Old March 15th, 2016, 09:49 AM   #1
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
TYGA 300 Full system anyone tried it ???
Hi All, Just after some info on whether anyone has tried the Tyga full system for the 300 on a pregen ?
They appear to have modified the header pipes when compared to the nextgen 250 system, but I can't find a picture of the exhaust on the bike with a side profile to see if its tight enough to fit a pregen !
Old March 17th, 2016, 07:50 PM   #2
Anyone? Free bump Chris.
Old March 19th, 2016, 01:52 AM   #3
Mohawk
Mohawk's Avatar
Thanks for the bump.
Anyone got a picture of one on the bike side shot to show the header path ?
I'll check with TYGa, as I can't find any on the net.
Old March 19th, 2016, 04:40 AM   #4
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Can't say anything about performance, fitment or sound but TYGA is known to make quality stuff and if they can make nice 2 stroke pipes for lots of bikes i trust that they can make a simple exhaust for a little 4t
Old March 19th, 2016, 06:18 AM   #5
Ghostt
Ghostt's Avatar
The header won't fit a PreGen, due to the exhaust ports are further apart than NewGen.
violente et ignorantia
ZX-2R BLOG
Old March 19th, 2016, 08:49 AM   #6
Mohawk
Mohawk's Avatar
But it has seperate header pipes, so the spacing is immaterial. they changed the shape for the 300 which uses pre-gen size headers ! and as it has a longer stroke then the pipes must be slightly longer, but it fits the 250 & 300, I assume the header port adaptors are the only differences.
Old March 20th, 2016, 06:51 PM   #7
HoneyBadgerRy
HoneyBadgerRy's Avatar
I think there are only two ways to find out. Ask them, or buy one and figure it out.
Old March 22nd, 2016, 07:21 AM   #8
Captain Caveman
Motorcycle(s): ZX6R, NINJA300R
Yeah installing a full on my 300 at the moment, if you need any measurements. I'm chasing a powercommander map at the moment.
Captain Caveman is offline   Reply With Quote
Old March 22nd, 2016, 07:25 AM   #9
Mohawk
Mohawk's Avatar
I just had a cartoon charactor loose in my head as in "Capppptaaaaain Caaavee Maaaann"
I'd be interested in how close the header pipes come to the front of the engine comapred to the pre-gen headers !
Thanks for any pics or info you can provide.
Old March 25th, 2016, 06:18 PM   #10
omnivore
omnivore's Avatar
Motorcycle(s): CBR Fireblade, KTM 950SM, YZF750 (x2), R6, ZZR250, XR200, KTM 50SX Sr.Pro, Honda Spree
Anyone?
building a ZZR250 racebike for my 15 yr old nephew and this would be helpful if it fit.
KTM 950 SM,YZF 750 Street, CBR929 EnduranceBike,YZF 750 vintage racer, R6 racebike , SOAR #22
Last futzed with by omnivore; March 26th, 2016 at 01:59 PM.
omnivore is offline   Reply With Quote
Old March 26th, 2016, 12:48 AM   #11
Mohawk
Mohawk's Avatar
Finally found a side on pic, it's the same header routing as the 250, so won't fit a ZZR, due to the fairing bracket being where the headers want to be, unless you take a piece out or make the loop lower, or use a different setup.
See here, http://i1.wp.com/therideadvice.com/w...n.Still020.jpg
Will fit the next gen 250 too.
Must keep looking for an old Muzzy or just replace the cans on the stock system.
YMMV
Old March 26th, 2016, 01:13 AM   #12
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Chris why are fixed to the Tyga exhaust?
Maybe you take a look for the Arrow, this is besides the Leovince the best exhaust (LV=1 for the FI-250) for the 2-fiddy.
From Arrow you can get the header separate.
Old March 26th, 2016, 08:07 AM   #13
omnivore
omnivore's Avatar
YMMV
All I care is that it clears the oilpan and swingarm.
we are using R6 fairings, and a custom tail on thebike.....so fairing bracketry is a non issue.
Old March 26th, 2016, 10:48 AM   #14
Mohawk
Mohawk's Avatar
The reason for the TYGA, was it looks like they changed the pipe shape from the next gen 250, so it might have fitted the pre-gen motor & its the right size header pipr diameter.
The Leo & Arrow are just reworked 250 pipes & the header routing is the same, so still a problem for me, as it will hit the oil cooler I have mounted in the fairing bracket !
Old March 30th, 2016, 02:41 PM   #15
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
Lightbulb
Hadn't seen this thread before today. If Capt. Caveman hasn't sorted your questions yet, I could feasibly photograph and/or measure the Tyga system on my 300 when myself and that bike are once again in the same geographic area. The only measurement I already took was weight, on a component basis (e.g. each individual header pipe, etc). Those numbers are, of course, also not on my person at the moment.
My personal reason for the Tyga system was straightforward: price. (insert CREAM smiley here).
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old March 31st, 2016, 05:50 AM   #16
omnivore
omnivore's Avatar
What did the Tyga system price out at shipped?
Old April 1st, 2016, 03:24 AM   #17
Mohawk
Mohawk's Avatar
Thanks but fairly certain it won't fit my needs now I've found a good pic
Old June 6th, 2016, 11:28 AM   #18
omnivore
omnivore's Avatar
We used an ebay copy (@$220)of the Tyga on our ZZR successfully ....raced last weekend and it worked good, and is light and looks great.
Old June 6th, 2016, 12:28 PM   #19
toEleven
Slower than you.
toEleven's Avatar
MOTM - May '16
Sorry, didn't see this question earlier. To my location (east coast, USA) it totaled $409.56 USD. $100+ cheaper than the nearest price I had at the time for other manufacturers' full systems.
Old August 7th, 2017, 10:38 PM   #20
Twinshock750
Twinshock750's Avatar
Motorcycle(s): CMR TZ750 Yamaha, McIntosh TZ350 Yamaha, OW01 Yamaha, 300 Ninja Lightweight production Bike
Fitted a Tyga full system to my 300, and at the same time my tuner reflashed the ECU with Woolrich racing software and then got into it on the dyno with some fuelling and timing changes. Picked up 10% power gain to 38.4hp from 35. Stock filter and motor, on pump gas.
Don't always believe what you think!
Twinshock750 is offline   Reply With Quote
Tyga full exhaust system? Sharkride 2008 - 2012 Ninja 250R Tech Talk 7 October 6th, 2015 07:10 PM
FS: TYGA full exhaust CF can josefmd Motorcycle-related 12 May 2nd, 2013 05:38 PM
New pics, Clip-ons and Tyga full System w; MGP Growler WolfgangCG 2008 - 2012 Ninja 250R Tech Talk 23 November 20th, 2012 10:08 PM
tyga slip on exhaust system thisdudematt 2008 - 2012 Ninja 250R Tech Talk 6 August 16th, 2012 02:15 AM
Tyga vs AreaP full system 675Raisinator Ninjettes At Speed 20 February 8th, 2012 09:12 AM
