Old September 24th, 2012, 08:03 PM   #1
Confuzshuz
Motorcycle(s): 2011 ninja 250r
clutch lever pivot bolt/nut torque specs
Anyone know the torque specs for the clutch lever pivot bolt/nut?
I left it at 45 in-lb because I think the pivot bolt/nut was a smaller diameter than the brake side.
Thanks in advance.
Confuzshuz is offline   Reply With Quote
Old September 24th, 2012, 08:10 PM   #2
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Thanks in advance.
87 in-lbs
geeker is offline   Reply With Quote
Old September 24th, 2012, 09:00 PM   #3
Confuzshuz
Originally Posted by geeker View Post
87 in-lbs
thanks, but I don't think that correct. 87 in-lb is for the clutch cover on the engine.
Old September 25th, 2012, 05:11 AM   #4
geeker
geeker's Avatar
Sorry, it wasn't specifically listed. The brake lever is listed on the brake section. Try the page for the unspecified fasteners.
Clutch Lever Pivot Bolt Yaozer Items Wanted 2 June 20th, 2013 09:42 AM
Can't remove Clutch pivot bolt lock nut! ninja98r 2008 - 2012 Ninja 250R Tech Talk 7 May 22nd, 2013 04:52 AM
Clutch pivot bolt and nut setasai Items Wanted 4 October 8th, 2011 08:14 AM
Clutch Pivot Bolt addy126 2008 - 2012 Ninja 250R Tech Talk 8 October 7th, 2010 02:44 PM
Never use fuel tank linear, and there is a nut on the clutch lever bolt... saber63 1986 - 2007 Ninja 250R Tech Talk 0 April 23rd, 2010 08:58 AM
