Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old February 27th, 2014, 09:39 AM   #121
cuong-nutz
cuong-nutz's Avatar
Originally Posted by felo View Post
i know, i am just saying if the fitment is the same, you can look at the aftermarket 250 rear huggers to put them on a 300 then
Yes, the 300 hugger fits the 250. It's been confirmed by PartsNinja.
HalfFast Racing Team
Old February 27th, 2014, 01:47 PM   #122
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
I think he's talking about the other way around. The 300 rear huggers have more spots to bolt down though so not sure why you'd use a 250 one...
Old February 27th, 2014, 04:17 PM   #123
cuong-nutz
cuong-nutz's Avatar
"Ahhhhhh, I see!" said the blind man.
Old March 14th, 2014, 07:47 PM   #124
old3
As he picked up his hammer, and saw.
old3 is offline   Reply With Quote
Old July 1st, 2014, 08:40 AM   #125
SSneekey6.0
Motorcycle(s): 09 Ninja 250
I know I'm bumping a old thread...but did anyone confirm if the 300 front fender fits the 250?
SSneekey6.0 is offline   Reply With Quote
Old July 14th, 2014, 09:03 AM   #126
Rassie
Motorcycle bon vivant...
Rassie's Avatar
Motorcycle(s): 300 Ninja, 250R Ninja, SV650S, CB350, GT750, Aprilia RS250, Triumph Street Triple R
Lower and upper triple clamps are also compatible between (08-12) 250 and 300 Ninja. Forks are same diameter as well but have different mounts for the caliper. Front axles is the same. Spacers are different on the non brake side due to elimination of the speedo drive.
Anyone need more checking I have all 3 generations of the 250/300 in my garage so can quickly take a look to compare at least visually and by way of measurement what could be compatible.
Will check on front fender and engine mounts later in the week.
NESBA 13, 300 Ninja, 250r Ninja, 06 SV650, Ninja ex250, CB350, CL90 ,GT750, Aprilia RS250, Triumph Street Triple R www.mybikeproject.com
Rassie is offline   Reply With Quote
Old July 30th, 2014, 10:45 AM   #127
red26
Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150
Hi @Rassie, hows it going with the engine mounts?
red26 is offline   Reply With Quote
Old August 2nd, 2014, 11:23 AM   #128
Rassie
Rassie's Avatar
Engine mounts between Ninjette models.
OK so got around to take some measurements this morning. Seems that we are in luck. The width of the lower rear mounts is the same on my 08 250 and on my 13 300. Both are 120mm. The upper mounts are also the same at 100mm.
Now those front mounts are a different story since the 300 has some rubber mounts there that I did not see on the older models (would have to strip off the fairings to confirm). However since the rear mounts are the same it will be easy to modify the front mounts to suit.
The distance between the lower and upper mount was difficult to measure but seemed to be the same as well at 180 to 185mm or somewhere in between. As I mentioned it is difficult to measure that distance but eyeballing it gives me 180 to 185mm and they both seem to be the same.
Old August 2nd, 2014, 03:34 PM   #129
micoulisninja
modaholic junkie
any info yet on primary exhaust pipes ?? do they interchange ?? is there enough clearance for a 250 aftermarket system to fit the 300 engine ?? the 300 has different routing because of new shape and lowered oil pan and oil filter facing front so I am still wondering...
I will find out eventually on Monday but if sone has already tried even a stock 300 on a 250 or sth...
Old August 3rd, 2014, 07:38 AM   #130
Rassie
Rassie's Avatar
300 and 250 exhaust headers.
I have tried the 300 headers on the 250 and it bolts straight on, no issues. Not sure about the reverse but could not see why you would want to do that. The 300 stock header pipe is larger than the 250 pipe, so would think there is minimal benefit.
Old August 3rd, 2014, 08:20 AM   #131
micoulisninja
modaholic junkie
right !! but...well, like I said.....
" is there enough clearance for a 250 aftermarket system to fit the 300 engine ?? the 300 has different routing because of new shape and lowered oil pan and oil filter facing front so I am still wondering..."
maybe I should have posted "racing"...
Old August 3rd, 2014, 04:32 PM   #132
Rassie
Rassie's Avatar
I will take a look and compare soon as I am in the garage again.
Old August 4th, 2014, 01:07 AM   #133
micoulisninja
modaholic junkie
thank you very much Rassie !!
Old August 17th, 2014, 02:18 PM   #134
Rassie
Rassie's Avatar
I checked and it does not look like the 250 pipe will fit the 300. The 300 motor has a different sump that comes down lower. I attached some pictures so you can see.
Old August 17th, 2014, 02:22 PM   #135
Rassie
Rassie's Avatar
BTW the headers on the right are Tyga headers. I have an exhaust sitting on the shelf that was supposed to go on my track bike. It was too nice so I decored the stock muffler and I am using that instead.
Old August 17th, 2014, 05:00 PM   #136
cuong-nutz
cuong-nutz's Avatar
I tried the 300 header and it hits the oil filter cover on the 250.
Old August 17th, 2014, 06:33 PM   #137
micoulisninja
modaholic junkie
thank you Rassie for all details and pics and c-n for your important input... well I am already "manufacturing" my own exhaust system.... 10cm of 250's yoshi R-77 headers, then another 40cm (give or take) 2nd and 3rd cylinder stock ZX-12R exhaust headers , then again yoshi 2-1 merging (the stock ZX-12 pieces fit right into it... well it took lots of cutting and fitting and measuring again and again but I am building it the way I want it on low budget for my 345cc project (need the money for more important engine stuff)... tomorrow some welding to match and bond pieces and then again to fit the rest... changed the routing and chose for the 300's stock path to gain some length... thinking about taking out the left side of the bike...will see how it goes...
pics later on when it'll look more like an exhaust, still in pieces...
chose the stock ZX-12 cos I believe have right size (32,5mm ID) for what I am building and it was for free !! sitting in my garage for 12 yrs, was about time it came to use...
got to think about ID of the rest of the pipe till muffler...yoshi is 42mm IDfrom merge till 30 cm before muffler, then opens up gradually to about 50, then narrows down again a bit into the muffler...
think I'll keep a bit of that last part and make the rest out of 45cm ID pipe... hope I'll manage to avoid making the s-turn round the back of the oilpan to place the muffler on the right after all...
another thing to say btw since c-n mention the stock 300 fitting problem
a friend of mine recently managed to fit a stock 300 system on his '09 efi 250 kinda same way I am...
kept about 12-15cm of the stock 250 headers, then cut the first 7cm off the stock 300 fit and welded it back together, passes under the engine just fine, no clearance issues... however 2 things that can be major drowbacks...
1. because of that "tailoring", the holding points of the exhaust are off by about 2cm... had to cut and weld that too, and he had to use a spacer for bolting on the muffler to the rear footpeg...looks funny at the moment, going to match it up properly soon...first impression is that it works much better throughout the rev ranga but no dynoing for him... I don't know what he is going to do with mapping though (don't forget efi european versions), I think it will be necessary to adjust the AFR... it is a very cheap solution (cost him about 90$ including cutting and welding but huge improvement to original stock
2. most important... problem removing oil filter... routing of 300's pipes don't leave enough room for taking out cover and changing the filter so it will be necessary to remove right side fairing unbolt the muffler bolt and the chassis bolt so that the pipes can "hang" abit and give enough clearance for the job to get done... the way I saw it this is not for sone who is not experienced with DIY sevice and/or not having a serious tool kit...
one last thing to ask @Rassie and @cuong-nutz if I may... please measure the outside diameters of the primary pipes and that of the secondary, after the merging, just before it starts turning behind the pan, of the stock 300 just for comparison, since my friend is now on his way for the summer vacation and will be back in September... Rassie do the same on the 300 Yoshi if you have the time and courtesy... thank you both in advance!
Old August 19th, 2014, 11:22 AM   #138
Rassie
Rassie's Avatar
The Yoshi pipe is 32mm at the header, then widens to 45mm after the collector and again widens at the exit from underneath to 53mm before it runs into the muffler.
Old August 19th, 2014, 03:17 PM   #139
cuong-nutz
cuong-nutz's Avatar
300 stock exhaust piping
25.4 mm section going into the head
28.5 mm before the collector
38 mm after the collector
35 mm where exhaust slips over pipe
Old August 20th, 2014, 11:22 AM   #140
micoulisninja
modaholic junkie
so now I can verify that all measurings concerning Yoshimura exhaust system is that 250 and 300 is completely IDENTICAL (but the routing of course)
After working with parts of it, what is left to be mentioned is that for every number Rassie is providing above, one must keep in mind a -3mm of inside diameter...
thank you Rassie for your quick response...
Old August 20th, 2014, 11:26 AM   #141
micoulisninja
modaholic junkie
precise same as 250's ...
huge difference there...still 25.4mm for the 250 there
I think that last measuring is what counts as far as secondary is concerned since after the collector is the cat I think and they gave it some space to not cut the flow so much... Thanks once again C-N !!
Old August 20th, 2014, 03:46 PM   #142
cuong-nutz
cuong-nutz's Avatar
my Measurements might be slightly off since my caliper could be off .4-.5 mm but I think what I gave you is close.
Old August 21st, 2014, 03:56 AM   #143
micoulisninja
modaholic junkie
Old August 24th, 2014, 10:19 AM   #144
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Sorry if this was already discussed, thread was tl;dr
But, does the ninja 250 seat fit the ninja 300?
Thanks
Be careful. Remember you are
invisible
Old August 24th, 2014, 11:27 AM   #145
Rassie
Rassie's Avatar
Yes for the 2013 plus fuel injected model 250. No for the 2008 to 2012 pre fuel injection models.
Old August 24th, 2014, 11:33 AM   #146
Yes for the [EX250L] (2013+ 250). No for the pre[vious] models.
FTFY
Old August 24th, 2014, 01:01 PM   #147
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Dang it, I was hoping that when I eventually move up to the 300 I could take my corbin seat
invisible
Old August 25th, 2014, 08:14 AM   #148
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Yea, would have been nice to leave the seat pan the same.
Raven's Rejuvenation
Old August 5th, 2015, 11:23 PM   #149
feernando
Motorcycle(s): ninja 300 ninja 250 project
do the rims swap with ninja 300
feernando is offline   Reply With Quote
Old August 5th, 2015, 11:23 PM   #150
feernando
from a new gen 250 ^^^^
Old August 6th, 2015, 10:06 AM   #151
Rassie
Rassie's Avatar
Yes the rear will bolt right in, but remember it is a little narrower. The front will also go right in but you will need a spacer to insert where the speedo drive used to be or just keep the speedo drive. Also the 250 front rotor is a 6 bolt versus the 5 bolt on the 300, so you will have to keep the 250 rotor. They seem to be the same size otherwise. Not sure about the caliper mounts, they seem to be in the same position after quick measurement.
Old March 16th, 2016, 08:30 PM   #152
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I know there was mention about the 08-12 250 front wheel being compatible with the 300. Would it work with the ABS version of the 300? I'm assuming, if I purchase the correct ABS part, it'll swap right onto the 250 wheel?
EDIT: Looks like it won't work. The bolt pattern is different for the rotor/ABS. 5 bolts vs 6 bolts.
Riding it like I financed it.
PARTS NINJAS FIRST NINJA 300 PART OUT! Full 2013 Ninja 300 in good shape! NEED PARTS? PartsNinja Motorcycle-related 75 October 23rd, 2016 04:08 PM
Talk about wrong time, wrong place tlhamon General Motorcycling Discussion 8 February 1st, 2015 12:07 PM
Will certain parts from my old 250r that will fit the new 300? Hitman 2013 - 2017 Ninja 300 Tech Talk 4 October 20th, 2012 06:59 AM
[topix.net] - On Two Wheels: It's time to talk laws and safety for motorcyclists Ninjette Newsbot Motorcycling News 0 June 15th, 2011 03:20 AM
[topix.net] - Bike Helmet With Built In Headset Lets You Ride And Talk At Same Time Ninjette Newsbot Motorcycling News 0 January 10th, 2011 02:20 PM
