Old December 23rd, 2013, 02:09 PM   #1
Lucagst
Lucagst's Avatar
88-94 cdi swap in 08-12 new gen wiring help
Hello everyone. I am in the process to replace my 2008-2012 cdi with the 88-94 cdi because it is giving me problems with rpm needle jumping around and performance loss.what I want to know is if someone could help me with wires colors from the 2008-2012 wire harness go to wich pin in the 88-94 cdi. I ask because I do not want to buy a wire harness from 88-94 because i want to make my own harness.i find the post where they made the 88-94 cdi swap but they do not specify the colors of the wires harnes of the 2008-2012 that go direct into the 88-94 cdi pins because they using the pregene harnes.i wanto make my own.tank you in advance for the reply
Lucagst is offline   Reply With Quote
Old December 23rd, 2013, 02:49 PM   #2
I thought that @g21-30 was pretty well-versed in the CDI wiring.
Old December 26th, 2013, 10:34 AM   #3
g21-30
g21-30's Avatar
If you reference the DIY on Diagnosing problems with the CDI, you would have seen the diagram that is attached.
With the following info taken from the DIY, your question is answered:
After removing the original CDI and disconnecting the original wiring harness, I then used a razor knife and carefully sliced down the center of the harness and peeled back the electrical tape. This exposed the eight wires; however, only 7 will be re-used, since the '88-94 CDI only has 7 connections!!
Next it was just a matter of connecting 6 matching pairs of colored wires. The one remaining wire pair (solid Red ['88] and Brown with black stripe ['08+]) were then connected. Just to show how confident I was that this was going to work, I didn't bother disconnecting the battery. Just make sure the Red and Br/Bk are the last wires connected and DON'T let the plyers touch the frame.
Old February 8th, 2014, 06:37 AM   #4
Lucagst
Lucagst's Avatar
Hi all I just installed the 88-94 cdi it started at first try bot the tach still jumpi I don't know wat the problem is, need of edvice tanks in advance.
Old February 24th, 2014, 06:02 PM   #5
Lucagst
Lucagst's Avatar
Problem solved..... I connected the rpm wire from the koso rx2n gauge direct to the pickup coil yellow wire and problem went away
Need help with 88-94 CDI wiring KrazyWalle 2008 - 2012 Ninja 250R Tech Talk 7 March 3rd, 2014 12:44 PM
CDI wiring help V2Neal 1986 - 2007 Ninja 250R Tech Talk 9 January 26th, 2014 01:14 PM
CDI Pinout/Schematic/Wiring indr 2008 - 2012 Ninja 250R Tech Talk 2 January 28th, 2013 09:56 AM
wiring harness and pregen cdi thomason2wheels 2008 - 2012 Ninja 250R Tech Talk 10 November 13th, 2012 08:50 AM
CDI wiring question PeeFo 1986 - 2007 Ninja 250R Tech Talk 8 January 10th, 2012 10:45 PM
