July 16th, 2011, 01:53 PM | #1 |
Join Date: Aug 2010 Motorcycle(s): Blue 2010 Kawasaki Ninja 250r Posts: 170
Yet ANOTHER Givi saddlebag w/quicklock setup
Piggybacking off the pioneer known as slolane and getting input re: quicklocks from setasai I have finally decided to post pics of my rendition of a DIY hard saddle bag setup.
I used 3/4" steel tubing as well as 1/8" flat steel bar all welded together and then bolted to the passenger foot peg mounts using the stock foot peg pins and c-clips. Unfortunately for me, unlike setasai I couldn't utilize the bolts under the rear fender that bolt right to the frame as a means of support due to my hotbodies undertail. That's why I went the route of the passenger foot pegs. A big thanks to slolane for getting me to think about a project like this and to setasai for pointing out that there was a quicklock kit available for these bags. I couldn't imagine how much time I would have spent trying to fab up a good locking mechanism for these sidebags. lol. PLEASE ignore the dirty undertail. I have been field testing these for a few days now and just earlier today there was a truck trying to wash mud off of the road outside a construction site. Of course...that road was the road I HAD to take to get to where I needed to be. Turns out, scott's ebay hugger does nothing for the rooster-tail of spray caused by going through water. Hopefully, it keeps stones & gravel off my undertail at least...
AreaP Quiet Core CF | 8000k HID | FP Jet Kit | Puig db | A&L rearsets | hotbodies undertail | airbox delete + k&n pod filter | Pazzo blue shorty levers | solo seat cowl Last futzed with by Jerkson; August 18th, 2011 at 11:45 AM. |
July 16th, 2011, 02:23 PM | #2 |
See now that looks wonderful. Now we have 3 variations on installing sidecases. Very cool. I would imagine that out of all of us, my bracket system should be the weakest purely because there is only one mount location.
Evolution of the luggage mounts. Very amazing. What kind of exhaust is that? It looks like the mount is so much higher up because there is spacing around the exhaust. Also, could you post up some side pics so I can see how far back you mounted yours? |
July 16th, 2011, 03:02 PM | #3 | |
You used the bolts under the rear fender though, which should be a pretty solid spot. The test I did was tried to shake the entire bike by grabbing the luggage bracket and giving it hell! The exhaust is a short AreaP quiet core. It is much shorter than stock and thus makes the cases look higher Mine was wobbly side-to-side when it was simply bolted to the passenger seat. Those peg-mount points were a lifesaver. More pics on the way 1 sec.
AreaP Quiet Core CF | 8000k HID | FP Jet Kit | Puig db | A&L rearsets | hotbodies undertail | airbox delete + k&n pod filter | Pazzo blue shorty levers | solo seat cowl Last futzed with by Jerkson; August 18th, 2011 at 11:47 AM. |
July 16th, 2011, 03:57 PM | #4 |
Oh ok. I see how that worked out. Looks fantastic.
I'm leaving tomorrow morning for a 435mile stretch to SoCal through Highway 1 so I'll report back on how sturdy they are if they make it through my trip. Have you noticed any handling differences? I actually feel a little more stable with the sidecases on. |
July 16th, 2011, 04:48 PM | #5 | |
The only difference I have noticed is when there is a cross-wind; the force applied to me and the bike perpendicular to the direction of travel is greatly increased. However, when they are full with 40lbs of books spread amongst the 3 cases, I feel very planted and stable especially at highway speeds when there is no major cross-wind
AreaP Quiet Core CF | 8000k HID | FP Jet Kit | Puig db | A&L rearsets | hotbodies undertail | airbox delete + k&n pod filter | Pazzo blue shorty levers | solo seat cowl |
July 16th, 2011, 05:05 PM | #6 |
Awsome
July 16th, 2011, 07:37 PM | #7 |
Motorcyclist
Join Date: May 2010 Motorcycle(s): 2014 Ninja 300 ABS Posts: A lot.
Great job Jerkson!!! Turned out really well
I'm looking forward to your ride reports. I have done day long trips so far and the bags are great! |
July 16th, 2011, 07:41 PM | #8 | |
I think having the ability tohaul items around with me is going to make using the bike more often, as opposed to using the car, a very real possibility. I also like that I can remove the entire assembly without tools and in about 3 min I will post back tomorrow night for sure with a report of how the long day trip went. Slolane, if you hadn't done such a good job on yours I wouldn't have even attempted it.
July 16th, 2011, 07:46 PM | #9 | |
Motorcyclist
Being able to remove them quickly is pretty neat too. Looking forward to your report. Thanks man, I'm glad I could help out and glad all of our sidecase projects have turned out really well. |
July 16th, 2011, 08:06 PM | #10 |
Hey quick question. The E21's are rated at 5kg max load. How heavy have you tried filling them? 11lbs per case is nothing. Even just clothes you can easily go over. Looks like for my trip they will be weighed at approximately 14lbs each. Doubt I'll have a problem but it just seems that the rated max is super low for these things.
Hey i also want to mention that remember that as far as ninja 250's go. We have a unique setup. There arent many who have added hardcases to the newgen ninja 250's. Atleast not many that I have seen or know about. Makes you feel warm and fuzzy inside doesnt it? |
July 16th, 2011, 08:46 PM | #11 |
Join Date: Apr 2011 Motorcycle(s): 2009 V-Strom 650 ABS Posts: 166
Looks great!
Where'd you get that top case? I see a Givi logo on it, but it sure looks like this: http://cgi.ebay.com/ebaymotors/Unive...Q5fAccessories Also, about how much did you spend on all of this? |
July 16th, 2011, 08:59 PM | #12 | ||
They are rated rather low but theres only the two lower nubs supporting all that weight...save for a little weight carried by the top latch depending on how you position it. That said, I have 10lbs in each side right now with no issues. Just got back from another ride too and I totally forgot I had the weight in the back....didn't really notice it at all zipping around town. EDIT: I have thought about the weight becoming an issue down the road. If it does I will weld a large flat plate for the bottom of the cases to rest on like a shelf. IF it becomes an issue. Quote:
All in all the breakdown of cost was: TOPCASE ~ $40 shipped Sidecases ~$185 shipped Monokey latch system and little bits - $26 24' (only used 3' of it) 3/4" square steel tubing $18 3'x1" flat steel plate - $10 Paint - $10 TOTAL $289
July 16th, 2011, 09:26 PM | #13 | |
Now one more question - how the heck do you get on the bike? I'm 5 10", and I just went out to the garage and played around - there was no even remotely graceful way of getting on, short of stepping up onto the left peg and swinging over. I suspect that's not good for the kick stand though, having the dynamic forces and weight of an entire man plus the bike's weight all on one little bracket. Unless you're quite tall, that just leaves karate kicking and hoping to god with all your mobility-limiting gear on that you don't catch the bike and push it over, or slowly lifting your leg over like a feeble old man. The prospect of dealing with that every time I get on and off my bike is not real appealing. I may have to just go with the saddlebags, but I know the utility of the top trunk would be tremendous. |
July 16th, 2011, 09:33 PM | #14 | |
Now, to answer your question about how it's attached. The flat bar that sticks out from the stripped down passenger seat is bolted to the passenger seat. Then you get to use the normal method of installing the passenger seat....lock and all. Then you maneuver the angled rods into the passenger footpeg spots and bolt them in. Since the top rod is flat steel is bends a bit making the maneuvering of the angled footpeg rods possible. Here are two more pics. These were taken during the planning stages and are much better secured. I will take more pics on the assembly when I take it all off tomorrow night to wrap the seat pan in fabric
AreaP Quiet Core CF | 8000k HID | FP Jet Kit | Puig db | A&L rearsets | hotbodies undertail | airbox delete + k&n pod filter | Pazzo blue shorty levers | solo seat cowl Last futzed with by Jerkson; July 17th, 2011 at 05:00 AM. |
July 16th, 2011, 09:40 PM | #15 | |
I too agree that the Givi trunks are insanely expensive. |
July 16th, 2011, 09:45 PM | #16 | ||
Motorcyclist
My similar setup was $200 for the sidecases and $60 for the topcase. Getting on is kind of like a punch-kick, you kind of pivit on your left foot, not too bad really. |
July 16th, 2011, 09:52 PM | #17 |
Motorcyclist
I have had mine for 7 months now, works great! I didn't use the quick release bracket, bolted mine directly to the rear seat pan. The largest full face helmet I can fit into mine is a Child Large, not any adult sized. |
July 16th, 2011, 10:00 PM | #18 | |||
July 17th, 2011, 04:57 AM | #19 | ||||
Yeah those large givi sidecases...I saw ones that hold a helmet in them. They look like they would stick out WAYY to far for my liking. However, thats interesting that the rule of thumb is to fill them until it negatively impacts handling. I check my sidecases where they slide onto those two lower nubbs every day to see if the plastic of the cases shows any stress marks or signs that the plastic is failing/deforming....just in case. Im staying subscribed to both of your threads...so if any of us notice issues or make refinements as the need arises, we should update our threads so as to collectively provide good long-term data regarding our DIY methods.
July 17th, 2011, 07:08 AM | #20 |
July 17th, 2011, 08:22 PM | #21 |
Go Pack Go!
Join Date: Feb 2011 Motorcycle(s): 09 250R, 07 XL1200L Posts: 39
This looks GREAT - exactly what I was looking for.
Can you post a picture of how you utilized the passenger foot pegs? Thanks
09 Ninja 250R (commuter) 07 XL1200L (weekend fun) 02 SV650S (totaled by an idiot cager) & others |
July 18th, 2011, 08:36 AM | #22 | |
Yesterday I went 677KM around the Muskoka Lakes and found only 1 issue with my fully-loaded setup: The cheapo ebay topcase has two small hinges on the lid, these hinges have a pin in them, much like a door hinge in your house does. The Pin rattled loose and fell out of one of the two hinges!! On one end the hinge is sealed but on the other end it is exposed. I would suggest putting some hot glue in the hole to prevent this from happening to anybody else.
July 18th, 2011, 11:45 AM | #23 | |
Btw, I felt the crosswinds you were describing. Man they really push me around. Although to be fair, I doubt it'd have felt very different without the extra sidecase surface area. On the otherhand, it felt more stable on the freeway and dipping into turns with a little extra weight in them. |
July 18th, 2011, 11:54 AM | #24 | |
Awesome. I look forward to your full detailed report I will read it in it's entirety but I'm too lazy to post an in-depth report from yesterday's ride. They definitely do help with stability when weighted down
August 2nd, 2011, 11:23 PM | #25 | |
I'm looking to build a rack based on your design. Got the bags, the quick release brackets, and a shiny new Lincoln 140 welder that I have no idea how to use yet. |
August 2nd, 2011, 11:34 PM | #26 | |
August 2nd, 2011, 11:38 PM | #27 | |
Will of course do a full write up when complete. That is, assuming I can figure out how to weld properly. |
August 2nd, 2011, 11:55 PM | #28 |
Hope you figure that out soon. I'm eager to hear about how your project turns out. I love having those sidecases. Most notable things I have in it is wet wipes, smoke/clear visor, and a bottle of water. Amazing how convenient it is. Goodluck.
August 3rd, 2011, 07:07 AM | #29 |
Sorry bout the pics...they were hosted on Picasa and I rearranged them.
I will get them back up today.
August 18th, 2011, 11:47 AM | #30 |
Ok so maybe it took me two weeks to get them back up... I will put some more up today
March 1st, 2013, 08:58 AM | #31 |
Join Date: Feb 2013 Motorcycle(s): Kawasaki Ninja 250R 2012 Posts: 3
Nice customization.
If you want your rear seat back, check this out.. (Not sure if this is available in the US)--> Let me know if you find it! |
March 1st, 2013, 09:39 AM | #32 | |
Posted via Mobile Device |
Red Cortech tailbag & saddlebag set | misfitsailor | Items Wanted | 1 | April 1st, 2014 09:49 PM |
DIY - Yet Another, Another Hardlocking Saddlebag Mount | NathanF | Cargo Space | 36 | May 28th, 2013 10:11 AM |
DIY: Another Hardlocking Saddlebags w/ Quicklock | setasai | Cargo Space | 55 | November 19th, 2011 11:24 PM |
[webbikeworld.com] - Giant Loop Coyote Saddlebag Review | Ninjette Newsbot | Motorcycling News | 0 | December 14th, 2010 04:50 PM |
[motorcycle.com] - New saddlebag from The Leatherworks | Ninjette Newsbot | Motorcycling News | 0 | October 1st, 2008 04:21 PM |
