Old August 29th, 2011, 05:17 PM   #1
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
Headlight bulb keeps blowing
So.... My headlight keeps blowing. I don't know why and this is my daily driver
Any ideas? No blown fuses either, just 2 bulbs in the last 2 days. I haven't changed anything recently either.
Also, my high beam socket isn't connected to anything and just dangles. Could that be it?
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
caps is offline   Reply With Quote
Old August 29th, 2011, 05:18 PM   #2
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
But it's been dangling like that for a while and the bulbs just started blowing, right?
Trailerboy531 is offline   Reply With Quote
Old August 29th, 2011, 05:24 PM   #3
caps
Sexy Beast
caps's Avatar
yup
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old August 29th, 2011, 06:15 PM   #4
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Mine blew my new bulb, I ended up having the harness backwards (at lest this what I guess it was). I had my black/yellow wire on the bottom post (it needs to be on top (toward windscreen)). Mine hasn't blown since I changed this.
Old August 29th, 2011, 06:19 PM   #5
rockNroll
rockNroll's Avatar
Motorcycle(s): black
You aren't touching the glass of the new bulb, right?
Old August 29th, 2011, 06:26 PM   #6
caps
Sexy Beast
caps's Avatar
nope, i know the oils would make it blow
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old August 30th, 2011, 08:49 AM   #7
dubojr1
dubojr1's Avatar
Just for giggles... check the voltage at the plug while the bike is running.
Old August 30th, 2011, 06:33 PM   #8
caps
Sexy Beast
caps's Avatar
Well I havent done anything other then change the bulb and it hasn't blown. I'm keeping my fingers crossed.
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old August 30th, 2011, 07:40 PM   #9
leed
leed's Avatar
Motorcycle(s): Time will tell
For the record, H7 bulbs do not have polarity. Aaand, oils will make it explode, not just burn out!
As for bad bulbs.. It could be loose parts or missing dampers. If there's too much vibration, the filaments will break! Or you may have just gotten unlucky with the bulb you bought. Did you replace your bulb prior to this? Or had the one prior to this been in there for a while?
Old August 30th, 2011, 07:54 PM   #10
caps
Sexy Beast
caps's Avatar
Bike's 5 months old, first replace
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old August 31st, 2011, 05:30 AM   #11
dubojr1
dubojr1's Avatar
Does the bulb plug in snugly. I had to tighten my connectors some to help mine fit better.
Old August 31st, 2011, 06:17 AM   #12
caps
Sexy Beast
caps's Avatar
I hadn't thought of that, next time I have to take it apart I will check the connectors
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
headlight bulb james250ninja 1986 - 2007 Ninja 250R Tech Talk 1 September 4th, 2014 05:36 AM
What headlight bulb are you using? agentbad 1986 - 2007 Ninja 250R Tech Talk 16 May 22nd, 2014 08:44 PM
New headlight bulb??? set608 1986 - 2007 Ninja 250R Tech Talk 2 May 8th, 2013 10:09 AM
Headlight fuse keeps blowing iangee 2008 - 2012 Ninja 250R Tech Talk 5 May 26th, 2012 01:00 AM
Keep blowing headlight fuse! Hexdex 2008 - 2012 Ninja 250R Tech Talk 8 October 26th, 2010 07:01 PM
