Old December 19th, 2011, 06:37 PM   #1
PeeFo
Motorcycle(s): 1989 250 ninja
CDI wiring question
Hey guys I have an 89 bike and the CDI crapped out for the second time on me. I ordered a new one off of ebay and they sent me a CDI for a 95-2007 bike. After some searching it seems like I can swap pins in my connectors and add a resistor to make this thing work on my bike. The only problem Im having is that the wiring diagram for both bikes tell me the wire colors but I dont know which wires go to which pin. Has anybody done this before or could you maybe get a picture of the connectors for a 95-2007 box.
Thanks guys
PeeFo is offline   Reply With Quote
Old December 20th, 2011, 07:56 AM   #2
Jinx250
Smoker
Motorcycle(s): Guess....
You can't make that work on your bike. It's not just the pins, but the stator also. For $25 shipped my bud can get you a working one from an 88/89. Plug and play, no mods.
Jinx250 is offline   Reply With Quote
Old December 20th, 2011, 08:41 AM   #3
el250
no such thing as ninjette
Motorcycle(s): (2) 1987 EX250E2, 1989 EL250B3, 1991 EL250E1, (3) 2005 EX250F19, 2007 EX250F7F, soon to add more..
It will work by re-pinning the connector wires, it is the 1986-1987 that won't because of th stator rotor and it having two pickup coils and being analog.
As he has searched for and found, there is one extra wire that is needed with that gray wire.
These are label up view of igniter connector pins.
* = switched power through resistor
Might as well post this one too..
Anyone see any mistakes on my diagrams, let me know.
I would check why you are killing igniters. I would think you have other problems with wiring or a safety switch that makes the igniter look dead.
Have your old "dead" igniters still?
I'll buy them cheap so I can test them, since I am not that far from you. Very curious what is dying on them.
el250 is offline   Reply With Quote
Old December 20th, 2011, 02:40 PM   #4
PeeFo
Thanks el250, Im going to go give it a shot right now.
If you want my old ignitors you can have them. I don't know what was killing them but the guy at a local store told me the newer ones should be more reliable. I tested the old ones per my manual and the resistance values were way out of line.
Old December 20th, 2011, 06:27 PM   #5
PeeFo
Just to update, I swapped wires and soldered in my 100ohm resistor and she fired right up. Good info in this thread
Old January 10th, 2012, 09:06 AM   #6
Palero
Palero's Avatar
Motorcycle(s): 1988 Honda Hawk GT 1989 EX250F (Died from left-turning car) 2011 EX250J (Died from SAME left-turning car)
Where do we install the 100ohm resistor?
Palero is offline   Reply With Quote
Old January 10th, 2012, 12:44 PM   #7
if something keeps going bad, theres probably a reason. check your regulator output voltages.
Old January 10th, 2012, 09:57 PM   #8
el250
Resistor and extra wire is only needed if going from a 1988-1994 igniter to a newer igniter and you have 1988-1994 ignition switch and wiring harness.
1995 and newer ignition switches have the resistor under the plastic cap in its wiring.
If switching to a new igniter on 1988-1994, the resistor goes between a switched +12vdc to the gray wire pin on igniter.
IMHO, 1988-1994 igniter are the better igniter.
If replacing, to a third party igniter (BRT) or to FI controller, there is no need to worry about the resistor since it is only a Kawasaki (well actually, denso) anti-hotwire feature.
Old January 10th, 2012, 10:45 PM   #9
Palero
Palero's Avatar
Thanks for the info.
I'm planning on going from my 1988-1994 igniter to the Ecotrons Ninja 250 EFI setup here http://www.ninjette.org/forums/showthread.php?t=92261
Need help with 88-94 CDI wiring KrazyWalle 2008 - 2012 Ninja 250R Tech Talk 7 March 3rd, 2014 12:44 PM
88-94 cdi swap in 08-12 new gen wiring help Lucagst 2008 - 2012 Ninja 250R Tech Talk 4 February 24th, 2014 06:02 PM
CDI wiring help V2Neal 1986 - 2007 Ninja 250R Tech Talk 9 January 26th, 2014 01:14 PM
CDI Pinout/Schematic/Wiring indr 2008 - 2012 Ninja 250R Tech Talk 2 January 28th, 2013 09:56 AM
wiring harness and pregen cdi thomason2wheels 2008 - 2012 Ninja 250R Tech Talk 10 November 13th, 2012 08:50 AM
