Old September 6th, 2011, 01:24 PM   #1
akima
Nooblet
akima's Avatar
MOTM - Oct '13
U-turns on a Ninjette
I learnt to ride on a 125 Standard-type bike. I found that performing U-turns was a piece of cake <-- HIGHLY relevant ok! The bunny is doing u-turns with a cake!
I've only ridden my Ninjette about a dozen times, so I shouldn't beat myself up about it, but I find u-turns really difficult on it.
On the 125 I went really slowly during the manoeuvre; about walking pace. I also kept the 125 almost completely upright (no lean). I feel like the Ninjette wants to tip over during the manoeuvre, whereas the 125 felt completely stable. The Ninjette also seems to have a much bigger turning circle.
Do you think it has to be done faster on the Ninjette so that I can get in more lean so that I can get a tighter turning circle.
Any thoughts or advice is welcome
Old September 6th, 2011, 01:32 PM   #2
Some relevant threads.
http://www.ninjette.org/forums/showthread.php?t=81267
http://www.ninjette.org/forums/showthread.php?t=25993
http://www.ninjette.org/forums/showthread.php?t=13515
Old September 6th, 2011, 01:54 PM   #3
keep the gas on. don't be afraid to go a little bit quicker than you did with the 125, it's heavier and needs more gyro force from the wheels to stay up. leaning is not bad. right next to my house i have to pull a u-turn in about 10 feet of road-width... first couple times i freaked and almost pulled it up and would've hit the curb... just stay on the gas and push her down, she'll turn. just make sure you practice where you won't hit a curb
Old September 6th, 2011, 03:47 PM   #4
WhiteRice
Kamikaze Squirrel
WhiteRice's Avatar
Motorcycle(s): 2010 250r
Gah u-turns! I dropped my bike on my first day out trying to get out of a dead end. Just take it to a parking lot and get plenty of practice.
Ride the rear brake a bit. Swivel your head toward where you're going! Lean your bike toward the turn and get your weight on the outside peg.
WhiteRice is offline   Reply With Quote
Old September 6th, 2011, 04:04 PM   #5
akima
Nooblet
akima's Avatar
MOTM - Oct '13
I read those other forums posts Alex. Thanks.
Thanks Alex.s and WhiteRice too. Your advice seems to echo what everyone else is saying.
I've already had a fair bit of practice doing u-turns... I've gotten lost lots I think I'll take what I've learnt to a parking lot and start with a big turning circumference and work my way down to ON THE SPOT BURN-OUT ROTATION!! jk
Old September 6th, 2011, 04:14 PM   #6
don't forget if you somehow get boxed in by stupid cars parking where they shouldn't and fancy yourself fit enough (and trust your kickstand, and don't care about the asphalt you're about to destroy) you can always balance the bike on the kick stand while you rotate it around. might be easier than the burnout. generally speaking of course this is a last-case scenario and there's probably a better way to move the bike. also if you do it enough your kickstand/kickstand mount starts to bend and then when you set it down on the kickstand with a bend mount, it sets down... then goes a little bit further. also there's a chance of simply breaking the kickstand all together and dropping your bike.
Old September 6th, 2011, 05:01 PM   #7
ally99
Ninja chick
ally99's Avatar
MOTM - Dec '13, Feb '15
Look where you want to end up! Sometimes that means you're actually turning your head and looking backwards as you are initiating the lean. Weird, but the bike follows where you are looking!
Postwhores are COOL! ~Allyson
Old September 6th, 2011, 06:41 PM   #8
RedOctober
RedOctober's Avatar
Motorcycle(s): 2012 Ninja 250, 2008 Daytona 675
I'm exact opposite
I "learned" to ride in MSF...first day was on Kawa Eliminator 125cc. 2nd day was on pre-gen Ninja. I found Ninjette to be a lot more stable and easier to turn (almost nailed the box double-U turn). Push her down, give her gas, she'll do the work.
RedOctober is offline   Reply With Quote
Old September 12th, 2011, 10:51 AM   #9
KawiKid860
KawiKid860's Avatar
+1 for the eliminator haha... I actually learned to do a U-turn on my Ninja 500 in parking lot sessions before I got my endorsement, and I got to doing them nearly flawlessly. I friction zone it going into the turn then slowly let out and give it a little gas to accelerate out for the smallest radius turn, but I can idle through it within the 20' box idk if that's possible with the ninjettes seeing as my bike has quite a bit more low end :P. The eliminator sucked it was all wobbly which was probably partly my technique but I made it within the box!
Old October 13th, 2011, 09:45 AM   #10
nit8690
nit8690's Avatar
Motorcycle(s): Ninja 250r soon
My fear right here lol. I learned on about a dozen different bikes lol. most recent being a 200 cc dual sport that team orgeon provides. its small and is pretty nimble. we had to do the u turns and the sharp 90. on those I found that if you keep yourself straight up but lean the bike it helps alot. the second course I did was a rider practice and they put us on this course it started with a sharp 90 then to this figure...v I guess lol where we did 5 u turns. take a corner swerve another corner acclerate to a set speed and stop after a cone and stop quick if it makes sense lol but the 1st time we were all so confused we sucked. then did some stuff and did the course the 2nd time. I had it down and I was in that zone.went from taking I think 2 minutes to do the course to just over a minute. lol move to oregon and do the rider skills practice lol
Or find a cone of some shorts or somthing you can turn around and just do it a few times...lean the bike keep yourself up it works lol
Getting a ninja 250 asap
nit8690 is offline   Reply With Quote
Old October 13th, 2011, 10:28 AM   #11
akima
Nooblet
akima's Avatar
MOTM - Oct '13
I've actually got it pretty much down now. I don't really have to think about it anymore. I even had a biker in full leathers walk up to me and complement my skills when I was parking. He recognise my bike as a Ninja 250r and said he was considering getting one for his gf to replace her R1 (which she struggles with). I guess our bike is much lighter and more nimble than most sports bikes. Recently, I've been wondering more and more why people even buy the big engine bikes. I went to London yesterday and had no trouble following the paths through the traffic that the nimble scooters were taking. I also got up to 90mph on the motorway home so I easily kept up with the flow.
Old October 13th, 2011, 10:36 AM   #12
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
I still find myself putting my feet down at times while u-turning on the 250; I have absolutely no problem u-turning on my zx6r though. The zx6r has a little bit of a wider turning radius but not much. The 250 just doesn't feel nearly as stable as my zx6r for some reason; I have a feeling it's the wider rear tire allowing more traction and thus more confidence while turning at low speeds.
Live2ride is offline   Reply With Quote
Old October 13th, 2011, 11:04 AM   #13
totaled
totaled's Avatar
Motorcycle(s): '09 Ninja 250-SOLD
I found myself watching the bunny hop back and forth thinking it was going to do something different.... what's this thread about?
"I've given up reading books. I find it takes my mind off myself. -Oscar Levant
totaled is offline   Reply With Quote
Old October 13th, 2011, 11:05 AM   #14
Numbersix
Numbersix's Avatar
Motorcycle(s): Honda Elite 110 (deceased), Green 2012 Ninja 250 (sold on Pi day); Grey/Green 2019 Ninja 400 ABS
Agreed on all points; the Ninja isn't quite as darty as my Elite (that's Lead 110 to you in the UK) but nearly so.
My low-speed cornering drill is to go to a parking lot, find a storm drain and circle it repeatedly in one direction, then the other, as tightly as possible without bobbling.
That seems to work for me to build the muscle memory for the right body position, clutch slipping, and throttle; I'm certainly not close to perfect, but that drill helps me improve.
Numbersix is offline   Reply With Quote
Old October 13th, 2011, 12:00 PM   #15
akima
Nooblet
akima's Avatar
MOTM - Oct '13
That's a good idea. I think I'll try and get some more low speed practice in soon. I still can't come to a complete stop and keep my feet on the pegs. Seems as soon as I stop I start tipping.
How far can you look through the turns? csmith12 Riding Skills 88 April 28th, 2015 12:49 PM
what turns you have problem with the most...? RJprod Riding Skills 12 June 6th, 2013 07:44 AM
Downshifting for turns dcx4610 Riding Skills 106 October 24th, 2012 01:31 PM
Taking turns TnNinjaGirl Riding Skills 51 August 3rd, 2012 04:32 PM
Slow U Turns Liber Riding Skills 17 August 14th, 2011 07:35 PM
