Old March 4th, 2009, 10:55 PM   #1
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Post DIY: Lowering the back with Roaring Toyz lowering links
So tonight I decided it was time to finally lower my bike just a little bit. I could get the ball of one foot down securely, and pretty decently on the other, but with my knee problems, it just did not feel safe for me. I decided to get the Roaring Toyz front and rear lowering kit and attacked her this evening. First off, it is COLD here right now!
Tools you will need for this:
Floor jacks
19 mm socket
torque wrench
7 mm allen wrench
flat blade screw driver
breaker bar, or someone weighing around 180 lbs
This DIY
The short version - jack up the bike, take off the old links, put on the new links and torque to 44 ft-lbs.
Longer version:
Come home and find this wonderful package:
Open it up and find:
Gather your tools:
Take a good look at the old links so you can see what you are removing (the service manual helps here as well)
Lift the bike onto a rear stand and carefully position jacks under the bike to hold it steady. Then remove the rear stand so that the bike is supported only by the jacks. I used a pair of floor jacks on the center part of the frame (under the rearsets) and my car jack in the middle underneath the oil pan. On the exhaust side, the header is in the way, so I placed the jack on the little nub that hangs down a bit. I'm not sure if this was a good idea, but we had two other jacks and a pair of hands on the bike at all times, so I felt fairly safe doing it this way. Securing the front brake with something helps as well - I use a hair tie
On the brake side, loosen the nuts on the bolts connecting the lowering link with the 19 mm socket. An extender for your wrench might be helpful, as well as the breaker bar or larger person who can stand on it (I used my hubby ) Use another person to help secure the bike while you remove the lowering links and bolts. When you do this, the swing arm will pivot so that the front end moves down. Lifting up on the wheel will help to get it back into position when you replace the new links.
I wanted to lower an inch, so I used the center position in the top row of three holes.
Place the new links, replace the bolts (you might want to use some blue loctite here), and torque to 44 ft-lbs using the torque wrench.
Very carefully lift the bike back onto the rear stand - this is made more difficult by the jacks since the bike is now lowered an inch meaning the swingarm is higher than when you took it off of the rear stand. We had my car jack under the center of the engine block, so we used that to raise the bike just a bit to remove the two jack stands, and then lowered it back down until the spools were sitting on the forks of the rear stand. When you put the bike back on the kick stand, it will not lean as far over, but in my opinion it seems to be ok without replacing it. If you were to lower any more than an inch, you would need to replace the kick stand for stability.
As you can see, I can now touch much better than before!
Now you can move onto lowering the front end/raising the forks! Zartan and Kkim have combined to make a DIY for that which you can find here:
http://www.ninjette.org/forums/showthread.php?t=9804
Old March 4th, 2009, 10:56 PM   #2
noche_caliente
and with that I am off to bed, as I have to be at work in less than 7 hours If you have any questions, let me know and I'll get back to you tomorrow evening sometime *yawn*
Old March 4th, 2009, 11:28 PM   #3
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Whats your height if you don't mind me asking. I'm roughly 176-178cm (5 ft 7 - 5 ft 8) and was wondering if I would need to lower the bike.
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old March 4th, 2009, 11:39 PM   #4
Thx, Noche! Looks great. Added to the DIY sticky...
Old March 4th, 2009, 11:46 PM   #5
Good job. We needed a DIY that covered this... so many people will thank you for this, I'm sure.
Old March 4th, 2009, 11:54 PM   #6
islanderman7
The Sexy Filipino
islanderman7's Avatar
Motorcycle(s): Ninja 250R 2008 (da black one)
Nice. Do you have to replace the side stand with this kit? My concern is that my friend lowered his R6 maybe ~1-2" and his bike looks like it is sitting vertical. Long story short, his bike was blown over due to some moderate winds.
So how does it sit with this lowering kit... vertical?
islanderman7 is offline   Reply With Quote
Old March 5th, 2009, 12:01 AM   #7
Old March 5th, 2009, 10:56 AM   #8
GreezMunky
GreezMunky's Avatar
Motorcycle(s): 09 250r (*sold*), 2010 Daytona 675
Miks I'm 5'7" and have no problem flat footing with both feet when I'm on the bike. But then again, it's your inseam that matters. I have about a 31" inseam. Kkim is about the same height as me but I don't think he could completely flat foot with his bike.. Please correct me if I'm wrong Kkim!
Add:
Oh and I have the Corbin seat which does lower how far up you sit on the bike about an 1in - ish so that helped.
GreezMunky is offline   Reply With Quote
Old March 5th, 2009, 10:59 AM   #9
yep, I'm 5'7" and my inseam is like 28-29". Noche is a bit shorter than 5'7" and I have no idea what her inseam is.
Old March 5th, 2009, 07:51 PM   #10
noche_caliente
Here's a really crappy camera phone pic, but it's the most I had energy to do for you.... sorry - please excuse the mess and multi-bike parking in the garage
Alex- sorry it's so big -feel free to chop it down some
Old March 5th, 2009, 07:52 PM   #11
noche_caliente
5'3 and 30"
Old March 5th, 2009, 07:58 PM   #12
Hi Noche -
It's not too big at all, it looks great! The board itself converts it down to 1024 pixels wide when you uploaded it.
- Alex
Old March 5th, 2009, 09:22 PM   #13
jpnfrk
Her name is Itoshii
jpnfrk's Avatar
Motorcycle(s): 2007 Kawasaki Ninja 250
Thank for the DIY Kim, if you don't mind me asking, how much did you get the kit for?
Dunno if the seat height on my 07' is that much different, but I'm thinking of lowering mine a bit to reach the ground better.
"A frog in a well can not see the ocean" ~ Japanese proverb
jpnfrk is offline   Reply With Quote
Old March 6th, 2009, 08:03 AM   #14
tlhamon
tlhamon's Avatar
Motorcycle(s): None Yet
Thanks for posting that!!! I am going to do the same mod due to my tiny little legs.
It's not worth doing if you aren't completely stressed out about it.
tlhamon is offline   Reply With Quote
Old April 3rd, 2009, 11:14 PM   #15
snowlife
Motorcycle(s): BMW f800gs
This i find a bit funny. The person who i know would like to lower the bike is under 5ft
snowlife is offline   Reply With Quote
Old April 6th, 2009, 08:12 PM   #16
kris4
Motorcycle(s): 08 ninja 250
So I used the Roaring Toyz lowering kit to lower the front and rear. I set the rear to the lowest setting dropping the bike 3" according to the kit description. The bike looks great, unfortunately it bottoms out. I ignored the bottoming out until recently I discovered that the tire has scraped a hole in the plastic wheel well located above the rear tire. The electrical wires are now exposed.
Has anyone else run into this problem? Also, has anyone solved this problem without raising the bike?
kris4 is offline   Reply With Quote
Old April 6th, 2009, 08:18 PM   #17
very common problem with lowering the bike that much max should be 1-2" tops. no way to fix the problem short of having a custom shock made up, which I have never seen.
why do you need to lower the back so much?
welcome to the site.
Old April 6th, 2009, 10:05 PM   #18
zartan
zartan's Avatar
Motorcycle(s): 08 250 R
yes I stiffened up the spring. and no passengers pegs!!
"Don't let adverse facts stand in the way of a good decision" Colin Powell
zartan is offline   Reply With Quote
Old April 6th, 2009, 10:16 PM   #19
Z, by that you mean you set the preload higher?
exactly how much is your bike lowered by??? 2 inches, if I remember correctly?
Old April 6th, 2009, 10:45 PM   #20
zartan
zartan's Avatar
ah yea..preload higher... if that means shortened the spring to make more tension.
exactly how much??? did not get a chance to measure the back before.
whatever the x10 link shortens it on the shorter of the 2 holes. Around 2 "
They didn't even have aftermarket links back then last year early April 08
my dealer experimented with the x 10 link. I took it back to set the preload higher because it would bottom out. ( they have the right tool not the silly one in the kit). I would not have lowered it if I did not have had to.
Now I only bottom out when I hit something excessive at speed or going down stairs...
Old April 6th, 2009, 11:13 PM   #21
huh?
Old April 6th, 2009, 11:31 PM   #22
miks
I'm lovin' it.
miks's Avatar
You ride your bike down stairs? You're a stunter?!
Old April 7th, 2009, 12:38 AM   #23
zartan
zartan's Avatar
No I don't ride down the stairs. I was just being goofy...about the stairs. the rest was serious.
Old April 12th, 2009, 07:15 PM   #24
snowlife
Can you get 1.5" lowering safely?
Old April 12th, 2009, 07:25 PM   #25
who are you asking that question of?
Old April 13th, 2009, 03:30 AM   #26
snowlife
anyone with an answer. SO can you lower the rear of the bike 1.5" without the tyre it rubbing against fairing?
Old April 13th, 2009, 04:58 AM   #27
NickH
NickH's Avatar
Motorcycle(s): 2009 Buell XB12Scg and 2009 Kawasaki Ninja 250R
Couldn't you tighten the rear spring to prevent it from compressing and "bottoming" out?
-Nick-
Posted via Mobile Device
NickH is offline   Reply With Quote
Old November 2nd, 2009, 08:48 PM   #28
subiegy2010
noob in training
Motorcycle(s): '08 Ninja 250R (sold) '05 SV650S
I posted this in another thread but I think it should be in here for future reference as well:
So here is a pic of where it is rubbing
And just so everyone can see what hole my lowering links are on:
This pic shows the bikes height at that setting; the kickstand is on a brick so you can see the height without the bike leaned over.
So I'm thinking about either putting a small piece of black duct tape over that area and allow it to rub on that instead of the fender. Any thoughts on this? Either that or I will just raise it up half an inch to the next setting.
If I raise it up, that makes the Lowering Kit pointless because the Roaring Toyz kickstand will no longer be needed. That was the most expensive part of the kit (over $100)... I don't understand why RT even makes this kit if it can't be used on a setting that would require a new kickstand without the tire rubbing on the fender.
subiegy2010 is offline   Reply With Quote
Old November 2nd, 2009, 09:03 PM   #29
KJohnson21
KJohnson21's Avatar
Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick"
Try adjusting the suspension stiffness. If you've never touched it, it's probably on the softest setting. If you stiffen it a notch or two, it'll make it harder to bottom out or rub. It'll end up raising the rearend a little bit too.
HEY!! Unregistered!! Does your bike have a name?
KJohnson21 is offline   Reply With Quote
Old November 2nd, 2009, 09:14 PM   #30
subiegy2010
noob in training
I was actually thinking about that, I'll try it tomorrow. I'm pretty sure the previous owner hasn't touched anything on the bike, so the suspension is probably at the stock setting.
Old November 10th, 2009, 08:45 PM   #31
subiegy2010
noob in training
I set the spring to position 2; it was at 1. The bike is in storage for winter so we'll have to see if it works or not in the spring.
In the mean time though, Zartan, what setting is your spring set to and have you experience any rubbing?
Old November 12th, 2009, 11:47 PM   #32
zartan
zartan's Avatar
My bike is using a x10 link so not the same as Roaring toyz. I have the shock spring set pretty stiff almost all the way. Still once in a while I feel it bump but not too often.
Old November 13th, 2009, 01:46 PM   #33
subiegy2010
noob in training
It looks like your x10 link lowered the bike about the same as my RT link.
Old December 23rd, 2009, 07:59 PM   #34
mychelle
mychelle's Avatar
Thanks for the DIY. It helped a lot and now I can touch the ground with both feet!
mychelle is offline   Reply With Quote
Old December 28th, 2009, 07:20 PM   #35
Baby Ninja
2007 Ninja 250
I was given these same links at a local dealer. Will they also work on a 2007? If so, any other thoughts?
Baby Ninja is offline   Reply With Quote
Old June 24th, 2010, 02:56 PM   #36
jermyzy
Motorcycle(s): '09 Kawasaki Ninja 250R, '09 Suzuki SV650SA
Any update if this worked? I recently lowered the 250 for my wife and put it at the 4th hole (same setting as yours) and we are also experiencing the fender rubbing issue. She is quite short so raising it up another notch is not the best option. Did adjusting the pre-load solve the problem?
jermyzy is offline   Reply With Quote
Old June 24th, 2010, 03:07 PM   #37
did you lower the front, too?
Old June 24th, 2010, 05:12 PM   #38
jermyzy
Yes, front was also lowered with the Roaring Toyz kit. The shop that lowered it for us says he will adjust the rear preload settings, but I'm not sure if that will solve the problem or not. There is currently about a 3-4 finger gap between the rear wheel and the rear fender.
Old June 24th, 2010, 07:21 PM   #39
adjusting the preload will make the bike ride harsher over bumps if she's light.
exactly how short is she? inseam length?
Old June 24th, 2010, 09:38 PM   #40
subiegy2010
noob in training
After I adjusted the preload the ride got really harsh, especially on bumpy roads. I probably weigh more than your wife so it would be even worse for her. As far as if setting it higher stopped the bike from rubbing, I'm not sure. I didn't keep it at that setting long enough to know. I raised my bike up one notch and set the preload back to 1 since then. Bike is much more comfortable and I like the added height.
Roaring Toyz lowering links/dogbones hole layout (pic) dullers 2008 - 2012 Ninja 250R Tech Talk 1 June 1st, 2013 11:11 AM
Roaring Toyz Lowering Links + Blocks zomgcake Motorcycle-related 1 October 27th, 2010 06:12 AM
Roaring Toyz Lowering Links - settings heights? azia 2008 - 2012 Ninja 250R Tech Talk 11 September 8th, 2010 01:18 PM
added: shogun frame sliders, roaring toyz lowering links and blocks! BIGT94z Pictures 7 July 26th, 2010 02:21 PM
