Old August 9th, 2014, 02:29 AM   #1
Ninja Chris
Ninja Chris's Avatar
Motorcycle(s): 2012 Black & Yellow Ninja 250
Rear shock Preload for 2up?
I searched but could not find guidelines for setting the rear shock up for rider + passenger.
My wife loves to ride with me and I'd like to make sure my bike is set up as best as possible. I've learned to check and adjust tire pressure before each of our rides. The resources I've checked so far detail setting preload for the rider, not the passenger (owners manual, service manual, online guides, Ninjette.org search). You can probably see where I'm headed with my question.
Is it possible to properly set the rear shock for the two of us? (full gear - I'm 165lbs, she's 130lbs)
I should note we haven't had any problems, it's just that I'm learning more and am ready to start fine tuning/customizing.
Ninja Chris is offline   Reply With Quote
Old August 9th, 2014, 03:55 AM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
all of it
Old August 9th, 2014, 12:14 PM   #3
Ninja Chris
Originally Posted by rojoracing53 View Post
all of it
Thanks Jason. I suspected as much.
Guess I'll add the rear shock to my list of upgrades.
Old August 9th, 2014, 12:45 PM   #4
If you're comfortable with your own riding, the stocker is fine for the "every now and then" 2up ride. 4-5 on the ramp preload is a preferred setting based on my experience at near max load capacity on spirited rides.
Old August 9th, 2014, 11:10 PM   #5
Ninja Chris
Thanks Chris. We're going to change sprockets, chain and oil/filters this week, so I'll bump up the preload while we're at it and test it out.
Old August 10th, 2014, 08:35 PM   #6
Hand-test the temperature of your tires after a long ride together.
If the rear is close to feeling uncomfortable to the bare hand, pump some more air into it and test it as well.
With pre-load, the suspension will not be able to accommodate more weight; it is just the geometry of the bike, light beam and front suspension what will remain close to solo conditions.
Rear preload? nikeeric86 Ninjettes At Speed 9 April 18th, 2014 01:47 PM
DIY - Adjusting the rear shock preload noche_caliente 2008 - 2012 Ninja 250R Tech Talk 139 April 6th, 2014 10:20 PM
Rear Shock Preload 2up oblivion007 2008 - 2012 Ninja 250R Tech Talk 4 December 7th, 2011 05:01 AM
For sale: 2003 ninja 250 rear brake pedal and rear shock ReDnEcK Motorcycle-related 0 October 6th, 2010 12:02 PM
Replacing my rear shock with a newgen rear shock... ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 12:38 PM
