Old April 2nd, 2012, 03:32 PM   #41
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Originally Posted by Pudge Ate Me View Post
Quick question here,
I am about to install the proton flush mount turn signals. I understand that you do not need to change any wiring for one set of LED's but I am thinking of future intergrated tail light. If I purchase this kit, this will be the only diode thing I will have to do if I get an intergrated tail light and led turn lights correct?
Correct.
The www.ModMy250.com guy
Old April 2nd, 2012, 03:45 PM   #42
Pudge Ate Me
2012 Ninja 250R Green
Pudge Ate Me's Avatar
Motorcycle(s): 2012 Ninja 250R Green
Will I have to replace/change the relay on the back of the bike near the tail light at all if I use this kit?
Pudge Ate Me is offline   Reply With Quote
Old April 2nd, 2012, 04:44 PM   #43
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
Yes, you'll have to go with an electronic flasher if you want your LEDs to work well. As a matter of fact, a relay should be the first thing you'll have change if you're set on going the LED route. I use the Tridon EP34 but I think Tri has a newer one as well.
EthioKnight is offline   Reply With Quote
Old April 24th, 2012, 07:17 AM   #44
Risky
Motorcycle(s): Ninja 250 2012
Yo Tri, how do I go about scoring on of your pre-made up diode kits?
Risky is offline   Reply With Quote
Old April 24th, 2012, 06:59 PM   #45
jasonz1c
jasonz1c's Avatar
Motorcycle(s): Ninja 250R 2008 - Green
http://modmy250.com/LP.html
jasonz1c is offline   Reply With Quote
Old April 24th, 2012, 07:46 PM   #46
Risky
Question
Originally Posted by Redsvt View Post
After removing the connectors I come to find out that I have 2 green wires plug into the #9 connector, not one as the photo indicates. Now I connected everything and all works well, front and rear, horn works, dash lights all come on and the bike starts.
Mine too has 2 green wires in the #9 connector. When you say you "connected everything", are you saying you treated the 2 green wires as if they were 1? if not, how did you deal with the 2 wire issue? no one seems to mention it anywhere but its obviously the norm for the 2012 model.
Old April 24th, 2012, 10:30 PM   #47
CThunder-blue
ModMy250.com
The two green wires are connected together at the same pin, so unless you want to cut the factory wire for some reason, just follow the instructions and you'll be fine.
Old April 27th, 2012, 08:54 AM   #48
Risky
As I'm in Australia outside of shipping range, I whipped up my own no cut kit exactly as per your instructions and it works a charm. Thanks very much for taking the time here as it made a pretty tech job pretty easy for a rookie. Cheers.
Question for you guys though. The diode's work great and now no light whatsoever makes it to the wrong side when indicating. However, apart from my proton which has it's own flasher in built, my other indicators do not flash but rather remain lit constantly. I am running a Narva LED specific relay and this is responsible for this behaviour. I switched out for the stock and got the exact same deal. Waste of money that flasher was ($32!). I have an old electro-mechanical relay which I switched in and it works great, flashing all 3 indicators (I have protons, oberon bar end and oberon LED rear indicators) perfectly in sync. I'd much rather an LED relay as the mechanical makes a loud & very vintage sounding click click click. How is it possible that the LED relay does not work correctly?
Old June 2nd, 2012, 04:55 PM   #49
headshrink
headshrink's Avatar
Just found this... awesome!
Old June 3rd, 2012, 12:19 AM   #50
CThunder-blue
ModMy250.com
Not all electronic relays are made the same way. The LED relays I sell also make the normal clicking sound. If you have it working, I'd just leave it as is.
Old September 30th, 2012, 10:49 PM   #51
psych0hans
psych0hans's Avatar
Hi, If I buy this kit, can I have multiple LEDs for turn signals? Or am I limited to 4? I'm planning on adding more LEDs to the under tail and under my side fairings for turn signals. I'll be using the Tridon EP34 relay.
Old October 1st, 2012, 06:37 AM   #52
CThunder-blue
ModMy250.com
You need this kit if you install more than two led signals. It won't matter how many you install. I have 8 on each side of my bike.
Old February 13th, 2014, 02:50 PM   #53
tmlewis3
tmlewis3's Avatar
Motorcycle(s): 2011 Ninja 250r
Hey, I bought this kit last week and all four of my blinkers were working fine before, but I went ahead and installed this anyway just in case I wanted more LED lights. Now when I put the turn signal on, all four blinkers light up and blink at the same time... any idea what the problem is?
tmlewis3 is offline   Reply With Quote
Old February 13th, 2014, 02:52 PM   #54
CThunder-blue
ModMy250.com
Hmmm, it's possible one of the diodes failed. I'll ship another kit.
Old February 13th, 2014, 03:23 PM   #55
tmlewis3
tmlewis3's Avatar
Ok, thank you. Is it uncommon that all four LED blinkers work without the diode?
Old February 13th, 2014, 04:18 PM   #56
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Diode just restricts the path which the current flows.
Old February 13th, 2014, 05:04 PM   #57
CThunder-blue
ModMy250.com
yeah, without the kit, all 4 would blink at the same time. Make sure your grounding path is clean.
Old February 13th, 2014, 06:06 PM   #58
tmlewis3
tmlewis3's Avatar
That's weird. I grounded it to the bolt shown in this diy.. it's backwards tho. Works fine without the diode, and all four blink with the diode.
Old February 13th, 2014, 06:44 PM   #59
CThunder-blue
ModMy250.com
probably just a failed diode. I'll ship one out this weekend.
Old August 6th, 2016, 01:08 PM   #60
iwanttoridemybike
Motorcycle(s): 2003 Ninja 250
hi! i have the same problem but on my 2003 ninja 250. All the kits say they're only compatible with the 2008-2012 ninjas. I'm wondering if there's a similar kit out there but for older ninjas
iwanttoridemybike is offline   Reply With Quote
Old December 27th, 2017, 03:49 PM   #61
Thugwife
Diode still for sale ?
Please read theGB thread for info. I'm asking people to pm me their email so I can send invoices out.
Hi I was wondering if I can still purchase this diode I know it’s been over 5 years so I wanted to ask . I’m still having issues with all 4 blinkers becoming hazards . Thanks !!
Thugwife is offline   Reply With Quote
Old December 28th, 2017, 12:22 AM   #62
It's a 10-cent part that works much better and more reliably if you take the extra 5-minutes to solder it into harness wiring. Add 5-cents for heat-shrink tubing or electrical tape.
Old December 28th, 2017, 11:08 PM   #63
Here's diode kit designed to be soldered into harness.
https://www.superbrightleds.com/more...diode-kit/1190
Old December 29th, 2017, 08:04 PM   #64
That's beautiful. I did it the hard way when I did that a few years back.
Old March 29th, 2018, 11:16 PM   #65
StrangeRida
Motorcycle(s): ninja 250r
Hi Guys,
Just received my Diode Kit and it was easy to install.
I also got the EP34 Relay now the all 4 blinkers on at same time is fixed but now I have the issue that the lights stay solid and relay is buzzing really loud.
How would I be able to fix this?
Im lost lol
StrangeRida is offline   Reply With Quote
Old March 30th, 2018, 02:04 AM   #66
Something’s not wired properly. Draw a schematic of how you have every single wire connected.
Old March 31st, 2018, 03:09 AM   #67
StrangeRida
I just disconnected old signals and put LED ones on,NO CUT DIODE KIT and EP34 Relay I did make sure i got the polarity right apart from that there has not been any other rewiring been done.
Anything else I need to inspect?
It really sux need the bike on the road ASAP for work.
Old March 31st, 2018, 05:17 AM   #68
Have you tried going back to the incandescent bulbs and factory wiring under the dash to check the turn signal flasher relay? Do you have a spare turn signal flasher relay?
Have you contacted the vendor to help you? Tri is a helpful guy.
Old March 31st, 2018, 05:16 PM   #69
Buzzing relay means it’s got feedback loop going. Some wiring may be crossed. Or relay may be defective.
As mentioned, might be good to undo some of the changes to use process of elimination to narrow down problem area.
1. put everything back to stock and verify everything works correctly as stock
2. Replace only relay. If it buzzes, then relay is bad. Don’t proceed until you get relay replaced
4. Install LED turn signal. Verify they all work and blink. Turn signal indicator should flash
5. Install diodes to fix turn-indicator flashing
Old March 31st, 2018, 10:57 PM   #70
StrangeRida
Thnx for your reply @choneofakind and @DannoXYZ
I pt all stock globes back and went one at a time with LED ones.
Front all good but as soon I plug an LED into the Back wires it Buzzes but if I connect the Old stock one to the same LED ( 3 Signals one side ) it works perfectly. ( Still flashes a bit fast but better then nothing)
Would I need to solder another resistor into the circuit?
Old April 1st, 2018, 11:24 AM   #71
Is this buzzing with stock or EP34 relay?
Did you revert to all stock with stock relay and removed diodes?
Old April 1st, 2018, 12:41 PM   #72
StrangeRida
@DannoYZX I havent solder anything into the circuit yet.was just asking
I did went all stock but my stock relay is starting to fail goes off after few seconds.
But all stock light working perfect with EP34 only blinks a little to fast but its not major.
Buzzing only comes from EP34 as Stock just fails right away and neither side blinks as soon I hook up LED to the rear.
Old April 1st, 2018, 05:39 PM   #73
Stock relay failing and EP34 buzzing are signs you have wiring issue. Probably in the rear leg of circuit. EP34 should flash slower with stock bulbs, so there's definitely a short somewhere.
Does your rear LED come with polarity protection diode? Or are you using voltmeter to find +12v wire?
Old April 3rd, 2018, 08:45 PM   #74
StrangeRida
hmmm weird as I have not touch any other wiring at all just wanted to change over to LED.
What do I need to do next to eliminate the problem?
Any suggestions?
I used a Voltmeter to find the +12V wire
Old April 4th, 2018, 07:38 AM   #75
mgentz
Board Member
I used this kit. Simply awesome and EASY.
https://www.customled.com/products/2...-cut-diode-kit
Old April 5th, 2018, 09:33 AM   #76
Any suggestions?
You have pre-existing issue, so you need to fix that before changing to LED.
1. power-off
2. unplug both rear turn-signals
3. measure resistance to chassis-ground of each wire in each rear turn-signal harness connector (4 measurements total).
4. what are these measurements?
5. measure resistance between each terminal of each rear turn-signal harness connector
6. what are these two measurements?
Old October 29th, 2022, 03:33 AM   #77
trithemonk
Motorcycle(s): 2012 CBR250r and 2012 Ninja 250r
Just installed your kit! It was super easy to install, the instructions are just the right level of detailed, and everything works perfectly now. Thank you so much!
trithemonk is offline   Reply With Quote
DIY - Installing a ZX-6R Master Cylinder VeX 2008 - 2012 Ninja 250R Tech Talk 33 August 27th, 2018 11:30 AM
DIY: Installing the Ecotrons EFI Kit on a Pregen n4mwd Videos 174 May 10th, 2013 08:48 AM
No-cut Diode kit CThunder-blue Motorcycle-related 16 July 24th, 2012 09:37 PM
DIY- Installing Footpeg Extenders kkim 2008 - 2012 Ninja 250R Tech Talk 78 November 20th, 2010 09:58 PM
DIY: Installing Halos tlhamon 2008 - 2012 Ninja 250R Tech Talk 26 October 27th, 2010 08:40 PM
