Old August 28th, 2016, 09:39 PM   #1
The Seldom One
Motorcycle(s): 2012 Kawasaki Ninja 250
Where do you buy your Valve Shims?
Hey I have ANOTHER question.
I figured I would be able to easily find a valve shim kit for my bike. Apparently that isn't how it works.
General google searches bring up shim kits, but they aren't specified to fit my bike. I also can't find out info on the shims so that I might be able to order some based on just the size.
So, does anyone know where I can order a kit from? or individual shims that are in .025 increments instead of the poem .05
I would rather buy a kit, seeing as they run the same price as 8 new shims.
Thanks.
The Seldom One is offline   Reply With Quote
Old August 28th, 2016, 09:52 PM   #2
empire00
empire00's Avatar
Motorcycle(s): 2009 250r SE, 2015 FJ-09
I bought a kit from amazon.
https://amzn.com/B000UKM6LG
empire00 is offline   Reply With Quote
Old August 28th, 2016, 10:08 PM   #3
The Seldom One
How did you know they fit?
Old August 28th, 2016, 10:31 PM   #4
empire00
empire00's Avatar
If you set your bike in your Amazon garage it will tell you. I also checked the size in the service manual.
Old August 28th, 2016, 10:46 PM   #5
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
I followed the link above: It comes up that this kit does NOT fit a 2012 Ninja 250!
(We are in the 2012 forum section)
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old August 28th, 2016, 10:54 PM   #6
empire00
empire00's Avatar
We are in the 08-12 section and it does fit my 09. I was unaware that there was a difference in the shims from 08 to 12
Old August 28th, 2016, 11:00 PM   #7
The Seldom One
there isn't, but when ever I put the bike in the "garage" section it says it does not fit, and most of these kits don't specify the diameter of the shims. I did find out that the diameter we need is 7.48mm and hot cams hcshim01 is 7.48mm. Looks like I'm going to go ahead and grab those, I was going to order from an online dealer with free shipping, but don't want to wait until September 10 to put this bike back together.
Thanks for your help guys.
Old August 29th, 2016, 12:15 AM   #8
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
Good to know they fit regardless the garage says no! I'm about to crack the covers on my bike this week for its first check (11,000 km). Hopefully; I won't need shims but that's a great link for if I do!
Old August 29th, 2016, 05:25 AM   #9
ducatiman
ducatiman's Avatar
As Amazon listing unclear...always good habit to cross check and verify listings at the manufacturers website using the part # listed.
hotcamsinc.com
Description:
7.48mm Complete shim kit 1.20-3.50mm in .05mm increments with 3 shims in each size
Part Number: HCSHIM01
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old August 29th, 2016, 08:20 AM   #10
The Seldom One
I'm at roughly the same miles as you and my exhaust valves were out of spec (tight), only cylinder 2 on the intake was a hair out of spec and I'll be able to swap two of the shims around.
When you remove your valve cover, be careful with that coolant hose that goes into the cylinder head. Mine had a lot of dirt wedged between it and the valve cover, and when I took the cover off, guess where it went?
Learned my lesson to wash the bike before doing work.
@ducatiman Yep! Thanks
Old August 29th, 2016, 08:39 AM   #11
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I trade mine in at the local bike shop, no charge if you just swap them out
Old August 29th, 2016, 08:40 AM   #12
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Was gonna say just this!
Goin' fast on slow bikes!
Old August 29th, 2016, 09:04 AM   #13
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
^ Just make sure you measured everything right before you do it. Since you don't have numerous choices on hand you have to go back to the shop if you made a mistake
measure 10x cut once type thing
Old August 29th, 2016, 09:12 AM   #14
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
One more thing: Use a micrometer and NOT a caliper.
Make a chart with the layout of the valves. Use this for the shim thickness and the lobe to bucket gap. Draw a box on it and place the shim on the chart so they don't get messed up.
Personally, I use old mini muffin tins for this sort of work. The mini's are smaller cups and you can use it for nuts, bolts and all kinds of other things too. You can keep the shim and the valve cup in the same hole. Keeps you organized!
http://www.bedbathandbeyond.com/stor...tegoryId=12598
Old August 29th, 2016, 09:58 AM   #15
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I love little tricks like that. I've always used egg cartons myself
Old August 29th, 2016, 10:01 AM   #16
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Even cheaper!
Old August 29th, 2016, 10:10 AM   #17
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Originally Posted by RacinNinja View Post
Even cheaper!
Plus you get some good protein out of it!
Old August 29th, 2016, 12:01 PM   #18
cuong-nutz
cuong-nutz's Avatar
X2 on the micrometer. This will give you the most accurate measurement although you can get a semi close enough measurement with a caliper.
I buy shims in bulk (4 pack) of the sizes I know I will need and mostly from Ebay.
HalfFast Racing Team
Stacking valve shims corksil 2008 - 2012 Ninja 250R Tech Talk 8 July 2nd, 2015 11:03 PM
Anyone stock valve shims in SoCal yblaser Items Wanted 1 June 23rd, 2012 08:34 PM
Where to find shims for valve adjustments cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 7 December 12th, 2011 06:42 PM
Valve Shims questions kashun84 2008 - 2012 Ninja 250R Tech Talk 3 December 9th, 2010 12:35 PM
Buying valve shims... headshrink 2008 - 2012 Ninja 250R Tech Talk 4 March 5th, 2010 01:24 PM
