Old July 9th, 2013, 07:00 AM   #1
focus101
Motorcycle(s): 96 250
Exclamation rear wheel wobble
hey guys i had my bike on the center stand and started it and put it in 1st i hit the gas a few times lightly just to check a few thing and i notices the rear wheel was wobbling slightly, can this be an alignment issue or tire balancing
shawn
focus101 is offline   Reply With Quote
Old July 9th, 2013, 07:10 AM   #2
AdhesiveTransfers
Expectations=Limitation
AdhesiveTransfers's Avatar
Motorcycle(s): 2009 Ninja 250
the bearings ?
~www.AdhesiveTransfers.com
_______________NINJA250_____________________
*Riding Rev Limits*
AdhesiveTransfers is offline   Reply With Quote
Old July 9th, 2013, 07:20 AM   #3
Check;
Alignment
The tire's carcass and overall usability
Balance
Bent wheel
Bearings
Old July 9th, 2013, 08:39 AM   #4
focus101
think the alignment is gonna be the first thing i check, its not making any noise indicating that the bearings are bad and tire looks fairly new..
Check;
Alignment
Balance
Bent wheel
Bearings
Old July 9th, 2013, 01:00 PM   #5
shawn
The swingarm pivots on two needle bearings that are seldom serviced.
If they are worn, the pulsing action of the engine via the chain will swing the arm and tire sideways.
With engine off, grab the frame with one hand and try to move the swingarm sideways, grabbing it by the axis of the wheel.
That will check those needle bearings and pivot shaft.
Then, grab the swingarm at the same point with one hand and try to move the wheel sideways, grabbing it by the most rear point.
That will check the bearings of the wheel.
If all that is OK, then follow the line of the tire that runs close to the border of the rim on each side.
They should keep the same distance all around on both sides, otherwise, the tire has been incorrectly installed.
If the wheel is bent, you will be able to see it while rotating it by hand (engine off).
Old July 10th, 2013, 07:10 AM   #6
focus101
the bearings are fine but ive notices that the wheel hasn't been balanced, theirs no weights on it..
thanks for the input
Old July 10th, 2013, 07:13 AM   #7
No weights doesn't mean it's not balanced. I have had at least 4 or 5 wheel/tire combos that balanced without weights.
Old July 10th, 2013, 09:15 AM   #8
focus101
think imma take the wheel off and check it and see if its damaged..
Old July 10th, 2013, 09:22 AM   #9
I hope the best for you Shawn. If your wheel is bent you have a few options. There are companies that can straighten a bent wheel. Cost for a 250 wheel should be around $100 bones and a week or so of time.
While not ideal, your rear shock will eat up a lot of rear wobble. The rear wheel of my R6 track wheels is slightly bent with a ding on the lip as well. And trust, I show it no mercy either.
In general, what I am saying is.... if it's not a real problem, do not fix what is not broken. Know what I mean?
Last futzed with by csmith12; July 10th, 2013 at 10:32 AM.
Old July 11th, 2013, 05:29 PM   #10
focus101
its no problem when I'm riding but, I'll put some miles on the bike and see how it performs, thanks for the input..
Shawn
Rear shock set to high (rear wheel slipping)? passive101 2008 - 2012 Ninja 250R Tech Talk 6 August 10th, 2014 08:45 PM
08+ rear wheel, right rear set, rear brake system, seat cuong-nutz Items Wanted 2 October 6th, 2013 05:37 PM
Rear wheel spitting up onto the fender & rear seat. Solutions? uKER 2013 - 2017 Ninja 300 Farkles 21 July 29th, 2013 01:00 PM
rear wheel help! bamaland 1986 - 2007 Ninja 250R Tech Talk 21 September 10th, 2010 04:48 AM
