Old October 3rd, 2012, 02:13 PM   #1
jeanca223
jeanca223's Avatar
Motorcycle(s): Ninja 250 2012
DIY: Installing Spy 5000m Alarm on ninja 250r 2008 - 2012 (New Version)
Hi everyone,
I know there is a thread about installing this alarm but unfortunately the pictures are offline so I wanted to share a step by step guide with pics of how I installed mine on my 250R 2012 ninjette.
Spy 5000m Alarm
Out of the box the alarm will look like this:
1: Loud! Siren
2: Transmitters
3: LED indicator
4: Wiring loom
5: Brain box, Antenna and batteries
6: Microwave sensor
7: Microwave sensor cable
First of all, you will need to take off the following components:
BOTH SEATS
REAR FAIRINGS
REAR SEAT KEYHOLE STAND
BATTERY COVER
If you don't want to lose your screws you might follow this link first
How to keep screws organized during maintenance
I will put the pictures of my ninjette when I removed the fairings but the official step by step guide is here:
DIY: Removing the fairings
Let's get started
Removing Seats
Removing Rear Fairings
Removing Rear Seat Keyhole Stand
Remove Battery cover
Now let's understand what each color means on the wiring loom
1 Black GND ->: Ground to chassis (ends with a ring)
2 Red->: Positive to battery
3 Black->: Negative to battery
4 2x Yellow->: Rear turn signals one for each
5 Brown->: Plate light
6 Pink->: Remote engine Cut Off
7 Gray->: Remote engine Cut Off
8 Blue->: Remote engine Start On
After knowing the cable coding on the alarm we will have to locate the turn signals and the plate light cables:
For each turn signal we have to connect the positive cable to the alarm's yellow cable -> like this:
Then connect the positive cable of the plate light to the alarm's brown cable-> like this:
Now let's put the alarm's black GND cable (ends with a ring) -> to this screw on the chassis.
NOTE: I checked with a tester if that screw was grounded before putting it.
It is time for testing the alarm so what we will do is plug the microwave sensor plug and the siren plug to the brain box plugs
and connect the alarm's Red cable -> to the battery's positive and the alarm's Black cable-> to the negative of the battery.
It should look like this:
After making sure everything is OK with the alarm
it is time to find a location for the following components:
Brain Box
Siren
Microwave Sensor
Antenna
I decided to put the brain box along with the tool bag under the passenger seat.
The siren next to the bike's computer
I put the microwave sensor over the battery cover using a piece of Velcro that comes with the alarm
and the Antenna onto that metal plate
And the LED indicator is located in the windshield (see the red dot in the picture)
I did not make any hole to the dash the LED indicator is just between the windshield and the dash,
I just passed the cable under the side fairings along with the front turn signal cable until get to the brain box plug.
Now the alarm should be working fine except for the remote engine start and the remote engine cut off
I decided not to use the remote engine start at all, I use to have it on my previous bike and honestly never use it
and regarding the remote cut off I will do it after the warranty period expires.
I will explain what you have to do in order to make the remote engine cut off work
NOTE: I am not sure if this works since I haven't try it yet. Please tell me your results.
In six months I will probably update this with my own pictures.
Get the fuse box and locate the IG Fuse
You will have to cut the brown cable and connect the Pink-> and Gray -> cables to each end of the brown cable that you cut. See picture bellow:
If any feedback please send me a private message and i will modify this post
Last futzed with by jeanca223; October 4th, 2012 at 08:24 AM. Reason: Easier title for google search and for users understanding
jeanca223 is offline   Reply With Quote
Old October 3rd, 2012, 09:20 PM   #2
Good work!
/linked from main DIY
Old October 4th, 2012, 08:09 AM   #3
jeanca223
jeanca223's Avatar
Originally Posted by Alex View Post
Good work!
Thanks, I hope it will be a helpful reference
Old October 4th, 2012, 09:34 AM   #4
Dragonracer76
Dragonracer76's Avatar
nice DIY!
Beards make everything better. ATGATT
Dragonracer76 is offline   Reply With Quote
Old November 7th, 2012, 06:49 PM   #5
vjnhtam
Hi, I'm wondering where the blue wire goes
vjnhtam is offline   Reply With Quote
Old November 8th, 2012, 11:52 AM   #6
jeanca223
jeanca223's Avatar
Hi the Blue->: Remote engine Start On goes to the start relay but
as I said on my post I won't do it because I actually didn't use it
on my previous bike that had it installed
if you really want to install it I saw on some posts that it doesn't work well, please check this and let me know if you can make it to work.
BTW: Take pictures so we can improve this tutorial
This Thread
Old November 9th, 2012, 01:36 PM   #7
Lychee
sail away
Lychee's Avatar
It's been suggested to locate the brain box inside the air box.
Old January 10th, 2013, 01:37 PM   #8
NinjaGod
Motorcycle(s): 09 250 Kawasaki Special Edition
Plate Light
I was wondering where to connect the brown cable if I don't have the plate light to connect to anymore. I took the plate light off cus I didn't like the plate light and the tail section on my 09 250R. And the GND wire is fine where you said right? Thank you for the info on the Blue Pink & Grey wires (don't need to be connected) I was confused about those.
NinjaGod is offline   Reply With Quote
Old May 17th, 2017, 03:33 PM   #9
AvinKuang
Motorcycle(s): Kawasaki zx6r
my bike is 2013 zx6r!install remotes start is now work!can you help me ?i dont know pink and gray wire how install ! let me know! thanks
AvinKuang is offline   Reply With Quote
DIY: Installing Spy 5000m Alarm Remote Start Den 2008 - 2012 Ninja 250R Farkles 62 November 25th, 2016 03:03 AM
DIY and First Impressions: Scorpio i800 alarm ninjabadger 2008 - 2012 Ninja 250R Tech Talk 7 June 19th, 2013 10:15 AM
DIY for installing race fairing? psych0hans Ninjettes At Speed 5 April 16th, 2013 07:40 AM
spy 5000m remote start problems JohnA1989 2008 - 2012 Ninja 250R Farkles 12 April 24th, 2012 09:29 AM
DIY: Installing Halos tlhamon 2008 - 2012 Ninja 250R Tech Talk 26 October 27th, 2010 08:40 PM
