Old May 14th, 2013, 05:47 AM   #1
ninja98r
Motorcycle(s): Ninja 250R
Can't remove Clutch pivot bolt lock nut!
Trying to install shorty's. Having a hard time removing the clutch pivot bolt as the bottom nut will not come off. I am keeping the bolt from turning using a wrench while at the same time using a ratchet on the nut. The bolt is steady and the nut turns and turns but doesn't make it's way off the bolt. It won't tighten or loosen. Any tips or suggestions out there? Already got a replacement bolt and nut from the dealer as I anticipate I will have to butcher the current. Thinking about the best way to get the nut off without damaging the handlebar.
ninja98r is offline   Reply With Quote
Old May 14th, 2013, 06:03 AM   #2
Use a small screwdriver to force the nut out while you rotate the nut with a wrench; it will catch the thread of the bolt eventually.
The bolt screws in the thread of the aluminum support, which you will need for the new one: be very gentle with that one.
The nut is just a counter-nut.
The clutch switch is very fragile, removing it is better.
Old May 14th, 2013, 02:27 PM   #3
ninja98r
Thanks for the advice.
I have been removing the clutch sensor while attempting to remove the lock nut.
I did indeed try to wedge a small flathead albeit I was really trying not to scratch the support mounted to the handlebar. Perhaps I'll try again with more force.
I don't think the support will need to be replaced if I'm careful....? We'll see I guess.
I was also thinking of drilling or using a dremmel to the nut but will try to wedge it off while turning again first.
This was to be a simple mod!!! Only me!
Old May 15th, 2013, 05:44 AM   #4
Originally Posted by ninja98r View Post
.........I was also thinking of drilling or using a dremmel to the nut but will try to wedge it off while turning again first.
You are welcome
Use something soft, like a plastic table knife instead of a screwdriver.
You don't need much force, only enough to force the nut to catch on the thread of the bolt.
Due to over-torquing, the threads of the nut or/and the bolts have been damaged on the section covered by the nut, which is basically spinning over the bolt now.
A Dremmel may work or not, because too much damage to the bottom section of the bolt means that the soft aluminum thread of the support could be damaged when that end goes up and through it (unless you make it smooth with a file first).
Just a couple of ideas.
Hope you can solve the problem soon.
Old May 21st, 2013, 04:05 PM   #5
ninja98r
Got it!!
Got my shorty's on finally!!
Happy to report that I was able to get the clutch pivot bolt and nut out
Tried and tried to wedge the nut off but was unsuccessful....
Ended up having to carefully drill out the bolt just enough to get the nut off.
Tip: The lever brackets are threaded. Make sure you loosen and remove the lock nut prior to the pivot bolt. I believe I broke the bolt thread covered by the lock nut by attempting to loosen the bolt first. The lock nut was preventing the bolt from lifting causing the thread to break.
Old May 21st, 2013, 05:19 PM   #6
Did the thread in the bracket get damaged when you unscrewed the drilled bolt?
If yes, did you have to replace the bracket?
Old May 21st, 2013, 08:06 PM   #7
ninja98r
I managed to spare the bracket thread when removing the pivot bolt.
Albeit it was more snug trying to get the replacement bolt back in.
I was mindful when drilling out the bolt. Used two sized bits and made sure there were no protruding metal.
Thanks for the heads up on the risk.
Old May 22nd, 2013, 04:52 AM   #8
You are welcome
Clutch Lever Pivot Bolt Yaozer Items Wanted 2 June 20th, 2013 09:42 AM
clutch lever pivot bolt/nut torque specs Confuzshuz 2008 - 2012 Ninja 250R Tech Talk 3 September 25th, 2012 05:11 AM
Clutch pivot bolt and nut setasai Items Wanted 4 October 8th, 2011 08:14 AM
Clutch Pivot Bolt addy126 2008 - 2012 Ninja 250R Tech Talk 8 October 7th, 2010 02:44 PM
Never use fuel tank linear, and there is a nut on the clutch lever bolt... saber63 1986 - 2007 Ninja 250R Tech Talk 0 April 23rd, 2010 08:58 AM
