July 28th, 2009, 11:24 PM | #1 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
Keihin Needle Jet size
Keihins numbering system is royally irritating. Does anyone know what the oem needle in our carbs is? I'm usually pretty good with this but after an hour I am humbled and confused.
Sportisimoto USA is born. |
July 28th, 2009, 11:40 PM | #2 |
Join Date: Jun 2009 Motorcycle(s): 2007 Suzuki GSX-R750 Posts: 378
I think its a 98 but I know the dynojet 98 is different from the stock 98... Not sure about keihin
July 28th, 2009, 11:44 PM | #3 |
The Sportisi Master
That is the main jet size. I am talking about the needles.
July 28th, 2009, 11:47 PM | #4 |
lol, my bad...I think its time I go 2 sleep...
July 29th, 2009, 12:14 AM | #5 |
you do all this work with the 250R and you don't own a service manual?
http://www.ninjette.org/forums/showthread.php?t=9467 |
July 29th, 2009, 12:58 AM | #6 |
The Sportisi Master
Kelly that is stuff I do know and yes I have a service manual but I'm trying to figure something out. The thing is I'm trying to wiggle my way around and find a needle replacement for a guy rather than him buying a jet kit. Because $90 is ridiculous if you can do it cheaper. I have DJ needles just trying to see if there is something comparable that doesn't require a $90 kit.
July 29th, 2009, 05:25 AM | #7 |
IC2(SW)
I can barely even see the stock needles...... there so dam small
Is this the chart you were looking at? Looks like you just convert stock numbers to option numbers. Maybe give cpw a call: http://www.carbparts.com/keihin/need...et_needles.htm |
July 29th, 2009, 11:01 AM | #8 |
The Sportisi Master
Ya I went cross eyed after seeing that the first time. now they are stuck that way
Stock Needle Size? | RobDog | 2008 - 2012 Ninja 250R Tech Talk | 1 | January 30th, 2015 04:00 PM |
keihin main jet Q?? | cuz | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 10th, 2011 08:27 PM |
Keihin OEM vs Factory Pro jet sizes | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 161 | September 25th, 2010 02:13 PM |
which size needle goes where? | slow_2k10 | 2008 - 2012 Ninja 250R Tech Talk | 7 | September 7th, 2010 01:57 PM |
Keihin Needle Spreadsheet | g21-30 | 2008 - 2012 Ninja 250R Tech Talk | 5 | December 24th, 2008 12:34 PM |
