Old May 30th, 2010, 09:53 AM   #1
peter330
Motorcycle(s): 09 Ninja 250r Blue
change oil filter, without draining oil?
Newb question but I had changed the oil without the filter last time. Would like to change the filter on its own now, would the oil leak or would it be ok for me to change the filter without draining the oil?
peter330 is offline   Reply With Quote
Old May 30th, 2010, 09:54 AM   #2
Soujyu
You can't do it. You WILL lose oil. Either just do another full oil change with the filter or just wait until your next oil change interval.
Besides, changing your oil more often doesn't hurt.
Old May 30th, 2010, 10:29 AM   #3
Snake
Snake's Avatar
You should always change the oil and filter together at the same time.
Old May 30th, 2010, 11:45 AM   #4
Guinss
Guinss's Avatar
Motorcycle(s): 2008 250R (Black)
When you take your oilfilter out, there will be an opening 20 times bigger than the oil drain plug is, so the oil will be drained.
Guinss is offline   Reply With Quote
Old May 30th, 2010, 01:06 PM   #5
sofo
sofo's Avatar
Only if you have a lift that can clamp the bike and rotate it upside down. But if you were to go to that trouble, changing the oil and filter together is the easier route.
sofo is offline   Reply With Quote
Old May 30th, 2010, 01:08 PM   #6
TmP
Highway Ramp Hero
TmP's Avatar
Motorcycle(s): 09 250r
Awesome question though!
Too many mods for a 200 character sig...
TmP is offline   Reply With Quote
Oil isn't draining down into oil chamber! helpp! tammyxpr 2008 - 2012 Ninja 250R Tech Talk 7 January 2nd, 2014 03:07 PM
[webbikeworld.com] - How to Change the Oil and Filter on the BMW Scooter Ninjette Newsbot Motorcycling News 0 May 11th, 2013 05:40 PM
Valve adjusting and Oil filter change J>A>V 1986 - 2007 Ninja 250R Tech Talk 9 January 8th, 2013 02:36 PM
Oil change-190 miles-filter too? wild-bill 2008 - 2012 Ninja 250R Tech Talk 19 June 20th, 2011 12:54 PM
Oil filter change - missing parts HorizonXP 2008 - 2012 Ninja 250R Tech Talk 12 August 29th, 2010 09:26 PM
