Old May 5th, 2024, 10:02 AM   #1
frogbite
Motorcycle(s): 250 Ninja
Please help me understand "thread"
Hi all. I have a 2010 250R that has been sitting for years. I got it running a while ago but then it sat again but now looking to complete the project.
It was starting with ease but when I would give it gas it would bog down and stall. Pulled the carbs and they were very dirty. What had me confused is when I pulled out the needle in the diaphragm a small plastic washer came out and I am not sure of its purpose. The bike has the stock #98 and #38 main and pilot jets. The air mixture screw plugs had been removed by the previous owner and the air box is stock.
What I have are this washer pictured next to a needle holder and spring:
Wondering if the previous owner was trying to work around or improve an issue. Anyone have an idea?
frogbite is offline   Reply With Quote
Old May 5th, 2024, 11:33 AM   #2
ducatiman
ducatiman's Avatar
possibly using the washer as a needle shim? Either activly shimming or passively, conveniently storing the washer above the needle, thus enabling quick access if needed?
But just 1 washer, not present on the other slide needle?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Last futzed with by ducatiman; May 5th, 2024 at 01:01 PM.
Old May 5th, 2024, 01:12 PM   #3
frogbite
Thanks, there was one with each needle. I was thinking a shim as well as when jetting the needles are adjustable, so maybe the previous owner saw this as a way to improve on the response by allowing gas to flow at a quicker time?
I put the carbs back in the bike using the washers as a shim, will see if there are issues and if so will pull them back out and remove the washer. I would have thought if shimming that there would have been jet changes, hole in the lift made bigger (not sure if it has been drilled out), or a change the air intake like a K&N style filter or individual filters. Also the pipe is stock.
Thanks
Old May 5th, 2024, 04:10 PM   #4
ducatiman
ducatiman's Avatar
FYI.....the N9VU needle should be in the LH carb, N9VW in the RH carb....you've verified both are numerically correct and placed in correct locations?
Custom Carb Service
Old May 6th, 2024, 03:20 AM   #5
frogbite
Yes, found that bizarre but saw that in the service manual.
Old May 7th, 2024, 08:37 AM   #6
BoKu
Motorcycle(s): EX250F (2x)
Just curious, how do you know which needle is which? Are the numbers written on them?
BoKu is offline   Reply With Quote
Old May 7th, 2024, 08:44 AM   #7
ducatiman
ducatiman's Avatar
yes, side of needle, just under the "head". Very light, may be difficult to read.
Custom Carb Service
Who all is interested in a "Rain Riding Video Thread" from me? Demonik Riding Skills 27 October 3rd, 2017 10:39 AM
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl Ninjette Newsbot Motorcycling News 0 August 16th, 2012 04:30 PM
Another "Bike won't start this morning" thread. headshrink 2008 - 2012 Ninja 250R Tech Talk 40 January 1st, 2011 02:03 AM
the "I" Upgraded or added a bike thread (pics only) tc3jg The Ex-Ninjetters Lair 21 March 12th, 2010 09:56 AM
Trailbraking Discussion - Spinoff from "Rear Brake" Thread muffinman Riding Skills 21 July 2nd, 2009 05:40 PM
