May 3rd, 2012, 12:33 AM | #1 |
Dakine...
Join Date: Jun 2011 Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon) Posts: A lot.
DIY: less than $100 Clip-ons
So, you want clip-ons, but can't really afford them? heres a pair of clip-ons that cost less than $100...
Some back ground. I saw a SV650 clip on (one side) for sale in this forum saying that people swap those clip ons to our ninjas. after some searching, i found the DIY on Kawiforums. it was made in 2008. ALL the DIY pics are gone. so after reading through 28 pages, i'm making a DIY for those interested. I bought mine from @CZroe. im sure you can find them online. Difficulty: 3/5 Supplies: SV650 Clip-ons 0.020 Rod bearings (this is used as a spacer. fork is 37mm dia, clip on is 41mm) torch hand impact driver Basic tools torque wrench front and rear stand hammer rubber mallet replacement grips (optional) paint (optional) Here is the clip ons and rod bearings See the nub? get your dremel and chop it off Before: After: This is how a rod bearing looks, two come in a box chop them in half and pre curve them how they sit in the clip ons if you want to paint them, i used 2 coats of this: let them dry remove bar ends using torch to heat up bar end screw and remove using hand impact driver. use screwdriver to help you remove the grips remove bars and controls. set them aside do not let brake reservoir flip or you have to bleed the brakes. this is how i delt with it: the previous owner dropped the bike. bar bent and i did not know. i could not even tell it was bent. remove stem bolt (22mm or 7/8) and loosen upper fork clamps. remove the upper tripple tree clamp the chopped bearings did not quite fit as expected. chop two in smaller pieces place them in clip on and slide a bit down the fork tube. this is how it sits now *Place upper tripple tree clamp and bump it in place with a rubber mallet. clip ons should be as flush as possible with the tripple tree clamp. *tighten stem bolt (43 ft lbs) and upper fork clamps (18 ft. lbs) *loosely place controls on bars *bringing front end to full lock right and left, set your adjustments and clearances. there will be some rubbing, tight clearances. this is how its going to be. this was the mod that got Woodcraft making our clip ons. these clip ons are the only ones with risers decent enough to use also the smallest diameter clip ons. *once clearances are set, tighten the bolt for the clip ons and re-assemble bars with the controls. here is my clearances: Left full lock Right full lock *there is a small gap, but the camera did not pick it up. all done to clean up the look a little, i used this furniture plug things still need to find something to plug the forks with. ***Final thoughts: I was going to do the DIY bar ends that kkim made earlier, but i found weighted bar ends for the sv650 and got them only for $11. while test riding, the bars vibrate, but is tolerable. im gonna bet when i put the bar ends on it, the vibration will minimize. the riding position is a lot more aggressive now and will take a few rides to get used to. going into turns are really easy. it kind of just falls into the turn without hesitation. your hands get a little pinched while doing slow tight maneuvers, but you can adjust how you hold the bars and it will be just fine. for regular city riding, my hands were just fine, no pinching. have not went on the freeway yet or hit up the twisties yet, but looking forward to it. Yes my baby is dirty, gonna clean her up later Any questions, comments, etc... discuss |
May 3rd, 2012, 03:12 AM | #2 |
Join Date: Feb 2010 Motorcycle(s): 2009 CT Blue 250R(Sold), 2008 Black & Silver Honda CBR600RR(Current) Posts: 201
I looked hi and low to find caps to cover the forks but to no avail.
I just went and bought a set of Slingshot racing fork preload adjusters, if you remember seeing blue ones on my bike. http://www.slingshotracing.net/catal...dju-p-191.html Only down side with them was after awhile the anodized finish on theme faded. |
May 3rd, 2012, 04:46 AM | #3 |
Great job man! This mod may very well be in my future. Keep us updated!
May 3rd, 2012, 08:07 AM | #4 |
/linked
May 3rd, 2012, 08:36 PM | #5 |
Dakine...
Rode it again to work and gym. did not feel right(too crouched/squished together) so i moved my rear sets one notch back (A&L rear set adjusters) and lowered my shift peg a little. feels MUCH better now to figure out how to switch to GP shifting without cutting and welding anything...or at a minimum anyways...
May 3rd, 2012, 08:39 PM | #6 | |
Dakine...
May 3rd, 2012, 08:59 PM | #7 |
I found a few sets of the sv650 clip-ons online for a good price and will be doing this mod soon hopefully. Do you use the holes to line up the throttle housing and what not or did you drill new ones?
How tall are you? Reason why I ask is because I still have the stock rearsets.
May 3rd, 2012, 09:33 PM | #8 |
Awesome work, AJ!
Just wanted to add a few things:
Last futzed with by CZroe; May 5th, 2012 at 07:34 AM. |
May 3rd, 2012, 09:43 PM | #9 |
Linky to old thread: http://www.kawiforums.com/ninja-250r...u-clipons.html
I remember the thread when the pictures were still up. I followed the thread up till Woodcraft finally finished producing the clip-ons for our bikes.
May 4th, 2012, 12:24 AM | #10 | |
Dakine...
i just clipped off the nub that goes into the holes. no, it does not move/rotate when the screws are tightened. you can get them tight but not over tight and i could not get them to budge, so thats good. I am 5'6"-5'7" somewhere along those lines. If you are the same height or taller, i suggest new rear sets or adjustable rear set adjusters so you can get the bikes pegs and shifter to comfortably align with your new riding posture. thanks for posting the original thread. |
May 4th, 2012, 12:28 AM | #11 | |
Dakine...
yes. all true. i'd like to add a little to the fourth point. Some people are not concerned with losing the steering lock so they added the washers. I dont mind readjusting my grip while doing tight parking lot maneuvers to avoid pinching my hands on the fairings. i thought you just taped them to somehow protect them while shipping here |
May 5th, 2012, 02:16 PM | #12 |
Picked up some clip-ons! Will look into getting the rod bearings.
May 5th, 2012, 07:03 PM | #14 |
I just picked up a rod bearing for a mid 90s Chevy v8. Chevy parts are always in stock and always
Part # CB663P30
May 6th, 2012, 01:50 AM | #15 |
Dakine...
you are going to need to cut them up. i spend almost an hour trying to shape them to fit right and just ended up chopping them up. good job on the find though. and if you do get them to fit, you get to make a DIY for that
May 6th, 2012, 02:00 AM | #16 |
Dakine...
UPDATE: today i did some freeway riding as well as some twisties.
1) Freeway riding: currently, i dont have bar ends and the high RPM vibration made my hands a little numb after 20 mins..yes, i was wearing gloves. it is much easier to get into a full tuck and feel more "natural" while in tuck. 2) Twisties: there is this road called "Tantalus" about 15 mins from my apartment. its apx 2 miles of back to back turns...very sharp turns, including a few hairpins. half way up is uphill and the other half is downhill. like i mentioned above, after about 15 mins, the high rpms numb my hands. other then that, they felt really good. not really sure how to describe it though :/ --I do have bar ends coming in and cant wait to put them on. My friend, a fellow ninjette member has the woodcraft clipons and i sat on his bike. just from sitting on his bike and holding the handle bars, i can positively say that the SV650 clipons have a more aggressive ergo compared to the woodcraft. |
May 6th, 2012, 07:54 AM | #17 |
Couldn't you have reused the stock bar ends like in Kim's DIY?:
http://www.ninjette.org/forums/showthread.php?t=14281
May 6th, 2012, 09:00 AM | #18 | |
May 6th, 2012, 12:14 PM | #19 |
Dakine...
i originally was going to use my stock bar ends and do kkims DIY. but there is a small lip that goes over the bar before coming flush with the handle bar. that forces me to puch the controls closer with even more clearance problems. yes, those few millimeters do make a difference. also, the tubing i got(for free) the ID was too small. The bar ends that are coming in weigh apx the same as the OEM bar ends.
May 6th, 2012, 10:39 PM | #20 |
Dakine...
If anyone is interested, i came up with a way to plug the fork tubes. I used some furniture leg plugs i got from city mill. it fits pretty snug so i dont have to worry about it coming out or some punk popping them out. so, here are the pics:
Left: Right: Top: What do you think? |
May 7th, 2012, 04:44 AM | #21 |
Not bad...
Can you take a picture of one before it's installed so when can see what to look for?
May 7th, 2012, 12:10 PM | #22 |
Dakine...
Sorry, i did not take pictures of it before installation but heres a pic i found online. They looked like this. except the top is rounded instead of conical. and the size? im not sure. they are all in standard sizes and i had my micrometer with me so i just measured the diameters. make sure the ones you look for are hollow on the inside.
originally, i was going to find a plug that covered the entire fork tube but could not find any large enough. so i found some that will fit inside of the tube. that measurement is 32.xx mm at the base of the rounded part. i forgot what the actual measurement is. I cant just pull out the caps, they are pretty snug in there. i think i actually need to destroy them to get them out. they were only a dollar and some change anyways. |
May 7th, 2012, 10:02 PM | #23 |
I found out that it's easier to go ahead and cut the bearings in half and end them with pliers or channel locks you'll need to grind down the grooves on the bearing so it's flush. Also hammer the edges of the bearing so it'll make it easier to slide in. Also get a flat head to help open up the clip-ons for the bearings. I tapped mine in with a hammer and flathead screwdriver to have them set further in. The clearance from the control is. Very tight so you can expect some slight rubbig every once in a while. You could grind away an 1/8th if material to give you more room. I just hope and pray that my fingers don't get broken or dislocated from a freak accident. Thoughts: very sportier position and is great for people tall like me 5'11"+. The bars vibrate since I don't have weighted barends yet. Only cost was the bearings as a shop owner gave me these bars for free.
May 8th, 2012, 01:57 AM | #25 |
Join Date: Apr 2012 Motorcycle(s): 2011 Yamaha R6 & 2012 Kawasaki Ninja 250 Posts: 13
Nice write up AJ!
May 8th, 2012, 10:50 PM | #26 |
Join Date: Apr 2012 Motorcycle(s): 2008 ninja 250R 1979 SuzukiGS425E Posts: 94
How does flipping the brake reservoir over let air into the brake line and require you to bleed the front brake? Or...is there another reason it needs to be bled if it is accidentally flipped? I ask because I lowsided in gravel the other day and ended up having to take the whole throttle tube/front brake reservoir/assembly thing off because my throttle was sticking open. I did fix the throttle sticking issue, but I didn't know that the reservoir shoudn't be allowed to flip and it might have done so. Before reading this and after riding 120+ miles today I noticed that my front brake felt "weird" but had no idea why. I'm worried I might have allowed the reservoir to flip, but don't understand the mechanics of why that would cause problems and would like to know all the "why"s so I don't do this again. =)
May 9th, 2012, 08:23 AM | #27 |
There is some air in the brake reservoir. Turning the reservoir upside down allows air to get into the line and may get trapped in it.
May 9th, 2012, 01:03 PM | #28 |
Makes sense! Thanks! I'll have to keep an eye on that in the future.
May 9th, 2012, 10:13 PM | #29 |
Looks like I could use more shims. The pinch bolt for the clipon is torqued down and the gap is almost closed.
May 9th, 2012, 11:17 PM | #30 |
Dakine...
i dont think it needs to cover the entire gap. mines has even spaces around the fork tube and is pretty darn snug, but more wouldn't hurt
May 10th, 2012, 12:26 AM | #31 |
I think he meant the gap between halves at the pinch bolt.
And man, these seem to be better than the Woodcrafts. I love the Woodcrafts, but I hate how the weld of the pinchbolt on the upper triple tree forces the bars orientation to be closer to parallel with one another than the stock bars. They recently released something to remedy the problem, but I don't want to pay another 40 dollars for it... |
May 10th, 2012, 04:39 AM | #32 |
@Coung: Can we get some pics with the bars at full lock in both directions?
May 10th, 2012, 09:26 AM | #33 | ||
Let me run out and take some pics.
May 10th, 2012, 10:07 AM | #34 |
For some reason my bike turns farther right than it does left.
May 10th, 2012, 10:46 AM | #35 |
Thanks Cuong! Oh and sorry for the previous misspelling. Bank prolly won't even notice it on your check.
May 10th, 2012, 06:25 PM | #36 | |
I just finished installing the stock bar ends onto the clip-ons. I went to Lowe's and picked up some 5/16 x 2.5" hex bolts. I was going to with the oval head bolts like the stock 250 ones but they didn't sell them in pairs or singles and I didn't feel like paying 6 dollars for a bag. You'll have to get some black paint because the silver bolts stick out like a sore thumb. What you need: 2- 5/16 x 2.5" long bolts 2- 5/16 x nuts 5/16 rubber hose about 2.5" long cut in half. You can get a 3" bolt just make sure you get a longer hose accordingly. As AJ mentioned, the stock bar ends encloses over bar and does not sit flush against the end so you'll have to adjust your grips inward some for clearance.
May 14th, 2012, 07:27 PM | #37 |
If anyone is looking to do this, a forum member is still selling one of the two you will need:
http://www.ninjette.org/forums/showt...967#post495967 |
May 14th, 2012, 07:46 PM | #38 |
Dakine...
@cuong-nutz: i noticed you have your controls all the way in. how is your clearance with the brake hose to the gauge cluster when full lock left? i have prob. 1mm clearance on mines. if you have more, i'll be moving my grips and controls closer in and then use the stock bar ends since i will have more room
May 14th, 2012, 10:21 PM | #39 | |
May 16th, 2012, 11:16 PM | #40 |
Just to add, I commute on a daily basis and after this mod, I hear more wind noise as I'm closer down into the turbulent airstream from the windscreen. My new sport touring windscreen should fix this problem.
Ninja 250 DIY clip ons caused problems...NEED HELP | jaybro40 | 2008 - 2012 Ninja 250R Tech Talk | 26 | January 3rd, 2013 03:55 PM |
DIY Clip-ons or Redneck I did it myself? | Little Green Machine | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 2nd, 2012 08:18 PM |
Woodcraft clip-ons V.S. Kitaco clip-ons | tjb0012 | 2008 - 2012 Ninja 250R Tech Talk | 41 | June 20th, 2011 05:35 PM |
