Old May 8th, 2013, 08:44 AM   #1
set608
Motorcycle(s): 2005 Ninja 250
New headlight bulb???
Its time to replace myn. What would be a nice upgrade in power that i could do for more lumens. The bike is stock no extra electrical upgrades. Also with seafoam. Can i pour it down the vacuum line and which line is that?
set608 is offline   Reply With Quote
Old May 8th, 2013, 09:18 AM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
See the simmilar threads section below.
Philips xtreme vision 100% are consistsntly reviewed as the best H7 bulbs.
Old May 8th, 2013, 10:09 AM   #3
DaBlue1
DaBlue1's Avatar
Phillips Motovision Bulbs for motorcycles is a good choice. Google search the forum for reviews.
Do Not Put SeaFoam in a vacuum line ! If you use it, use the recommended dosage and put it directly into the fuel tank. Another alternative is Star Tron Fuel Treatment.Star Tron also makes a marine formula, however you don't have to worry about over dosing or getting the mix ratio wrong. You can buy it the same places you find SeaFoam.
headlight bulb james250ninja 1986 - 2007 Ninja 250R Tech Talk 1 September 4th, 2014 05:36 AM
Headlight bulb replace Bill N 2008 - 2012 Ninja 250R Tech Talk 13 June 26th, 2014 08:07 PM
What headlight bulb are you using? agentbad 1986 - 2007 Ninja 250R Tech Talk 16 May 22nd, 2014 08:44 PM
headlight bulb recommendation eddiekay General Motorcycling Discussion 13 July 2nd, 2013 09:26 PM
Headlight bulb keeps blowing caps 2008 - 2012 Ninja 250R Tech Talk 11 August 31st, 2011 06:17 AM
