Old November 20th, 2013, 10:43 AM   #1
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
wheel makes a squeak
so for a while now, my rear wheel has been making a small squeak at a certain point when it rotates. I only noticed it when I would clean my chain but I taught a friend how to ride yesterday and I could hear it as he rode. It also sounds like my chain makes a lot of noise as well. Are these problems?
Old Lemon is offline   Reply With Quote
Old November 20th, 2013, 12:20 PM   #2
Are you sure the chain is adjusted properly?
If you didn't locate the tightest spot before setting the tension it could be way too tight at some point. A tight chain will make noise.
Spin the wheel and see if the tension changes - does it get tight? Can you hear the noise when you spin it by hand?
Other things that could make noise in that area are wheel bearings and a dragging brake caliper.
Old November 20th, 2013, 12:26 PM   #3
^^^ this and chain lubed and clean?
Old November 20th, 2013, 12:30 PM   #4
time for a new chain
Old November 22nd, 2013, 01:07 AM   #5
Old Lemon
Lays er down
Old Lemon's Avatar
well my chain is in spec for slack so I would assume that it is not too tight. I can hear it when i spin by hand, I can spin it, hear it, reverse a little bit and spin through that point again and it will squeak. I lube and clean my chain every 300 - 500 miles and its only a couple thousand miles old. I have some meat left in my brake pads so I wouldnt say it is a brake caliper. Say it is a wheel bearing, what could I do?
Old November 22nd, 2013, 06:00 AM   #6
If you believe it to be the wheel bearing then isolate it. Take the chain off the rear sprocket, take the brake caliper off while your at it. You should only be left with a wheel on an axle. If it still makes noise, you found your problem.
What can you do? Nothing that I know of. Well, since you have it halfway apart. Take off the wheel and have a new bearing put in.
Old November 22nd, 2013, 07:01 AM   #7
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Are you sure its not the front wheel speedo drive?
Worlds fastest 250 ninja
Old November 22nd, 2013, 07:52 AM   #8
I would remove the chain as Chris noted, but first I'd make a mark on the chain sideplate and sprocket at some point (aligned with the swingarm or 12 o'clock - whatever) that shows the position of the chain and sprocket when you hear the noise.
Then pull the chain off and see if you hear the noise.
If not, put the chain back on, but don't align it the same, align it 180 degrees to the other side of the sprocket and see if the noise returns - and what position the sprocket is in when it does.
It's possible you may have a damaged chain link or roller, and getting the same noise in a different position on the sprocket may help isolate the cause.
Old November 22nd, 2013, 12:09 PM   #9
Old Lemon
Lays er down
Old Lemon's Avatar
well this is all a bit out of my league, I got a shop with good people that I think will have them take a look at it. Thanks for the help guys
Fix for front wheel squeak noise/Front wheel removal cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 13 April 23rd, 2014 12:25 PM
Front Wheel Squeak - Solved klewi 2008 - 2012 Ninja 250R Tech Talk 8 May 29th, 2011 01:50 PM
Whine/squeak from front wheel GeneJunkie 2008 - 2012 Ninja 250R Tech Talk 14 January 10th, 2011 03:16 PM
[hell for leather] - Wheel Jockey makes chain lubing easy Ninjette Newsbot Motorcycling News 0 December 29th, 2009 02:30 PM
[hell for leather] - Yoshimura GSX-R1000RR makes 176bhp at back wheel Ninjette Newsbot Motorcycling News 0 August 10th, 2009 08:40 PM
