Old July 26th, 2020, 09:17 AM   #1
cuggi5
Motorcycle(s): 2009 ninja 250r
LED BULB fitment
i have some LED bulbs that id like to install..however...does anyone know how i can get them to sit in the housing securely? the fan on the back of the led bulb is way to large for the bulb clamp to hold it in like it would a normal bulb that doesnt have a cooling fan attached. i dont see a way to insert the bulb and just twist to lock it in place either. so has anyone upgraded to led's? is the only way to secure the bulb in place is with the little wire clamp?
cuggi5 is offline   Reply With Quote
Old July 26th, 2020, 10:30 AM   #2
Hi Donell and welcome to Ninjette!
Please post photo of your LED bulbs and link to where you purchased them. In many cases, design of these bulbs are so poor that there's always issues with fitting them and getting better bulbs ends up being only solution. The low-end ones have generic mounting-base with an adapter ring to fit into original bulb-holders. This causes loose-fit and variable beam-patterns depending upon which way you wiggle bulb. Yes, spring-clip is required to hold bulb in place.
Also only bad low-end bulbs have fans. Better designed ones using higher-quality materials such as copper & aluminium heatsinks are smaller and don't require fans.
Aside from outright illegality of LED bulbs, they pose a serious risk to oncoming traffic with glare (above horizonal light spray). Which presents risk to you as well since blinded drivers tend to go in straight line in curve. So if you're on left-hand turn, blinded driver on other wide will miss their right turn and go straight into you.
Some background info on LED bulbs:
https://www.candlepowerforums.com/vb...-Manufacturers
https://www.tacomaworld.com/threads/...ectors.454371/
https://www.ninjette.org/forums/showthread.php?t=348470
Note LED bulbs puts out LESS light than high-quality halogen bulbs. Best LED bulb on market, Philips XTreme Ultinon bulb generates 1760 lumens. Compare that to Phillips Long Life HIR2 9012LL bulb which is 2100 lumens.
The preferred way to go with LED is an projector-retrofit (still in grey area legally). At least that way, you're not blinding oncoming traffic with glare. Note that even with TWO LED bulbs in TWO projector-housings, output is still less than single HID light.
https://www.ninjette.org/forums/showthread.php?t=335983
Here's beam-pattern you want.
Last futzed with by DannoXYZ; July 26th, 2020 at 07:34 PM.
Old July 26th, 2020, 11:25 AM   #3
cuggi5
so whats considered a cheap led bulb? ive been using the same ones from amazon for years in my car. id say 9/10 of them have cooling fans,
ive attached a picture of the bulbs and a link where i purchased them from amazon.
i chose those because they are always plug and play. and i dont need harness ect which is required for HIDs. so the leds give kindve the same look
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
**even the leds from the suggested website in one of your link has fans:
https://www.superbrightleds.com/vehi...1943&year=2009
Old July 26th, 2020, 12:54 PM   #4
Over 95% of LED bulbs on market are cheap, poorly designed items created purely for high-profits with little regard for fit or function. As you've discovered.
Eh??? It says "Motorcycle H7 LED Fanless Headlight Conversion Kit with Compact Heat Sink - 2,000 Lumens". Also "Integrated heat sink - no fans or bulky braided heat sinks". Note how this design has narrow channel at base of bulb to fit spring-clips? Someone's actually test-fitted their bulb into real-life headlights during design process to make sure their design fits.
Only the Philips Xtreme Ultinon 11972ULX2 specifically designed for reflector housings has close enough light-pattern to halogen to make it worthy of using IMHO. Earlier 1st-gen Ultinon had external regulator to allow for small removeable heatsink to make installation easier. Also much better CRI.
Last futzed with by DannoXYZ; July 26th, 2020 at 02:33 PM.
Old July 26th, 2020, 01:31 PM   #5
cuggi5
much appreciated! im gonna grab a set of those. for $149.99, they better be good quality lol. thanks for the quick responses as well!
Old July 26th, 2020, 02:28 PM   #6
You're welcome! My experience with Ultinons was many years ago when they 1st came out. I think many others on market are comparable at lower price now. Greg737 has used the H4 version from SuperbrightLEDs for several years now and he has favourable reviews.
Might want to give these a try:
https://www.ninjette.org/forums/show...58#post1269258
Old July 26th, 2020, 06:25 PM   #7
MauR
MauR's Avatar
Motorcycle(s): 250R
The preferred way to go with LED is an HID-retrofit (still in grey area legally). At least that way, you're not blinding oncoming traffic with glare. Note that even with TWO LED bulbs in TWO HID-housings, output is still less than single HID light.
Hello @cuggi5!!!
I agree with @DannoXYZ, If you want to go with LEDs best way is to use a Projector retrofit. Actually I think I will go back to HID since, as you can see in my retrofit, one HID has better performance than 2 LEDs.
If you don't want to go that way, there are some Philips high performance halogen bulbs that will work great on OEM reflectors.
Regards
I
MauR is offline   Reply With Quote
Led headlight bulb Ninjette 2011 lavarsios 2008 - 2012 Ninja 250R Tech Talk 3 March 2nd, 2019 08:41 PM
Cyclops 3800 lumen LED bulb impressions M42 General Motorcycling Discussion 8 October 6th, 2015 07:17 PM
Does dead taillight bulb affect the license plate bulb? headshrink 2008 - 2012 Ninja 250R Tech Talk 5 April 3rd, 2013 06:05 AM
[webbikeworld.com] - 1156 LED Bulb Replacement Review Ninjette Newsbot Motorcycling News 0 August 6th, 2012 07:50 AM
LED Bulb Supplier Recommendations? dubojr1 Off-Topic 5 April 29th, 2012 05:47 PM
