Old January 2nd, 2014, 10:25 AM   #1
tammyxpr
tammyxpr's Avatar
Oil isn't draining down into oil chamber! helpp!
I apologize for being kind of lengthy, I just wanted to be as thorough as possible.
Hey guys, my name is Tammy. I just bought a used 2010
ninja 250 from a small time auto dealer. Its my first bike, so I'm used to all this maintenance stuff. However, I preformed my first oil change on it (everything was as black as could be), it looked like previous owner never bothered with any maintenance. When I started my oil change I only got to the draining and then had to leave for work and wasnt able to finish it until 2 days later (I closed everything back up). I finished up the oil change (with a cold engine) and put some oil in the oil chamber, nothing came down tht I could see through the oil window. I s**** a pan and some paper towels underneath to see of anything would leak over night. In the AM there was a lil drop underneath the drain plug, i tightened it a bit and took the bike for a ride around the block to warm up the engine. The bike was still at a "minimal" oil level after putting in 1.5 quarts of oil in it. I bought another quart, put in half the next day and another half after that. Every time I put the oil in is after a block ride so the engine is nice and warm. At this point ive out in apprx. 2.5 quarts of oil and it is still borderlining the minimum level. There arent any signs of leaking where the bike is parked, but I mean, what else could it be??? Im really lost at this point. Please help!
**bike is currently at 2360 miles. Aprx. 2250 at time of oil change**
tammyxpr is offline   Reply With Quote
Old January 2nd, 2014, 10:37 AM   #2
How are you measuring the oil level in the sight glass? The engine needs to be off, and the bike needs to be straight up and down (not on the kickstand).
Old January 2nd, 2014, 10:41 AM   #3
cuong-nutz
cuong-nutz's Avatar
^^ what he said. You can hold the bike upright and take a look at the sight glass to see your engine oil level. You can have someone hold your bike upright while your check or place a 2x4 under the kickstand to get it closer to upright. Just have a hand on the bike so that it doesn't accidentally fall over.
HalfFast Racing Team
Old January 2nd, 2014, 10:41 AM   #4
At 2.5 quarts of oil added, unless it's leaking out somewhere, you might want to get prepared to drain some out.
And welcome Tammy!
Old January 2nd, 2014, 11:03 AM   #5
I think they nailed the problem - and you are most likely over-filled at this point.
Before running again balance the cycle vertical and check the level. If it's too high you can use a long clear tube to siphon some out of the filler opening. That's much more controllable than removing and re-installing the drain plug or oil filter.
To properly check it (after it's close) you need to start the engine and run it for a minute or two - but it doesn't need to be fully warm. Shut it off and wait 2 to 3 minutes to let the correct amount of oil drain back to the sump, then level the cycle and check it.
Old January 2nd, 2014, 12:40 PM   #6
tammyxpr
tammyxpr's Avatar
silly newbie
Wow! I cant believe I forgot to center the bike when reading the oil gauge! Lol well im glad its a simple fix and not something more serious. Thanks guys!
Old January 2nd, 2014, 12:40 PM   #7
don't leave too much oil in there. it causes issues
Old January 2nd, 2014, 03:07 PM   #8
Foxrider64
Hello Moto
Foxrider64's Avatar
Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F
Best way I have found to remove oil from being overfilled is to take a pump pray bottle and put the tube in the filler hole and pump some out.
Keep in mind to keep the bike vertical when doing this. For the first time trying it- have a friend hold the bike upright.
Good luck
Foxrider64 is offline   Reply With Quote
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
5qt. G-Oil Synthetic Motor Oil (5w-30) Free After $26 Rebate setasai Miscellaneous 3 May 25th, 2011 01:59 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and Ninjette Newsbot Motorcycling News 0 October 26th, 2008 05:10 PM
