Reflective custom graphics ZX-2R silver
Reflective custom graphic NINJA red(taillight lens)
Reflective rim tape silver
Electronic turn indicator relay
Replace front side reflectors with flush mount turn indicators LEDs
Installed rearview camera system
Installed oil cooler
Strip paint off grab handle, bare aluminum alloy.*
Custom reflective graphic "SERENITY" for windscreen silver
Aluminum chain guard from Suzuki Bandit 1200
Swing arm plugs from 08 Ninja 250
Mad Hornets Turn Signal Indicators w/duel color Cree LEDs(amber/white)
FH010 R/R modification
Digital gear indicator
Universal Rear View Side Mirror Rain Board Sun Visor Shade Shield
Kawasaki ZRX1200 lowered foot pegs
OEM upgrade shift spring
All this and full maintenance and rebuild everything else except the motor. I'm sure I'm forget some stuff, but you get the idea
Apon purchased
It wasn't in the best condition apon inspection
Freshly finished, before custom graphics.
Now meet SERENITY, now starting it's third season( 2 more than Firefly, sorry Joss), and over 10k miles I've done on it so far.
violente et ignorantia
ZX-2R BLOG
Old May 14th, 2016, 04:49 AM   #213
cbreater
cbreater's Avatar
Motorcycle(s): 16' S1000RR, 04' CB919, CRF150/230, 07' 250R
2007. Rearsets raised, rear fender gone, GSXR shock, Ricor Intiminators, 17" hoops with S20 EVOs spooned on, EBC pads front and rear, new fluids all around and new chain/sprockets stock gearing. Ready for track duty.
cbreater is offline   Reply With Quote
Old May 22nd, 2016, 10:51 AM   #214
Harpman28
Motorcycle(s): 2004 ex250, vfr800, klr650, drz400s
Almost ready for the track on Wednesday. Went way overboard on this bike. Looking forward to flogging it at the track.
Harpman28 is offline   Reply With Quote
Old May 22nd, 2016, 10:53 AM   #215
Ghostt
Ghostt's Avatar
Nicely done
ZX-2R BLOG
Old May 22nd, 2016, 02:02 PM   #216
Spencerrides
Motorcycle(s): 2005 Kawasaki Ninja Ex
Dude that's hot what did you do?
Spray paint the interior head light black? @choneofakind
Spencerrides is offline   Reply With Quote
Old May 22nd, 2016, 05:41 PM   #217
^^^ Fiberglass panel to replace the headlight in the fairing. Airtech streamlining makes them. That's what I did for my spare fairing for track days.
Old May 22nd, 2016, 06:11 PM   #218
Harpman28
- New gen front and rear end swap with brakes and fender
- airtech headlight block off (took forever)
- woodcraft rearsets and clipons
- ssr preload adjusters and fuel cap (venting issues may remove)
- homemade tail light replacement plate
- full muzzy system
- ebc floating rotor (ordered the solid one and this one showed up from amazon)
- galfer brake lines
- race tech fork internals
- hagon shock until I get the fox tcr back from rebuild
- homemade dog bones to get the rear up
- removed the gauge shroud to clear levers
- Chinese lever guards
- thermobob
Probably forgetting some things.
Old May 23rd, 2016, 11:15 AM   #219
VaFish
VaFish's Avatar
MOTM - Jan '16
Pregens you say? I has them.
Old June 21st, 2016, 06:07 AM   #220
- full muzzy system
- thermobob
Looks great!
Old June 21st, 2016, 06:19 AM   #221
Harpman28
Originally Posted by Alex View Post
Looks great!
Thanks guys!
Old June 26th, 2016, 09:21 PM   #222
Pregen's on 17's and modern radial rubber always look so damn good!!!
Old June 26th, 2016, 09:23 PM   #223
You wouldn't happen to haz a spare running engine floating around there that you don't really want any more, would you?
Old June 27th, 2016, 06:03 AM   #224
VaFish
VaFish's Avatar
MOTM - Jan '16
Spare engine, yes, running, unknown.
And I'll be going through NE Ohio in August.
Last futzed with by VaFish; July 1st, 2016 at 03:48 PM.
Old July 5th, 2016, 05:02 PM   #225
Nu2Street
Motorcycle(s): 2006 Ninja 250R
Here is my 06 as it was packed for my first long road trip- 300+ miles each way.
Nu2Street is offline   Reply With Quote
Old July 5th, 2016, 05:06 PM   #226
Nu2Street
I'll try that again.
Old July 5th, 2016, 05:09 PM   #227
The SPP (Sideways Picture Police) appreciate your efforts.
Old July 5th, 2016, 07:15 PM   #228
Ninja Rob
Ninja Rob's Avatar
Motorcycle(s): 2004 Ninja 250
Mods include:
3M velcro under the windscreen to hold my license which also has velcro.
Before life ends, Some people want to climb Mount Everest, some want to go to Disney Land, some people want to visit Paris. Me, I want to ride a motorcycle.
Ninja Rob is offline   Reply With Quote
Old June 20th, 2022, 11:35 AM   #229
downtowndave
Motorcycle(s): 2002 Ninja EX250F, 2003 Bajaj Chetak 150
Where did you get the amber lens for the rear integrated tail light? I'm considering buying clear and painting it amber but I'd love an off the shelf if it exists.
downtowndave is offline   Reply With Quote
Pre-Gens on the Dragon! livewire83 Videos 2 April 19th, 2014 11:16 AM
Exhaust systems for pre-gens psych0hans Motorcycle-related 5 March 8th, 2014 02:16 AM
custom pre gens darrell85 General Motorcycling Discussion 2 September 1st, 2010 11:18 AM
16 teeth front sprocket - fits pre-gens and new-gens Rayme Motorcycle-related 2 August 2nd, 2009 10:18 AM
New Rearsets for Selected Pre-Gens: komohana 1986 - 2007 Ninja 250R Farkles 31 June 2nd, 2009 12:44 PM
