Old July 28th, 2023, 03:56 PM   #1
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
My turn!
Just bought a Ninja 650. squeee!!!!!!
Old July 28th, 2023, 05:06 PM   #2
ducatiman
ducatiman's Avatar
'GRATS !
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old July 28th, 2023, 06:28 PM   #3
Woohoo!! Let's see some photos in this thread!!
https://www.ninjette.org/forums/showthread.php?t=396208
Old July 28th, 2023, 08:27 PM   #4
CaliGrrl
CaliGrrl's Avatar
I decided what I wanted, and called a couple of dealers to get it. ABS, KRT paint, new, and she's mine! I think her name might be Ivy.
Old August 4th, 2023, 10:13 PM   #5
CaliGrrl
CaliGrrl's Avatar
Manual says to keep the RPM under 4000 for the first however many miles.
They don't tell you it's hard to do.
This bike wants to go. Holy carp. Let the clutch out in first? 3000rpm. I'm only at 45mph when I hit sixth gear.
Will be glad when the break-in period is over. OOoh, she sounds pretty, though. Her name has settled down and she is Poison Ivy. I tried to reconcile Tinkerbell, but no. Same with Sprite. Too cutesy for this bike.
Old August 5th, 2023, 05:24 AM   #6
When I got my 2020 Yamaha MT-07 it had some restrictions on RPM like that. I took it to redline a couple times on the way home from the dealer, and opened the throttle at various RPMs several times in the 50 mile ride. The idea was to get the rings seated before the cylinders smoothed up too much. Now its oil level doesn't change visibly in 5,000 miles, so I'm thinking this break-in method has merits.
Old August 5th, 2023, 05:30 PM   #7
CaliGrrl
CaliGrrl's Avatar
Nice. I haven't taken it to redline but I've run it up a bit a few times.
Old August 6th, 2023, 08:33 PM   #8
You don't have to rev it up, but within 1st 100-miles, you should give it the beans to maximize cylinder-pressure to push rings onto cylinder-walls...
This isn't some '50s-tech cast-iron engine with tolerances in 1/1000th-inch that requires grinding lots of cylinders away to make parts fit. That's mostly done already through precision machining within 1/10000th-millimetre along with plateau-honing. Break-in is just final stage of seating rings onto surface.
They most likely didn't put in old-style single-weight dino oil that burns easily, so you don't have to worry about too much glazing cylinders. Don't let it idle too long, maybe adjust idle to 1500rpms. And vary RPMs and load/throttle (don't ride at steady speed). Gradually add load/throttle, 50%, 75%, 100% by 100-miles.
https://www.motorcyclistonline.com/b...break-in-myth/
Might be good idea to send in 1st-oil change sample for used-oil analysis to Blackstone Labs to get baseline reading for engine. Get TBN option.
Last futzed with by DannoXYZ; August 7th, 2023 at 09:41 AM.
Old August 8th, 2023, 04:16 PM   #9
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Congratulations! We wanna see a pic or two...
Old August 8th, 2023, 06:35 PM   #10
CaliGrrl
CaliGrrl's Avatar
This bike is so much fun!
Old August 8th, 2023, 06:36 PM   #11
CaliGrrl
CaliGrrl's Avatar
Sorry about the sideways thing...
Old August 21st, 2023, 07:12 PM   #12
CaliGrrl
CaliGrrl's Avatar
Title arrived in the mail. squeeeeeee!!!!!
Still waiting for the plate so I can try for a personalized one.
Old September 15th, 2023, 06:35 AM   #13
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
Cool I got a 22 Z650 last year
shspvr is offline   Reply With Quote
Old September 15th, 2023, 07:41 AM   #14
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Congrats!
[RideApart] - 2023 Ducati DesertX Gets Integrated Turn-By-Turn Nav, New Graphics Ninjette Newsbot Motorcycling News 0 February 3rd, 2023 01:15 PM
[visordown.com] - Ducati announces Turn-by-Turn navigation for 2023 DesertX, Diavel V Ninjette Newsbot Motorcycling News 0 February 2nd, 2023 04:38 AM
[webbikeworld.com] - Ducati?s 2023 Desertx and Diavel V4 to Carry Turn-By-Turn Naviga Ninjette Newsbot Motorcycling News 0 February 1st, 2023 10:51 AM
[motorcyclistonline] - Left Turn Or Right Turn: Which Is Your Bad Side? | CODE BREAK Ninjette Newsbot Motorcycling News 0 August 21st, 2015 09:20 AM
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
