Old August 2nd, 2022, 04:55 PM   #1
Redin99
Motorcycle(s): 2009 ninja 250r
A pic of my bike and a few ?s
Hi my name is tyler I’m 27 and have a 09 Ninja 250r runs great but I ride on highway any suggestions for better gearing also my forks seals are toast should I replace with different kind or stick with stock any suggestions welcome
File Type: jpg D65CADE3-0B4C-4101-B1F3-998CDFA2E7A7.jpg (163.8 KB, 16 views)
Redin99 is offline   Reply With Quote
Old August 2nd, 2022, 05:22 PM   #2
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Redin99! Glad to have you aboard...
Old August 2nd, 2022, 06:55 PM   #3
Greetings & Salutations!!!
Wow, that's awesome paint job!
I like using 16t sprocket in front for freeway cruising. Much more relaxed.
Stock fork seals work fine. Just did mine last month.
Old August 2nd, 2022, 07:35 PM   #4
Ceeloo Yello
Motorcycle(s): 250
Welcome
Old August 5th, 2022, 01:48 AM   #5
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome, Tyler!
Old August 7th, 2022, 05:10 PM   #6
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
Welcome. Factory seals are great but if you want to save a little money "All Balls Racing" sells seals as well. I used them on my CBR and 1k miles later and 2 trackdays it's still good. Enjoy your bike you'll get a lot out of it.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old August 16th, 2022, 06:44 AM   #7
Snake
Snake's Avatar
Hello and welcome!
Old August 22nd, 2022, 10:26 PM   #8
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Welcome!
Love the color!! I agree with suggestions already given!
Let us know how it goes!
The Bike | The Truck
Old August 27th, 2022, 07:33 PM   #9
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
Welcome Tyler...
I have a 2012 250R and love it
I would keep with the stock shocks and just rebuild them myself much cheaper that way.
that is a very pretty paint job on your bike ! I love the metal flake !
but get you some sliders on it before you lay it down and scratch it all up as you'll never be able to match that paint !
I have a 16 tooth sprocket on front and a 43 tooth sprocket on the rear
and I could cruse at 70~75mph all day if my butt could handle it ! LOL
I did have to work on the chain cover in the front to get clearance though...
I just took a hack saw blade and cut the part that was touching off....
(technically I clamped the chain cover in the vice between 2 wood blocks and cut off the half moon protrusion with a reciprocating saw, it went pirty fast, and then bolted right up. no more shift shift and shift before going 30mph either... that's silly !
Bob......
Old May 27th, 2023, 07:52 PM   #10
Redin99
Believe it or not it’s spray paint color shift
Old May 27th, 2023, 08:36 PM   #11
That's awesome! Can you post link to spray can product? thx
Old May 28th, 2023, 05:34 AM   #12
Rustoleum Color Shift:
https://www.rustoleum.com/product-ca...by/color-shift
https://www.walmart.com/c/kp/color-shift-spray-paint
Old May 28th, 2023, 05:56 AM   #13
awesome, thanks!!!
Old May 28th, 2023, 06:32 AM   #14
DaveTheWelder
Motorcycle(s): 2012 Ninja 250
I was literally looking at that same paint last night wondering what it would look like on mine. That is sharp looking, how many coats/cans did it take?
DaveTheWelder is offline   Reply With Quote
Old June 14th, 2023, 09:41 PM   #15
Redin99
So the key is to get the 2k clear not the cheap stuff it’s about 20 bucks a can and you break the thing on the bottom to mix and you only have a few hours to use I believe if I remember right here a link this stuff is key to amazing finish if I remember right I bought about 4 cans of paint and 2 of clear maybe 3 but it’s worth it 100% https://www.amazon.com/SprayMax-Glam...95780726&psc=1
Last futzed with by Redin99; June 14th, 2023 at 09:42 PM. Reason: Forgot to add link
Old June 15th, 2023, 05:39 AM   #16
Correct. That's what I used on my 250 and my Moto Guzzi, over the color coats. For the 250 it took 2 cans to do just the parts I kept, so I can imagine it would take 3 to include the fairings. I used Duplicolor lacquer for the metallic red, but I won't use it again. It's very finicky and very vulnerable to gasoline spills. Luckily the Spraymax 2K is protecting it well, and a little spillage at the gas station doesn't hurt it at all.
If you don't finish the can of Spraymax, you can keep it in the refrigerator for at least a week, maybe a little longer. I used some that was a week old without any problem, but I let it warm up thoroughly before I sprayed it.
Old June 16th, 2023, 06:43 PM   #17
Wow, that turned out awesome Jim!!!
Yeah, lacquer's not cured paint with permanent poly-vinyl cross-linking, so it can get dissolved easily.
As for clears, does anyone know where I can get some of this stuff? Best I've ever used, continues to flow for 20-minutes after spraying for glass-smooth finish! No cutting needed. And super-tough and chip-resistant.
EDIT: Ah... I see that DuPont was bought by The Carlyle Group and re-branded as Axalta Coatings... https://en.wikipedia.org/wiki/Axalta
Last futzed with by DannoXYZ; June 17th, 2023 at 12:22 AM.
Old June 16th, 2023, 08:04 PM   #18
Thanks JR. I painted my '72 H2 with Imron in 1979, and that paint is still on it. I wouldn't hesitate to use it again. I've spilled brake fluid on it and it doesn't hurt it at all. I even got lacquer thinner on it, and if you wipe it off reasonably quickly it won't damage it either.
Dropped my bike... with pic caineroad !%@*#$%!)@#&!%@ I crashed! 9 November 8th, 2013 01:24 AM
Drove my bike to work today and took this pic... kyrider General Motorcycling Discussion 27 August 13th, 2011 08:44 PM
Is this normal for a bike? **PIC** kroze 2008 - 2012 Ninja 250R Tech Talk 20 May 14th, 2011 02:07 PM
Bike accidents hurt. (Pic intensive) Linuss !%@*#$%!)@#&!%@ I crashed! 22 May 14th, 2011 12:51 AM
Pic of my bike ... on ebay! LOL - RIM TAPE Strider General Motorcycling Discussion 13 July 21st, 2009 06:30 PM
