Old March 25th, 2024, 08:16 AM   #1
Jakel57
Motorcycle(s): 1988 ninja 250r
Removing the float bowl
I need to replace the o ring on the float bowl, would it be possible to remove the float bowl without pulling the carbs?
Jakel57 is offline   Reply With Quote
Old April 5th, 2024, 09:53 AM   #2
ACL 9000
ACL 9000's Avatar
Motorcycle(s): 2005 EX250, 1975 Suzuki T500, 2018 Kawasaki Z900RS
If you have the right tool to fit under there and grip the fasteners correctly, I think so. It would be a really stubby JIS screwdriver, or an allen key if you're fortunate and the screws got replaced.
Ultimately, yanking everything to pull the carbs is never as time-consuming or annoying as it feels like it's going to be. It might be easier, in the long run, to just go for disassembling.
ACL 9000 is offline   Reply With Quote
Old April 5th, 2024, 09:07 PM   #3
johnhol78
Motorcycle(s): 2005 ZZR600. 2005 EX250F Ninja
Got the bike running!!!
Adjusted the valves and now runs pretty even with the air box missing….
Freshly cleaned and sealed tank going on tomorrow.
Now I just have to work out the creaking noise from the rear end…
Last futzed with by johnhol78; April 6th, 2024 at 07:00 AM. Reason: Wrong thread
johnhol78 is offline   Reply With Quote
Old April 6th, 2024, 06:10 AM   #4
Amazing how many EX's are denied their right to timely valve checks. Many owners simply blow off this critical function as a "meh" ...... eventually resulting in many bikes sitting dormant out back behind the garage. IF your bike has screw & locknut type valves (easy)....just DO IT. Even wiith shim type (more difficult).....just DO IT.
PS.....don't even consider blowing off this MUST DO on a Ducati! A "meh" is not even on the charts.
Old April 28th, 2024, 02:01 PM   #5
BurningRiver
Name: Matt the Hoople
Motorcycle(s): 1982 Honda GL500i
Originally Posted by ACL 9000 View Post
Ultimately, yanking everything to pull the carbs is never as time-consuming or annoying as it feels like it's going to be..
Cut to me explaining to my neighbors that no, I'm not murdering someone, I'm just trying to get the intake boots back on the carbs.
Seriously holy **** I can't this intake system back together unless I pull the rear wheel and airbox, I need help!
BurningRiver is offline   Reply With Quote
2007 Float Bowl Adjustment archaeofreak 1986 - 2007 Ninja 250R Tech Talk 10 May 1st, 2015 01:43 PM
Float bowl leak (I think) MasterCylinder 1986 - 2007 Ninja 250R Tech Talk 30 December 20th, 2013 10:16 AM
Float Bowl Screws kaybray 2008 - 2012 Ninja 250R Tech Talk 2 December 16th, 2012 02:51 PM
I need some float bowl gaskets ... Jim Moore 1986 - 2007 Ninja 250R Tech Talk 9 November 1st, 2012 10:59 PM
need float bowl gasket &/or oil screen cuz Items Wanted 2 October 19th, 2011 11:06 AM
